MGF/MGTF Speaker Upgrade - MG-Rover.org Forums
post #1 of 5 (permalink) Old 15-02-2017, 21:03 Thread Starter
Car: MGF VVC MK2
Hi all,
after so much time I've taken from the community, I think it is time to give a fraction back.
What follow is not a complete How-to, but more an extension to some very good existing guides out there.
[I'll try to provied pictures shortly]
Hope will be useful
Foundation
1. You need an MGF/TF with T-Bar (rear) spearks along discreet doors tweeters.
a. Not sure if any of the following is applicable to single door speakers.
2. Willing to do job yourself
What you need to buy
Follow a list of items I've bought and was a perfect fit:
1. Main door speaker
a. Cable adapater
NOTE: Don't biu cowl adaptors (I've done it), because probably they will not fit. Is better to re-use the original.
2. Door Tweeter
a. Cable adapter
b. Relaying on the original tweeters, with much better speakers, means having a very muddy and unclear sound, since the OEM can't match the uber-powerful new borthers
3. T-Bar (rear) speekers
4. Fire rated foam
5. J-Weld
6. Door clips
General Infos
* Door Cable adpaters: the doors speaker and tweeters have a special cable connectors. If you don't want to cut the original cable and juction it with ones coming with the speakers, the listed adaptors are a 0-hassle connection, even for future upgrades.
The good thing is they are quite water-tight and, since the leaking attitude of our cars, is a good thing.
* T-Bar speakers have no speacial adapter, they come with discreet +/- connector. No issue.
* Removing the door cards has proven disruptive for the bottom clips: they remained ... clipped to the metal frame.
With J-Weld I've litterally welded clips holder back to the door card, with much stiffer retention.
I've use a bit of the foam to keep the new clip in place.
This prooved quite good in the end: the doors are so tight on the metal frame that they don't vibrate even with very high volume.
STEPS!
1. CJJ Speaker replacement How-To
a. If door clips holder detach, read above
b. Use speaker cable adapter... and done!
c. Before putting the speakers on the door frame:
** For each speaker cut two strings of adhesive foam
** Attach first strip to the back of the cowl, that will press against the door frame
** Attach the second to the front of the cowl, that will got in contact with the door card
** This will hugely reduce vibration and will stiffen the door card aginst the speark (also eliminating chafing noise while driving)
d. Unscrew tweeter
c. Use tweeter cable adapter and... done!
e. Screw new tweeter in place!
d Connect cables!
2. T-Bar removal
a. removed the T-Bar unscrew the speakers from the boxes
b. Connect cables (no adpter needed)
c. Screw back speakers
Drive!
DeathFromAbove is offline
post #2 of 5 (permalink) Old 15-02-2017, 22:55
Mmmm. Speakers.
post #3 of 5 (permalink) Old 15-02-2017, 22:59
A discreet sub is good too. Nothing too big though.
Alpine Sub woofer fitting - How to
post #4 of 5 (permalink) Old 16-02-2017, 19:50
Yeah them Alpine under seat subs are awesome, I have one for sale
if anyone is after one.
ROVER-25X is offline
post #5 of 5 (permalink) Old 17-02-2017, 00:48
That's handy.
Mgf or mgtf alpine speaker upgrade nick1973 For Sale 7 13-01-2013 12:04
Need help with speaker upgrade AndyCroft1982 MG ZR / Rover 25, 200 & Streetwise 5 13-02-2010 18:26
speaker upgrade jbaker In-Car Audio, Entertainment, Sat Nav etc... 0 22-10-2009 17:30
speaker upgrade billo MGF and MGTF (Sponsored by MGFnTFBITZ) 2 04-04-2007 22:55
LED upgrade for MGF/MGTF MS quad lights Mr_Demon For Sale 3 10-08-2004 14:42
