MGF wont start - MG-Rover.org Forums
  • 1 Post By IanMc
post #1 of 14 (permalink) Old 16-02-2017, 16:56 Thread Starter
Car: vw tiguan.+ Rover 45. 1.8 ixl.+ 216 gsi + Rover 100 Ascot SE 16v
Unhappy MGF wont start
Hi to all, we parked up the mgf at xmas, went to bring it out of hibernation and it wont start and alternator was siezed, so, fitted new alternator, new battery, new coil, new fob battery, checked fuel pump and fuel, checked for spark checked fuses, checked inertia switch and immobiliser seems to turn off when the jingle stops and finally checked cam belt and timing marks were all lined up as they should be, engine turns over fine but it wont fire up, we tried squirting easystart down its throat to no avail, didnt even kick
any ideas cos ive ran out of them cheers Andrew.
45 chatsworth is offline
post #2 of 14 (permalink) Old 16-02-2017, 17:00
So, does the starter kicks or not? If not maybe worth to check relays?
post #3 of 14 (permalink) Old 16-02-2017, 17:02 Thread Starter
starter seems fine turns over well
post #4 of 14 (permalink) Old 16-02-2017, 17:52
Woof Woof
If it won't show any signs of life with easy start, I'd be looking again at the ignition and also a compression test.
barkingdog is offline
post #5 of 14 (permalink) Old 16-02-2017, 19:22
As above, If its not starting squirting easystart into it you probably have an immobilizer problem as if there was any spark at all you'd have had it fire squirting easystart into it
dert is offline
post #6 of 14 (permalink) Old 16-02-2017, 20:01 Thread Starter
theres a good spark , doesnt make sense
post #7 of 14 (permalink) Old 16-02-2017, 22:01
Stuck in the 80's...
A good spark at each plug?
IanMc is offline
post #8 of 14 (permalink) Old 17-02-2017, 08:21 Thread Starter
Yes a good spark at each plug. after all the stuff weve checked and/or replaced theres gotta be something blatently obvious that staring us right in the face, ive gone to look for it.
post #9 of 14 (permalink) Old 17-02-2017, 13:29
Are the plugs wet with fuel?
IanMc is offline
post #10 of 14 (permalink) Old 17-02-2017, 15:28 Thread Starter
Yes there wet, its doin me head in now
post #11 of 14 (permalink) Old 17-02-2017, 15:48
Try holding the throttle open fully (foot flat to the floor) then turning it over for say 15-20 seconds continuously.
My thinking is maybe it is just flooded with fuel now.
Good luck.
barkingdog likes this.
IanMc is offline
post #12 of 14 (permalink) Old 17-02-2017, 19:02
Car: MGTF 160 And Mercedes SLK
If you have spark and fuel, the only things left are compression and timing.
Not sure how either could have changed, just being parked up
Whitwell.Mike is offline
post #13 of 14 (permalink) Old 17-02-2017, 19:10
Woof Woof
Dry them out put them back and pull the fuel pump fuse out. Now hold the throttle wide open and turn it over whilst someone sprays easy start down the throttle body. If it try's to fire shove the pump fuse in and see if it goes.
post #14 of 14 (permalink) Old 18-02-2017, 07:27
Do you have a distributor?
MGF Wont start. justin1984 MGF and MGTF (Sponsored by MGFnTFBITZ) 8 01-05-2012 22:20
MGF wont start, but able to bypass and start with starter motor. karl12345 MG / Rover Related Chat - up to 2005 0 14-10-2011 20:33
mgf 97 wont start DJMARK MGF and MGTF (Sponsored by MGFnTFBITZ) 16 19-12-2007 09:45
mgf wont start (please help) michael paice MGF and MGTF (Sponsored by MGFnTFBITZ) 8 29-10-2006 17:23
mgf wont start wwjoineryltd MGF and MGTF (Sponsored by MGFnTFBITZ) 1 28-07-2006 20:08
