Mgtf 2003 over heating - MG-Rover.org Forums
post #1 of 4 (permalink) Old 15-02-2013, 17:13 Thread Starter
Hi I have a MG TF 2003 cool blue, It started to over heat and was diagnosed with the dredded head gasket fault.....this was repaired (skimmed), new water pump, cam belt, thermostat and has had a co2 block test which has shown there is no issue with the head gasket.
My car is still over heating BUT it does not over heat everyday and it goes on the same journey (30 miles on motorway). My mechanic is now at a loss as to what could be the issue with it.
Please help or can anyone suggest a MG Rover mechanic near to Doncaster that could help.
sunnyside is offline
post #2 of 4 (permalink) Old 15-02-2013, 18:25
Did they fit a new coolant cap? If not then I would do so.
I do wonder if the thermostat was the correct one, 2003 was the change over from a conventional thermostat to one that also opens with pressure (known as PRT). It has been known for cars fitted with the later type to have the older type also fitted by well meaning but misguided garages.
The other thought is that there is still air in the coolant system, there are 3 bleed points and all need to be used.
post #3 of 4 (permalink) Old 18-03-2017, 19:38
over heating
air lock, head gasket, water leak, knackered head.
Stewart Bell is offline
post #4 of 4 (permalink) Old 18-03-2017, 20:10
Think before you type!
Sadly the OP is very unlikely to see your reply, he/she hasn't logged on since April 2013...
IanMc is offline
Mgtf 2003 agricola Cars For Sale 10 26-08-2012 16:23
2003 MGTF for sale Kimmieaa Cars For Sale 0 26-04-2011 10:57
rover 45 1995cc 2003 td heating williamcadger MG ZS / Rover 45 & 400 1 10-09-2010 20:57
MGTF - Over heating and water Boils deepea MGF and MGTF (Sponsored by MGFnTFBITZ) 7 14-04-2009 16:13
MGTF over heating nick_b2581 MGF and MGTF (Sponsored by MGFnTFBITZ) 11 26-10-2007 14:57
