mgf vvc head gasket replacement - MG-Rover.org Forums
post #1 of 9 (permalink) Old 20-09-2006, 09:11 Thread Starter
Car: 98 MGF
My '98 VVC headgasket blew yesterday and I am considering a DIY replacement and would be grateful if anybody could answer the following.
1 Is there a definitive set of instructions listed anywhere?
2 Are special tools needed and are they available?
3 Much reading also suggests perhaps replacing the oil rail. Is this necessary and is it possible without taking the engine out.
4 There was no indication of overheating just some other symptoms over a few days that have ended in the failure. So, is it essntila to have the head skimmed. I understand that if so, removel of the VVC gear is very very tricky???
5 Anybody out there done it themselves?
Any other guidance and advice will be greatly appreciated
Regards Keir (In tears and seeking an overdraft)
mgfboy is offline
post #2 of 9 (permalink) Old 20-09-2006, 09:19
1. There are a few threads on this forum with DIY instructions do a search in the entire forum not just this section.
2. You will need a way of locking the cams but other then that I don’t think so.
3. If you fit the new LR gasket then the consensus is that the new oil rail should be fitted together with new main bolts and its possible to drop the sum institute. If you fit the MGR MK3 gasket then there is know need. The dowels should also be matched to the gasket and fitted correctly.
4. You will not know if the head needs skimming until you take it off.
post #3 of 9 (permalink) Old 20-09-2006, 09:31 Thread Starter
Car: 98 MGF
2. You will need a way of locking the cams but other then that I donít think so.
Thanks Chris, many search reults come up with fragmented info, I was hoping (cheeky?) for a complete guide thriough it.
I had followed many threads (including your own) and there doesn't seem to be consensus about using the LR gasket.??
Keir
mgfboy is offline
post #4 of 9 (permalink) Old 20-09-2006, 10:16
post #5 of 9 (permalink) Old 20-09-2006, 10:26 Thread Starter
Car: 98 MGF
Thanks Chris, i had seen this but wasn't sure if it related to a VVC (he says MPi)???
Head gaskets don't frighten me, it's the VVC bit that does!!
Keir
mgfboy is offline
post #6 of 9 (permalink) Old 20-09-2006, 11:57
Chris seems to have covered all the known bases Keir. Best of luck , just don't move them thar cams.
post #7 of 9 (permalink) Old 20-09-2006, 12:16 Thread Starter
Car: 98 MGF
Thanks Pete, do you know if the tools to lock the cams are available - or even absolutely necessary?
Keir
mgfboy is offline
post #8 of 9 (permalink) Old 20-09-2006, 13:26 Thread Starter
Car: 98 MGF
Keir
I know I'm talking to myself but this may come in useful for somebody. Draper do the rover cam locking tool. My local shop has it for £2.99!!!
Same thing is on ebay for £4.99 plus £1.50 p+p
Keir
mgfboy is offline
post #9 of 9 (permalink) Old 20-09-2006, 19:04
Car: MG Motor 2011 TF135
Keir
I've been away for a few days and can't read everything but ...
has somebody suggested changing the waterpump while you are in there? About £50 incl vat and saves taking the cambelt of again later.
Sprinter is offline
mgf vvc head gasket unimatrix1066 MGF and MGTF (Sponsored by MGFnTFBITZ) 8 06-10-2007 20:19
VVC Head Gasket Replacement LukeCarry MGF and MGTF (Sponsored by MGFnTFBITZ) 3 29-09-2007 20:29
Mgf Vvc Head Gasket Puzzle CEDARS MGF and MGTF (Sponsored by MGFnTFBITZ) 3 04-07-2007 18:01
mgf vvc head gasket replacement mgfboy MGF and MGTF (Sponsored by MGFnTFBITZ) 0 20-09-2006 09:13
25 VVC Head Gasket Replacement cost RickJ MG ZR / Rover 25, 200 & Streetwise 19 06-01-2006 10:44
