MGF Front subframe alignment - MG-Rover.org Forums
post #1 of 11 (permalink) Old 14-03-2017, 16:47 Thread Starter
Is it possible to put the front subframe back misaligned ????
I changed the lower wishbones (which necessitates lowering the front subframe) and after 4 wheel laser alignment it would appear that the right hand front wheel is approx. 1cm further back than the left hand front wheel. We inspected the frame and the under body but there is no evidence of work or accident damage. The car drives ok but the laser doesn,t lie and you can see the difference when you look from the side at two front wheel arches.
Any ideas ????????
Many thanks in advance
Clive
Mgwanderer is offline
post #2 of 11 (permalink) Old 14-03-2017, 20:45
I wouldn't think so. The bolts locate in specific places and there isn't much movement.
I think if anything was out of line you may have struggled to locate some of the bolts.
post #3 of 11 (permalink) Old 14-03-2017, 21:45
Stuck in the 80's...
Are the correct wishbones fitted and to the right side?
IanMc is offline
post #4 of 11 (permalink) Old 14-03-2017, 21:52 Thread Starter
Thanks for the reply Clive, I know you've had the subframes out , where would you start looking for the difference??
the other Clive
post #5 of 11 (permalink) Old 14-03-2017, 21:55 Thread Starter
Ian,
I checked that and the wishbones are stamped L & R......
Even in Flemish that is good as it is Links and Rechts ( I hope) :-) :-)
post #6 of 11 (permalink) Old 14-03-2017, 21:59
Was the subframe completely dropped or just the rear mounts?
If completely dropped, there is potential with the front mounts to be refitted slightly out due to the holes on the mounts being oval....pic below. However; yours being am F would have rubber insert mounts so not sure if that would make a difference. Have dropped the front subframe on both an F and TF to change lower arms, but never experienced your issue.
dert is offline
post #7 of 11 (permalink) Old 14-03-2017, 22:21 Thread Starter
Yes, lowered the full subframe to avoid any stress on the front mounts, but I find the difference quite a lot for something like an oval slot, but I will look again tomorrow.
Thanks anyway as all ideas are gratefully received
post #8 of 11 (permalink) Old 14-03-2017, 22:35
I would have thought if it were down to one component, like the lower arm, then you would have castor problems too.
post #9 of 11 (permalink) Old 14-03-2017, 22:58 Thread Starter
Clive , you mean the wishbone when you say lower arm???
post #10 of 11 (permalink) Old 15-03-2017, 00:48
Yes. They are called the front lower arm on F/TFs.
post #11 of 11 (permalink) Old 15-03-2017, 06:33 Thread Starter
I would have thought that (Rusty) front lower arm would have been a more descriptive name.
You can tell I've just woke up eh
mgf front subframe and bits stevewidds Wanted 2 14-03-2014 09:37
Subframe replacement - alignment! johnt40 MGF and MGTF (Sponsored by MGFnTFBITZ) 0 17-02-2013 16:19
rear subframe / front subframe Jaffacakekilla MGF and MGTF (Sponsored by MGFnTFBITZ) 7 02-09-2012 20:55
front subframe wanted. (MGF) gbs100 Wanted 3 05-07-2011 11:51
Rear Subframe alignment / locating BassADdict MGF and MGTF (Sponsored by MGFnTFBITZ) 6 23-12-2005 12:07
