MGF Feels like it floating at 70mph - MG-Rover.org Forums
post #1 of 25 (permalink) Old 30-06-2011, 16:00 Thread Starter
Unhappy MGF Feels like it floating at 70mph
Hi people i have a V reg MGF very proud of but on the motorway i go about 70mph and it feels like it floating is there any ideas what it could be or how to sort many thanks people.
Chris
cs190207 is offline
post #2 of 25 (permalink) Old 30-06-2011, 16:44
Car: MGF + Seat Ibiza FR TDI
Eat KFC for a few days? Always take a passenger? put some cement in the boot? take the wings off?
bobinio is offline
post #3 of 25 (permalink) Old 30-06-2011, 16:47
Car: Mini Cooper S 1.6 Turbo
What tyres do you have on the car? Is the PSI correct for all tyres? Is the ride height correct? Tracking been done? Do you have a spare tyre under the bonnet as this helps a little.
I also fitted a front splitter which helped.
Sam Luck is offline
post #4 of 25 (permalink) Old 30-06-2011, 16:58
Car: TF160
+1 to Sam's advice.
The F is prone to feeling light at the front - it shouldn't necessarily wander about (this could be a problem with tracking or pressures), but it's not unusual to feel a little 'floaty'.
Either a K&H splitter or a trophy front spoiler will reduce lift and lightness at speed.
Jason
Rejected Takeoff is offline
post #5 of 25 (permalink) Old 30-06-2011, 17:47
Car: Mgf Trophy 160 Now without hydrogas
Agree with Sam this is a very common post from new owners what brand are your tyres check the tyre pressures and ride heights when I got mine it had brand new budgets on the front one tyre 22 psi the other 40 psi not great when I had to drive it 250 mile home at 50mph max
midlife martyr is offline
post #6 of 25 (permalink) Old 30-06-2011, 17:52
Car: ZR-T16
I have an F and had the exact same issue, grab a K&H splitter and then you can go alot faster with no scary light handling
kev321 is offline
post #7 of 25 (permalink) Old 30-06-2011, 17:53
Car: Jaguar X type 2.2 SE + MGTF 160 Aurora
Correct tyres & pressures are probably THE most important thing handling / driving wise on an F / TF.
As Sam says......tell us exactly what tyres you have on each corner, the size & pressure
Slippy is offline
post #8 of 25 (permalink) Old 30-06-2011, 18:21
Car: 1997MGFVVC x 2;1971MGBGT;2002Rover25.
My guess is tyre make, mix and condition, pressures and geometry.
What make of tyres do you have, are they the same all round, is there uneven tread wear across the tread pattern and are all tyres at a similar state of wear?
Having checked all this and corrected any anomalies it is essential to have the tracking tested on a 4 wheel laser tracking station by a competant outlet with a known reputation, preferably used to the MGF/TF set up.
Most handling problems on these cars of ours are corrected by these procedures.
Hope this helps
Get some answers to these queries posted ASAP so that we can confirm advice before you kill tourself.
Mykul
ORKHIS is offline
post #9 of 25 (permalink) Old 30-06-2011, 18:30
Car: I have 186 different cars
Mine was the same, albeit at 80mph+.
Changed tyres for GSD2's all round because they were due, had tracking done for what it costs.
Tyre pressure always correct, full size spare in front.
Not much change to be honest.
A regular, knowledgable forum member once told me these cars are 'skittish at high speed', I've learnt to live with it.
Think I'm spoilt with the D3 and A6 I drive far more regular, and notice it more as a result.
Will probably try a front splitter, for what they cost.
Personally I think more people experience this problem than they care to admit.
Have you got a spoiler on the boot?
Will Hay is offline
post #10 of 25 (permalink) Old 30-06-2011, 18:37
Car: TF160
I'm still with kev re splitter. To an extent it depends on whether you mean it just literally 'floats' or whether it tries to steer itself off the road.
Mine still floats at 70mph and that's with 4 nearly new tyres of correct size, pressure, same make and recently tracked, but after a year I'm used to it.
Having said that, obviously the advice re tyres is still very good and relevant - just don't expect it to disappear even with new rubber.
I think coming to an F from any other car is very much a culture shock regarding 'feel'. Not sure who quoted it in a post long ago, could have been Kameleon but can't swear to it, "the F will never be a one finger steering job"
As Orkhis says, let us know so we can help further if we can - be safe out there!
Jason
post #11 of 25 (permalink) Old 30-06-2011, 19:10
Car: Pug 206CC Sport
Having asked the same question (plus others) a few days back I can happily report that getting my tyre pressure right did help alot. I'd overcooked my pressure on the fronts, putting in 33psi instead of the 26psi they are meant to be
I am also ordering a front splitter (Seat Leon one - thanks to those who mentioned it!)
Minxy is offline
post #12 of 25 (permalink) Old 30-06-2011, 20:34
Car: 2000 VVC
Mine was terrible, would even swerve between lanes until I got the susspension pumped up to the correct height. Best 20 I've ever spent
peedy17 is offline
post #13 of 25 (permalink) Old 30-06-2011, 21:38
Ooops!
Forgot to mention that bit, got a little carried away with the other things while cooking dinner.
Mykul
ORKHIS is offline
post #14 of 25 (permalink) Old 30-06-2011, 22:00
Car: MG TF 160 80th Anniversary
mine is "floaty" between 70-80, below or above this it's fine.
Chris is offline
post #15 of 25 (permalink) Old 17-07-2011, 15:18 Thread Starter
Smile hi
thank you so much people i going to get a splitter soon and just going to check my tyres to see so weird i do love the mgf but hate going fast that is hard for me to say
cs190207 is offline
post #16 of 25 (permalink) Old 17-07-2011, 15:28
The front of the F is such that at speed it will get a lot of lift under the front, this is worse than most cars as the bulk of the weight (the engine) is at the back.
The trophy or K&H splitter force more air up and over the front pushing it down rather than lifting.
post #17 of 25 (permalink) Old 17-07-2011, 15:38
I don't think it will ever feel as plated at the front as a front engined car, but this can be lessened with good choice of tyres and keeping the vehicle in top condition.
Remember that a lot of these cars are 10+ years old and there will be wear on Track Rod Ends, bearings, joints etc etc. All this will add to a vague and floaty feel.
Have you had it in to a garage to check out all of the joints/bearings etc?
post #18 of 25 (permalink) Old 17-07-2011, 15:39
Not sure it forces it over the top, just stops it going underneath which reduces lift.
post #19 of 25 (permalink) Old 17-07-2011, 17:04
It must go somewhere, some will go sideways but the rest must go up.
post #20 of 25 (permalink) Old 17-07-2011, 17:10
It provides downforce is all I know, bit like the front wings on an F1 car, not 100% sure how it all works but if it does the trick who cares?? hehe
Minxy is offline
MGF feels unsafe and wanders on Motorway xboxdevil MGF and MGTF (Sponsored by MGFnTFBITZ) 27 17-08-2011 19:57
Tramlining - Floating Etc... sandman1976 MG ZR / Rover 25, 200 & Streetwise 5 22-12-2010 20:18
There's something floating in the coolant... MCowgill MGF and MGTF (Sponsored by MGFnTFBITZ) 0 09-12-2010 17:00
floating subs!!! Robo214 In-Car Audio, Entertainment, Sat Nav etc... 26 04-09-2006 22:25
MGF - Handling Feels Wrong yellowduke MGF and MGTF (Sponsored by MGFnTFBITZ) 2 14-08-2005 10:09
