mgtf 2003 starting problem - MG-Rover.org Forums
post #1 of 5 (permalink) Old 18-03-2017, 18:21 Thread Starter
hi can anyone advise me on how to fix an ignition problem I have, I turn the key and all the lights on the dash come on as should be when I try to start the car on the turn of the key nothing i did have a problem with the dash water gauge I found the problem was the engine wiring from the boot as this was rubbing on the harness could this be the problem again to the starter motor from the ignition any help please thanks in advance
graham8408 is offline
post #2 of 5 (permalink) Old 18-03-2017, 18:56
does the starting motor work
Stewart Bell is offline
post #3 of 5 (permalink) Old 18-03-2017, 19:19
Yeah could be a wiring problem, especially if your car has a history of them. Can you hear a relay click, or anything?
post #4 of 5 (permalink) Old 18-03-2017, 19:54
sundanceuk's Avatar
Car: MG TF 160
The starter motor is usually the culprit here sometimes the terminal connector can corrode away.
First place to check for sure!
Sundance
sundanceuk is offline
post #5 of 5 (permalink) Old 18-03-2017, 20:10
As Sundance says check the starter motor and connections. Also worth hitting the motor with a mallet, or the like, as they can develop spots where they stick.
Mgtf 2003 over heating sunnyside MGF and MGTF (Sponsored by MGFnTFBITZ) 3 18-03-2017 20:10
MGTF 2003 opinions please agricola MGF and MGTF (Sponsored by MGFnTFBITZ) 21 28-08-2012 21:47
Mgtf 2003 agricola Cars For Sale 10 26-08-2012 16:23
2003 MGTF for sale Kimmieaa Cars For Sale 0 26-04-2011 10:57
my 2003 mgtf 135 Deano For Sale 11 10-06-2010 20:48
