Locking the flywheel without gearbox attached 18G1674 - MG-Rover.org Forums
post #1 of 27 (permalink) Old 09-03-2017, 07:56 Thread Starter
Car: Please Select
I have a 2003 MGTF 135, which I am currently trying to change the headgasket on. I have separated the engine and gearbox as I am going to change the clutch at the same time.
I am trying to lock the flywheel, in the manual it says to use tool 18G1674, but I am unable to find anyone who has this online.
I found out that the LandRover part number for the tool is LRT-12-190 but drawn a blank on this.
Does anyone have this tool? or any other suggestions, other than attached the gearbox back.
Gareth
gjefferies is offline
post #2 of 27 (permalink) Old 09-03-2017, 08:21
super_cds is offline
post #3 of 27 (permalink) Old 09-03-2017, 08:28
no 11 here
Cambelt - TechWiki
post #4 of 27 (permalink) Old 09-03-2017, 08:36
post #5 of 27 (permalink) Old 09-03-2017, 08:40
Or this general purpose one. Sealey VSE2394 Flywheel Locking Tool | eBay
post #6 of 27 (permalink) Old 09-03-2017, 08:40 Thread Starter
Car: Please Select
Thanks I will give that a try... I have cam locking tool installed, but need to remove the crank bolt...
post #7 of 27 (permalink) Old 09-03-2017, 08:45 Thread Starter
Car: Please Select
@CJJ I have the pg1 and non-pg1 locking tools I can't get two bolts to line up in the location near the cylinder head, which the k-series manual says.... Guess its for the R65 gearbox/flywheel not PG1. In the MGTF manual is says to use the 18G1674 tool.
I noticed Sealey VSE2394 as a possible solution, has anyone used this successfully?
Gareth
post #8 of 27 (permalink) Old 09-03-2017, 11:29
Think before you type!
Have you thought about making one from a bit of scrap metal?
IanMc is offline
post #9 of 27 (permalink) Old 09-03-2017, 11:31 Thread Starter
Car: Please Select
Yes I have considered it briefly, but I don't really have the skills...
post #10 of 27 (permalink) Old 09-03-2017, 18:17
I used the same one CJJ indicated
Flywheel Locking Tool MG ZS ZR K16 Rover With PG1 Gearbox OEM 18G 1742
Fitted fine to my 2003 135 TF
g0rsq is offline
post #11 of 27 (permalink) Old 09-03-2017, 18:19 Thread Starter
Car: Please Select
Did you fit that in place of the starter motor?
post #12 of 27 (permalink) Old 09-03-2017, 23:44
Cot the one CCJ mentioned, actually used it three weeks ago on my TF.......it fits in place of the starter
dert is offline
post #13 of 27 (permalink) Old 10-03-2017, 07:01 Thread Starter
Car: Please Select
I have the same tool, but no gearbox to attach it too... Doesn't fit in the two screw holes above the flywheel in the block...
Hence why I am looking for 18G1674 tool
Gareth
post #14 of 27 (permalink) Old 10-03-2017, 17:36
Gareth
Yes sorry.
I had not realized that it fixed to the bell housing, and not the block.
I understand problem now.
Peter
g0rsq is offline
post #15 of 27 (permalink) Old 10-03-2017, 20:05
Would this not work?
MG Rover 25 ZR 45 ZS Engine Locking Tool Set Cambelt Change Without PG1 Gearbox | eBay
Cheaper version here MG ZR MGF ZS ZT TF FLYWHEEL LOCKING TOOL WITH PG2 GEARBOX OEM 15G 1571 | eBay
Should only need the 18g1674 if reluctor ring fitted
dert is offline
post #16 of 27 (permalink) Old 11-03-2017, 00:20
Would a windy gun not do it?
1Leigh is offline
post #17 of 27 (permalink) Old 11-03-2017, 05:05
Car: MG6 GT TSE Turbo
I had exactly the same problem with by MGB. I had a PG1 locking tool from my ZR160 days and by bolting a strip of metal as a back plate onto it I was able to lock the flywheel.
It was more of a problem once the flywheel was off to change an oil seal and needed to remove the front crankshaft pulley. But the B engine was on a stand and this is what I did.
With the sump off the crankshaft can be locked using a block of wood and no special tools are needed.
I don't know whether this could be done on a k engined car without removing the engine but it is just a suggestion.
new160 is offline
post #18 of 27 (permalink) Old 11-03-2017, 20:00 Thread Starter
Car: Please Select
@dert, i've got that tool and it doesn't fit... I can get one bolt lined up but not two. I guess that image is for the Rover 200 1.4 with the R65 gearbox. In the MGTF workshop manual it says to use 18G1674, but the k series manual says to use the 18G1571 tool, guess they never updated the manual.
I've ordered the tool that CJJ suggested and see what happens....
Thanks for all the suggestions
Gareth
post #19 of 27 (permalink) Old 11-03-2017, 22:07
The holes in the engine casting are in the same place regardless of the gearbox that is fitted to it.
post #20 of 27 (permalink) Old 12-03-2017, 07:27 Thread Starter
Car: Please Select
Yes but the flywheels are different which I guess is the reason, mg-rover changed the info in the workshop manual.
locking the flywheel? Wattsy MG ZR / Rover 25, 200 & Streetwise 5 18-03-2014 10:36
flywheel locking hughes07 MG ZR / Rover 25, 200 & Streetwise 8 09-06-2011 21:01
Hand make - Flywheel locking tool with PG1 gearbox Blueser MG ZR / Rover 25, 200 & Streetwise 6 13-02-2011 11:37
Flywheel locking? Ayrton19 MG ZR / Rover 25, 200 & Streetwise 3 14-11-2010 14:06
Flywheel Locking???? Randyjim Others 48 24-01-2005 16:39
