MGF front Subframe mounts - MG-Rover.org Forums
post #1 of 14 (permalink) Old 20-03-2017, 22:36 Thread Starter
Hi again,
the deeper I try to go the more problems I have
1/
do the front subframe mounts have rubber bushes in them as It seems to but I can't find them on the drawings
2/
what would cause a castor angle of double the allowed figure, I cannot see anything wrong with the naked eye
Many thanks in advance
Clive
Mgwanderer is offline
post #2 of 14 (permalink) Old 20-03-2017, 23:57
1/ The normal F's had rubber bushes in them, the trophy was solid. The TF's are solid. F mounts as shown on fleabay link http://www.ebay.co.uk/itm/MG-MGF-1-6...wAAOSw5cNYW5yw
2/ can't help you on that one sorry.
dert is offline
post #3 of 14 (permalink) Old 21-03-2017, 06:32 Thread Starter
Originally Posted by dert View Post
1/ The normal F's had rubber bushes in them, the trophy was solid. The TF's are solid. F mounts as shown on fleabay link MG MGF 1.6 1.8 *HARDLY USED 17K* SMALL LARGE FRONT & REAR RUBBER SUBFRAME MOUNTS | eBay
Thanks Dert,
what is the forum opinion, is it better to keep the rubber ones or do people change to the solid ones as per TF / MGF Trophy ones.
If the recommendation is to keep the rubber bushes are they available to buy
Many thanks
Clive
post #4 of 14 (permalink) Old 21-03-2017, 08:22
Car: MGTF115 & Rover25 1.4
Last time I looked Rimmers listed the rubber bushes on their site.
Yes just checked.
david.c is offline
post #5 of 14 (permalink) Old 21-03-2017, 08:51
Woof Woof
Solid stainless steel for me. Fit and forget.
barkingdog is offline
post #6 of 14 (permalink) Old 21-03-2017, 13:05 Thread Starter
Yes just checked.
David,
just had a look at the rimmers site and they only have the complete units no separate bush, where did you find it???
Clive
post #7 of 14 (permalink) Old 21-03-2017, 14:43
Car: MGF VVC MK2
I would say that you can find some very good quality stainless steel, powder coated, solid mounts from our forum sponsor.
Not using myself, but around there are lots of positive comment on the added stiffness of solid, non rubberized mounts.
DeathFromAbove is offline
post #8 of 14 (permalink) Old 21-03-2017, 15:11
sundanceuk's Avatar
Car: MG TF 160
That's where I got mine from, available in red, blue or unpainted.
I would also ask for new bolts at the same time.
Good luck with fitting them, its easy if they come undone ok.
Sundance
sundanceuk is offline
post #9 of 14 (permalink) Old 21-03-2017, 17:48
The F mounts with rubber bushes do not tend to rust away like the TF ones, probably because the rubber bush stops water ingress, My 1996 F front mounts look like new, where as my 2003 TF (Original) looked like this when removed....got my nice shiny stainless mounts from mgmania, which cost 45.99 delivered this time last year for two....they have increased prices big time since though and are now 32.99 each :o
One other thing, the rubber bushed ones means you can usually remove the front wishbones without the need to drop the subframe completely, also; there is a slightly smother ride
dert is offline
post #10 of 14 (permalink) Old 21-03-2017, 19:07 Thread Starter
Is there not a reaction between the mild steel and the stainless?
post #11 of 14 (permalink) Old 21-03-2017, 20:20
Car: MG ZS180 :D
No. Alu and stainless react when together.
Sent from Drew @ Roverdose
Roverdose is offline
post #12 of 14 (permalink) Old 21-03-2017, 20:26
The MGF trophy and the TF achieved a more sporty feel by suspension tweeks including solid mounts, the standard MGF is more refined with the rubber bushed mounts.
I have never seen just the bush, although I guess you could make one.
post #13 of 14 (permalink) Old 22-03-2017, 00:10
Car: MGF VVC MK2
On the MGF and TF restoration manual, Parker says ghat rubber mounts seems to have promoted faster rusting.
Go figure who s right.
post #14 of 14 (permalink) Old 22-03-2017, 06:12 Thread Starter
My head hurts,
why can life not be simple
Another question for the real experts
Is it possible to align the subframe by by adjusting the large central bolts
ie: slacken the front right and tighten the rear right to turn the subframe
slightly???
or are they tightened to the end of the thread or to the steel inner??
Rear subframe front mounts will dig MGF and MGTF (Sponsored by MGFnTFBITZ) 8 30-04-2016 06:21
front subframe mounts,fitting? mansell333 MGF and MGTF (Sponsored by MGFnTFBITZ) 9 24-04-2015 07:08
Subframe mounts MGF Neil Surrey Lab MGF and MGTF (Sponsored by MGFnTFBITZ) 9 02-10-2014 12:27
Stainless Front Subframe Mounts Reaper MGF and MGTF (Sponsored by MGFnTFBITZ) 8 01-08-2014 11:20
front subframe and mounts tf bugsb MGF and MGTF (Sponsored by MGFnTFBITZ) 2 14-03-2013 16:45
