MGF Ride Height - MG-Rover.org Forums
post #1 of 7 (permalink) Old 26-01-2012, 20:45 Thread Starter
MGF Ride Height
After fitting my new alloys this evening i got the tape measure out and checked my ride height. I know i need to pump up the Hydragas but as it stands my rear is 30cm from centre of alloy to wheel arch and my front is 32cm. This is a good 5cm lower than it should be. Im not going to get chance to sort this for a week or so. If i drive my car as it is will it cause any potential damage or is it just a case of avoiding lumps and bumps? I read somewhere about the membranes in the hydragas cylinders my be damaged if its run too low?
moomoo is offline
post #2 of 7 (permalink) Old 26-01-2012, 20:49
Think before you type!
I would say that any damage that may occur, may already have occurred. I wouldn't think another week will make any difference one way or another.
IanMc is offline
post #3 of 7 (permalink) Old 26-01-2012, 23:00
You did'nt say what size wheels you put on, but if its 16" trophy or similar what should the height be?? With 15" it should be about 35cm or 350mm so if an inch is added thats 25mm or 2.5cm divided by 2 from centre hub thats 12.5mm or 1.2cm so the height should be 238mm or 23.8cm. Is this correct??
Hobby is offline
post #4 of 7 (permalink) Old 26-01-2012, 23:05 Thread Starter
Im running 16" 11 spoke alloys at the moment.
moomoo is offline
post #5 of 7 (permalink) Old 26-01-2012, 23:10
You measure from the centre Of the wheel to the arch so therefore the distance should be the same whatever the wheel size.
Benfinlayson is offline
post #6 of 7 (permalink) Old 26-01-2012, 23:15
THINK YOU ARE CORRECT !!!!!!
Hobby is offline
post #7 of 7 (permalink) Old 26-01-2012, 23:22
if the ride is low then they tyres will suffer - especially the inside edge - the ride height should be 368 +/- 10mm (IRRC) - as its axel center to arch lip the wheel size doesnt matter
Carl is offline
MGF Ride height Peitolm MGF and MGTF (Sponsored by MGFnTFBITZ) 18 23-11-2009 14:49
mgf ride height bmw4me MGF and MGTF (Sponsored by MGFnTFBITZ) 3 18-09-2009 15:30
What's your MGF ride height? richgould MGF and MGTF (Sponsored by MGFnTFBITZ) 6 05-07-2008 12:44
MGF ride height Christine MGF and MGTF (Sponsored by MGFnTFBITZ) 2 26-05-2008 17:44
