Mgf starting problem - MG-Rover.org Forums
  • 1 Post By Mikeadman
post #1 of 4 (permalink) Old 16-03-2017, 17:00 Thread Starter
Question Mgf starting problem
Hi i had a 1998 MGF given to me that would nt start had been standing for 2 years after it broke down i hooked up a battery and cranked it over it weakly fired but didnt start spoke to my uncle who has a garage he said to start with the simple stuff took out the spark plugs and gave them a quick clean checked the leads for cracks cleaned the distributer cap and checked for cracks cranked it over again and after a few minutes it spluttered into life it miss fired when reved but on tick over it was fine left it running for about 10 minutes still would nt rev propely then died on me it restarted again with a wimper but not for long,so carried on going to coil and crank sensor the sensor tested ok but cant find any info on the resistance for the coil does any body know what the reading should be?
Jamie Nockolds is offline
post #2 of 4 (permalink) Old 16-03-2017, 19:00
Car: 1971Triumph TR6, 2006Jaguar X Type 2.5 AWD, 2008 Volvo C70
Fresh fuel added old fuel will not help!
Mike
IanMc likes this.
Mikeadman is offline
post #3 of 4 (permalink) Old 16-03-2017, 19:26
Stuck in the 80's...
Any more news on how/why it broke down?
I would start by doing the folowing:
Change the rotor arm and dizzy cap.
Change the leads.
Change the plugs.
Change the fuel filter.
Check the air filter.
Check the timing.
Then see what you get.
Good luck.
IanMc is offline
post #4 of 4 (permalink) Old 19-03-2017, 11:45
If it has a dizzy and rotor arm, change them. They are a weak point.
Problem starting MGF Davy Crockett MGF and MGTF (Sponsored by MGFnTFBITZ) 15 11-01-2009 10:55
mgf starting problem kate s MGF and MGTF (Sponsored by MGFnTFBITZ) 11 15-09-2008 13:26
MGF starting problem LIVS MGF and MGTF (Sponsored by MGFnTFBITZ) 6 29-01-2006 21:37
97 mgf starting problem scooter04 MGF and MGTF (Sponsored by MGFnTFBITZ) 4 10-10-2005 08:25
MGF - Starting Problem DavidBP MGF and MGTF (Sponsored by MGFnTFBITZ) 2 05-08-2003 03:33
