Noisy heater fan. - MG-Rover.org Forums
post #1 of 13 (permalink) Old 07-06-2011, 21:20 Thread Starter
Car: MG TF 135 in XPG
Noisy heater fan.
I got in the car today and started it up, the fan sounds as if it's making a 'swishing' noise. It changes the volume with the speeds 1-4. Doesn't sound like a leaf flapping about type noise. Where would be best to start looking? Something might of come loose after changing the dash and crap got in somewhere?
Really happened overnight, not make a noise until today.
Loaky is offline
post #2 of 13 (permalink) Old 07-06-2011, 22:32
Have you changed the resistor pack for ceramic resistors?
Chris T is online now
post #3 of 13 (permalink) Old 07-06-2011, 22:38 Thread Starter
I most certainly have, years ago, to fix the dead speeds / broken wires.
Loaky is offline
post #4 of 13 (permalink) Old 07-06-2011, 22:40
I've seen reports of the ceramic resistors touching the fan.
post #5 of 13 (permalink) Old 07-06-2011, 22:41
Car: MGF, Mercedes SLK, Renault clio, Honda VFR 800, SV 650s, Gs500, sr125, ybr125, 50cc, VW Polo,
When I did the heater matrix I did the fan resistors and stripped the fan casing at the same time.
There was all kinds of crap in there causing funny noises.
Worth a fan assembly out and looksee me thinks.
philmgf is offline
post #6 of 13 (permalink) Old 07-06-2011, 22:44
Send a message via MSN to hollinshead
I'd start by taking the fan motor out and having a look at it first?
It can be done without removing anything, you have to lay in some funny positions in the drivers foot well though!
It's located next to the clutch pedal, its black, kind of round with a plug going to it. It is held in by 3 screws, once you have undone them and unplugged it it should come out (you may find pressing the clutch down helps give you more room to get it out )
Once it's out try spinning it by hand and see if it makes a noise, you can also check there is nothing catching on it.
Mine was squeaking and I took it apart & sprayed it with WD40. (Don't tell Pete! )
Mine is now quiet as a mouse and it has been a good 7 months since I did mine.
hollinshead is offline
post #7 of 13 (permalink) Old 07-06-2011, 22:46 Thread Starter
They were big bulky things, I think that'd be the first thing to check, definitely sounds plausible, cheers!
Loaky is offline
post #8 of 13 (permalink) Old 07-06-2011, 22:47 Thread Starter
I'll investigate doing that if I draw a blank with Chris T's suggestion, thanks.
Loaky is offline
post #9 of 13 (permalink) Old 08-06-2011, 19:35 Thread Starter
In the end I decided to take the fan out, whoever said it was easy gets neg repped!
Well worst part was getting the top screw back in, I don't think i've ever been in such a bizarre position!
Anyway in the end I think it was a leaf in there, so all is well now! So thanks again guys!
Loaky is offline
post #10 of 13 (permalink) Old 08-06-2011, 19:42
I did say it involved some strange positions in the footwell?
post #11 of 13 (permalink) Old 08-06-2011, 19:51
...I don't think i've ever been in such a bizarre position!
What even more bizarre then in Pencelli 07?
post #12 of 13 (permalink) Old 08-06-2011, 19:58 Thread Starter
I can't remember what I was doing then, I hope no ones got photographic evidence!
Loaky is offline
post #13 of 13 (permalink) Old 08-06-2011, 20:07
Loaky goes off to get a super injunction...
Noisy fan belt Littlened MGF and MGTF (Sponsored by MGFnTFBITZ) 2 03-03-2011 09:43
Noisy fan square271 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 06-10-2009 14:43
noisy blower/heater fan 414 help tracy c MG ZS / Rover 45 & 400 7 25-03-2008 22:00
Noisy laptop fan tom_p_216si PC Gen Chat & Help 2 06-01-2008 08:47
Noisy Cooling Fan mike_kelsey MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 15-11-2005 08:29
