MG F/TF Fuse Listing - MG-Rover.org Forums
  • 1 Post By Roverlike
post #1 of 20 (permalink) Old 09-10-2012, 19:57 Thread Starter
Post MG F/TF Fuse Listing
I noticed there is no thread with information regading fuse listing and I think it could be useful to forum memebrs. In order to have full information on one place I added listings for TF 2003 onwards below.
I can not create nice tables by using only appropriate fonts, so I decided to use pictures as you can see below. I hope it will be useful to you.
The majority of the fuses are mounted in three fuse boxes:
- Under bonnet fuse box - attached to the LH inner front wing
- Passenger compartment fuse box - installed behind a fuse box closing panel on the driverís side of the fascia;
- Satellite fuse box attached to the side of the passenger compartment fuse box.
In addition to the fuse boxes, in-line fuses are installed:
- Near the under bonnet fuse box, for the Electric Power Assisted Steering (EPAS) system.
- Behind the LH side trim of the luggage compartment, for the Electro Mechanical Constantly Variable Transmission (EM-CVT), where fitted.
- On the side of the passenger compartment fuse box, for the SRS system.
- Behined driver side of facia, fuse for alternator
FUSE COLORS
UNDER BONNET FUSE BOX
PASSANGER COMPARTMENT AND SATELLITE FUSE BOXES
(RHD is shown, while LHD is simmilar)
EM-CVT FUSE
ALTERNATOR FUSE (MGF 2001 Model Year and after)
________________________________________________
TF 2003 ONWARDS
MINI BLADE FUSE COLORS
PASSANGER COMPARTMENT FUSE BOX
All relays in passenger compartment fuse box for MG TF 2003 onwards are the same part number YWB000440:
EM-CVT FUSE
ALTERNATOR FUSE
Chris T likes this.
post #2 of 20 (permalink) Old 09-10-2012, 20:11
Car: (Penelope) Mgf 1.8 Freestyle and (Beryl the peril) Trophy 160
Excellent effort, I could have done with this very recently, I hope this will become a sticky v.soon
plumber paul is offline
post #3 of 20 (permalink) Old 09-10-2012, 20:15
Car: MG TF 135 Sprint, Freelander Td4
Nice one Roverlike, very handy guide.
Mindy is offline
post #4 of 20 (permalink) Old 09-10-2012, 20:20
Car: "MIGUEL" 2001 MGF 1.8i Anthracite ! Previously had "Gertrude" a 1998 Belgian MGF 1.8i RIP !
Just look in the factory handbook, its all there ! !
Great info tho !
Will be of great help to members.
MGF-Gertrude is offline
post #5 of 20 (permalink) Old 02-11-2012, 18:38
Car: MGTF 160, TF LE500, Nissan Leaf, KTM 640, Kangoo Van, Freelander
Oooh. Just found this, nice work.
The 2003 onwards TF has the mini blade fusebox under the steering wheel, which looks like this.
post #6 of 20 (permalink) Old 02-11-2012, 20:01
Car: Ophelia~ a 2004 MGTF 160 in Spectre
There's also the 80 amp alternator fuse in the engine bay (I never knew this existed until it blew!!! )
Hopefully someone can find a photo
Good list tho and well worth adding to the stickies!
Birks is offline
post #7 of 20 (permalink) Old 02-11-2012, 20:09
post #8 of 20 (permalink) Old 02-11-2012, 21:08
This one?
post #9 of 20 (permalink) Old 03-11-2012, 10:23 Thread Starter
Hi CJJ and Birks,
I added information missing above, to complete this thread...
post #10 of 20 (permalink) Old 03-11-2012, 11:44
love it but will i be able to find it when i need to sticky please
Ron
bugsb is offline
post #11 of 20 (permalink) Old 10-08-2013, 18:17
This thread really does deserve to be in the 'How To' sticky
Would a moderator be able to help please?
will dig is offline
post #12 of 20 (permalink) Old 03-12-2015, 21:08
Car: MG ZR Turbo
passenger fuse box location
FUSE COLORS
EM-CVT FUSE
TF 2003 ONWARDS
EM-CVT FUSE
ALTERNATOR FUSE
were the hell is the passenger fuse box located..........not the driver side.
DJ TATTY is offline
post #13 of 20 (permalink) Old 04-12-2015, 06:04 Thread Starter
Passenger COMPARTMENT fuse box is on the driver side, under steering wheel.
Under bonnet fuse box is under front bonnet.
post #14 of 20 (permalink) Old 04-12-2015, 06:47
Think before you type!
Crikey, its quite difficult to miss.
IanMc is offline
post #15 of 20 (permalink) Old 23-06-2016, 21:21
Unhappy 80A fuse
I also have the battery light on and I can't find the fuse on my car - its an MGF year 1998 - does it have the said fuse ?
peterMGF is offline
post #16 of 20 (permalink) Old 19-11-2016, 21:16
pandrew3's Avatar
Thanks for this. I finally get to know what the round thing in the middle of the fuse box is. The cigar relay!!! I have been worried about this one as I noticed it is hot when I plug in my OBD2 in the TF. Does it just pull out? Could be why I cannot get any power out of the cigar plug even after I replaced the fuse.
pandrew3 is offline
post #17 of 20 (permalink) Old 20-11-2016, 06:42 Thread Starter
Round relay has two retaining clips from each side holding him in place. Otherwise you just pull it out
post #18 of 20 (permalink) Old 20-11-2016, 09:09
Hi and welcome to the forum (although you probably haven't been back since June)
The early MGF doesn't have this fuse.
James
post #19 of 20 (permalink) Old 04-12-2016, 08:55
The fuse box layout and info is great but I seem to have a problem, whilst trying to get the heated rear window to work I have found that the red engine bay fan relay is plugged in to what should be the heated rear window and there is a yellow relay plugged in to the middle slot for the engine bay fan. Any advise on whether this could just be an flaw of manufacture or has someone been fiddling?
Would the HRW relay actually work the engine bay fan?
Or should I just presume that the relays are the wrong way round and replace them both as they are probably knackered?
Bob B is offline
post #20 of 20 (permalink) Old 04-12-2016, 13:04 Thread Starter
Actualy both relays work in same way so they might be swapped.
What is the color of the bases of these relays? If base color correspond to relay color they might be in correct place. I think that relay's bases can be detached from each other and reattached in different order.
Best Ebay Listing Ever jimbogarner MG / Rover Related Chat - up to 2005 3 21-05-2010 10:58
My listing on Ebay Higgman For Sale 4 24-03-2010 08:20
The Best E-Bay Listing Ever Eric 1945 Rover 800 3 12-04-2009 18:42
Coupe Engine compartment fuse box (T series) - 40amp fuse blows? empsburna Coupe 40 22-05-2008 22:11
