MGF remote central locking - stopped working! - MG-Rover.org Forums
post #1 of 5 (permalink) Old 13-03-2006, 10:05 Thread Starter
Hello!
When I tried opening my 2000 MGF yesterday, I was unable to do so. Nothing happened when I pressed the button on the key fob.
I immediately assumed that the battery on the key fob had gone flat. I replaced it, but still nothing happened.
I looked inside the car, and could see that the red light was still flashing on the radio, so I assume the car battery isn't dead.
Does anyone have any idea what's the likeliest cause of this problem?
And is there any procedure for opening the car with the key - without the alarm going off and without it being immobilised?
Thanks very much,
Andrew
PimlicoMG is offline
post #2 of 5 (permalink) Old 13-03-2006, 10:09
Car: MR2 Roadster 2002
Send a message via MSN to Dean Carr
i believe you have to open the drivers door with key, then press the unlock button 4 - 8 times to reset it when youve changed the battery.
Dean Carr is offline
post #3 of 5 (permalink) Old 13-03-2006, 10:20
Car: 420 SDLi
Remove battery from fob.Hold each button down for 5 secs each.Replace battery.Unlock door with key(do not open).Press lock button at least 4 times.This will sync fob.Car should then lock/unlock with fob.
Fodenman is offline
post #4 of 5 (permalink) Old 13-03-2006, 12:25
or unlock the car with the key, MAKE the alrem go off, then turn it off with the alarm. shut the door, and lock with the remote. done.
smiddlewood is offline
post #5 of 5 (permalink) Old 04-05-2006, 19:03
I'm having the same problem.
I can lock the door using the remote but I can't unlock it. I tried resetting the fob as instructed above but no joy - I can still lock it but not unlock it.
I had the fob tested in a car shop and both the buttons were working.
Any ideas?
I've got a 98 (R Reg) MGF VVC.
Chris
caldridge1 is offline
Central locking just stopped working rover400i MG ZR / Rover 25, 200 & Streetwise 2 04-11-2008 17:19
216 Sli central locking & remote not working & cant open drivers door! help! Breezy 'R8' Rovers (aka Wedges!!) 5 06-03-2007 10:29
My remote central locking stopped working with both keys ? sie1uk MG ZT / Rover 75 (Sponsored by Rimmer Bros) 7 15-12-2006 21:43
Remote Central Locking Not Working dazzawhipple MG ZS / Rover 45 & 400 4 07-09-2006 22:42
