Odd alarm behaviour!! - MG-Rover.org Forums
post #1 of 10 (permalink) Old 19-08-2009, 13:35 Thread Starter
Car: Vectra 2.2 Design
Ive never had a prob with my mgfs alarm but for some reason today it decided to go off. Ran to car from work thinking someone breaking into my baby and there was nothing.
Reset it and two mins later it went off again!
Same again, reset, and 2 mins later it went off again.
So locked car with key only and decided to try wd40ing a few things such as locks and contact switches and also replaced the keyfob battery and then locked the car with the fob.
Now 10 mins on.....and fingers crossed.....its not gone off again, has anyone else experienced such weirdness???
smeagol_vvc is offline
post #2 of 10 (permalink) Old 19-08-2009, 13:46
Trader Supporter
Car: MGF, Alfa MITO, Volvo C70 and Maserati 3200GT 365bhp
maybe it's insects?
Iniside the car setting off the alarm.
TT MK7 exhausts for MGF and TF sold out next batch ordered. .
Neil Surrey Lab is offline
post #3 of 10 (permalink) Old 19-08-2009, 17:26
Car: MGF 1.8i
Yes. I have. Its damn annoying! Mine does exactly the same as yours and makes me look like an utter t*t running back and forth to turn my car alarm off.
Apparently it has something to do with a sensor in the T-Bar that if it gets moved (or something along those lines) it will just keep going off.. I don't think it does it if you use the key and not the fob!
I really need to know how to fix it!!
M14EY N is offline
post #4 of 10 (permalink) Old 19-08-2009, 18:07
I've been having the same problem. It only happened when i have been driving with the hood down. when i put it up, lock up the car, low and behold alarm goes off. Found the hood wasnt quite secured properly. What a dill
mg-kiwi is offline
post #5 of 10 (permalink) Old 19-08-2009, 19:59
Banned
Don't know if it's any help but my Blackberry is guarunteed to set the alarm off if I leave it in the car. Happens every time. I know it may sound optimistic but any chance you left your mobile in the car?
MG_CHIC is offline
post #6 of 10 (permalink) Old 19-08-2009, 20:07
Is it just blackberrys? I have left other fruit in the car with no problems.
post #7 of 10 (permalink) Old 19-08-2009, 20:10
You can have the sensitivity of the volumetric alarm adjusted on a testbook machine.
Things that can set off the volumetric alarm can be insects, thermal changes (sun coming up etc) and drafts (which can be down to vents open etc).
Other problems can be down to damaged wiring, faulty/worn micro switches in the locks and RF interference from external sources, such as CB radios/taxis etc.
post #8 of 10 (permalink) Old 19-08-2009, 20:31
Car: Tigger, MGF 1.8mpi 2001, ST Orange
Mine has a mind of its own too... Lock the car up one day fine, lock it up the same way another and off it goes!!
Mine is off to see a mate who can fix it!!!!
Teri is offline
post #9 of 10 (permalink) Old 19-08-2009, 20:35
Banned
Seem's to just be blackberry's at the momenet. I tested 5 different types of fruit in the control group and five different types in the test group. Using the results from this study I was able to conclude that there are more than ten fruits and therfore further analysis will be needed.
MG_CHIC is offline
post #10 of 10 (permalink) Old 19-08-2009, 20:44
Car: MGF 1.8 mpi Tahiti Blue
Send a message via MSN to Billy-Whizz
Had the same issue..... Lifted the bonnet and pushed the black plunge switch, top left corner facing car, in and out a few times. There was also a dry leaf in the vacinity but unsure what if any effect that had..... Anyhoo not had any problems since
Billy-Whizz is offline
Odd engine behaviour after starting rich_b Diesel Forum! 10 19-02-2008 06:29
Traffic Announcements - odd behaviour CD413 PCK121 In-Car Audio, Entertainment, Sat Nav etc... 0 10-11-2007 15:06
Odd behaviour! SteveChilds MGF and MGTF (Sponsored by MGFnTFBITZ) 17 25-07-2006 07:38
75 Tourer - odd tailgate behaviour - lock and wiper DickBrowne MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 23-04-2006 20:21
Rover 75 CDT reversing sensor odd behaviour Peter Maddern MG ZT / Rover 75 (Sponsored by Rimmer Bros) 6 07-12-2005 12:33
