Mgf vvc 1.8 1997 - MG-Rover.org Forums
post #1 of 4 (permalink) Old 12-05-2011, 17:09 Thread Starter
Send a message via MSN to talkabouthorses
Mgf vvc 1.8 1997
hi i have brought a mgf rebuilt the engine and replaced loads of parts including brake disc pads and cat plus back box, she runs lovely, i have no however go a smell of fuel in the car i have checked all the pipes in engine and the smell seems worst when its been stood once you have doors open and closed and running the car it goes away a bit, been told there is a hose from fuel filler cap to tank that perrishes and causes smell in the interior does anyone have any ideas or has had same problem xx
talkabouthorses is offline
post #2 of 4 (permalink) Old 13-05-2011, 17:47
Car: 1996 mgf vvc
Lifted straight from Dieter's site:
- rework the rubber hose under the brown gaiter between tank and filler pipe if it's kinked
- change the cheap clamps at that rubberhose to jubilee clamps
- change the green coloured cheap clamp at the fueltank sender unit hose to a jubilee clamp
- check the large sealing of the sender unit (tank to sender body)
- check whether there is a non return 'flap' installed inside the filler pipes lower end.
- check the screws of the fuel tank cover plate behind the seats on the right torque. Screws should be tightened starting from the centre to the outer.
- remove the tank cover plate behind the seats and re-align the white coloured shredder between the tank and the cover plate.
- add a self adhesive foam tape if the existing sealing material is not placed right.
See here http://www.mgfcar.de/fueltank/index.htm for more info.
xboxdevil is offline
post #3 of 4 (permalink) Old 14-05-2011, 11:39 Thread Starter
you are a star will be doing list today, have ordered a new ruer hose that goes inside the gator just in case it has perrised not looking forward to taking the panel off from back of seats but never say i dont have a go lol ta muchly have a great weekend xx
post #4 of 4 (permalink) Old 14-05-2011, 11:46
Car: 1996 mgf vvc
Good luck, I hope you get it sorted :-)
cheap back box mgf vvc 1997 spidercrab Wanted 0 27-03-2011 22:34
1997 mgf with vvc engine COUGAR55 MGF and MGTF (Sponsored by MGFnTFBITZ) 6 26-03-2011 04:07
For Sale 1997 1.8i VVC MGF - Very Low Miles & Owners (1997) claire86 For Sale 3 01-02-2009 19:53
MGF VVC - 1997 R Reg Brooktop For Sale 1 29-03-2005 14:11
1997 Mgf 18 Vvc Greg-Richards MGF and MGTF (Sponsored by MGFnTFBITZ) 9 24-04-2004 22:13
