MGF Ticking noise after cam belt change...HELP! - MG-Rover.org Forums
post #1 of 9 (permalink) Old 04-04-2003, 06:59 Thread Starter
Recently I had my MGF serviced at 60K. Servicing included, cam belts and tensioners change, HGF fix, water tank cap replaced, water pump change, suspension height adjustment, the lot. Ever since, the fist time I start up the engine from cold it makes a normal sound, but once it gets warm if you start it up again you here this rattling noise (coming from the engine) the moment it fires up. Also can hear this ticking/rattling noise between 2000 to 4000 revs roughly. Any ideas for possible causes from you experts please!
fuzzyHGF is offline
post #2 of 9 (permalink) Old 04-04-2003, 09:51
Car: Rover 100
where is the ticking coming from? is it near the fuel rail? if so its probaby the injectors, my old metro gti used to have tappy injectors....might be that!
5teve is offline
post #3 of 9 (permalink) Old 04-04-2003, 11:09 Thread Starter
Well, I've not spotted where the noise is coming from yet to tell you the truth. In any case it sounds rather difficult to me to be the injectors cause it started doing it after the cam belts change, plus that the car has only covered 60kKm, and as far as I know injectors dont fail so soon. One thing I could think of is loose belts, but I dont really know if this could be a valid case for my problem. Any ideas?
fuzzyHGF is offline
post #4 of 9 (permalink) Old 04-04-2003, 11:24
Stu
Stu's Avatar
Some injectors just tick, can be from new and does not mean they are failing.
What version of K series have you got?
Stu
Stu is offline
post #5 of 9 (permalink) Old 04-04-2003, 11:29
Car: Rover 100
yep they do just tick! my metro did 160k miles and they never failed, just tapped all the while but not irritatingly. you want to check that they have not left a loose bolt somewhere.... like rubbing against the belt!
5teve is offline
post #6 of 9 (permalink) Old 04-04-2003, 11:41 Thread Starter
Its an 1.8 VVC engine. Does the cam belt tensioner could be causing the rattling noise if was not properly fitted or I'm completely talking rubbish?!
fuzzyHGF is offline
post #7 of 9 (permalink) Old 05-04-2003, 08:39
Isnt this a common problem with the 1.8 VVC ? Something to do with the second cam.
Take it back to the dealer who did the work and get them to check it.
jon1800 is offline
post #8 of 9 (permalink) Old 07-04-2003, 09:30 Thread Starter
Common problem with the VVC...? With the 2nd cam...like what?
fuzzyHGF is offline
post #9 of 9 (permalink) Old 07-04-2003, 12:49
Stu
Stu's Avatar
Some VVC engines can have noisy mechanisms.
I would get it checked by the dealer. Ensure they changed and loctited the sprocket bolts as well as the cambelts. If these work loose, they will cause a lot of damage to the head.
Stu
Stu is offline
Cam Belt Change... **HugHesY** MG ZR / Rover 25, 200 & Streetwise 16 12-02-2008 00:44
cam belt change andymitton MG ZR / Rover 25, 200 & Streetwise 46 26-08-2007 12:39
How much for a Cam Belt Change I_Love_My_ZT MG ZT / Rover 75 (Sponsored by Rimmer Bros) 16 30-12-2006 15:09
MGF VVC Cam Belt Change BladeDude MGF and MGTF (Sponsored by MGFnTFBITZ) 4 15-05-2006 14:48
MGF VVC weird noise after cam belt change...HELP! fuzzyHGF MGF and MGTF (Sponsored by MGFnTFBITZ) 8 07-04-2003 20:45
