Odd starting behaviour.. - MG-Rover.org Forums
post #1 of 10 (permalink) Old 22-10-2012, 11:00 Thread Starter
Hi all,
My 97 mgf vvc has been playing up recently.. it seems to be related to filling up with fuel, when I stop at a petrol station, fill up and try and start the engine, it just ticks over and over and never gets the fire. I leave it for a while, and try again and repeat and eventually (with fingers crossed) it starts. It has on occasion just refused to start though and its very embarrassing.
So far I have put it down to stopping to refuel because mainly I don't have any other reason to stop in a journey. In the mornings, it seems to start ok.
I have so far replaced the coils, taken off my Magnecor leads and cleaned the ends, taken out the sparks and cleaned them and tested they all spark fine. I have a new starter motor and the cut off fuel switch isn't an issue because it does on most occasions eventually start if I am lucky.
What else could it be?
Was running fine and then just like that this started happening.
timahole is offline
post #2 of 10 (permalink) Old 22-10-2012, 12:05
Car: Audi TT 225 Quatrro
How far are you running it before refuelling?
Jay13 PNTHR is offline
post #3 of 10 (permalink) Old 22-10-2012, 13:15 Thread Starter
An example, last night I made the trip from Portsmouth to London, stopped just past Guildford to refuel.
So about 40 miles, but I did a trip the other day which was less than 4 miles and same thing at the fueling station.
timahole is offline
post #4 of 10 (permalink) Old 23-10-2012, 14:25 Thread Starter
Where should I go next? Fuel filter change?
timahole is offline
post #5 of 10 (permalink) Old 23-10-2012, 14:53
Car: TF160
Another way to look at it is that it doesnt start when warm - in which case I'd start with the engine temp sensor, especially if all the other serviceable items are 'good'.
Rejected Takeoff is offline
post #6 of 10 (permalink) Old 24-10-2012, 10:58 Thread Starter
Hey Jason,
So is that the ambient air sensor you are referring to or the sensor that goes into the top of the engine?
Thanks for your reply.
timahole is offline
post #7 of 10 (permalink) Old 24-10-2012, 11:43
Car: TF160
It's the brown sensor (I think they are brown on your age of F) located on the exhaust manifold side of the head.
I know it's a common thing re hot start problems, especially if as you say, all the 'normal' service items are good.
post #8 of 10 (permalink) Old 24-10-2012, 11:47
Hobbyist
Car: MG TF 160, ZR 2.0 Diesel
Probably just me thinking like a mad man but have you tried doing a journey, then stopping engine, then restarting without taking the petrol cap off, see if it does the same? otherwise my thinking is that when you take to cap off, any fuel in the pump runs back to tank, it could be that the pump isnt priming properly hence why it takes a while to fire up?
Steve
COPPERKNOB is offline
post #9 of 10 (permalink) Old 24-10-2012, 13:31 Thread Starter
Thanks Jason I'll get that replaced and Steve yeah need to narrow down exactly whats going on here - I'll do as you suggest the next time I'm on a longer run, my worry is stopping and then the car not starting up again
Thanks both will report back.
timahole is offline
post #10 of 10 (permalink) Old 24-10-2012, 13:34
Hobbyist
There must be times where you pop to the shops for a minute, return to the car and try to start? what happens? if all ok then you've narrowed it down.
Do you use the same petrol station all the time? it may be possessed by the devil
FBH odd behaviour al_dente MG ZT / Rover 75 (Sponsored by Rimmer Bros) 16 06-12-2009 17:39
Odd transmission behaviour p_b82 Diesel Forum! 15 26-11-2009 19:41
Odd alarm behaviour!! smeagol_vvc MGF and MGTF (Sponsored by MGFnTFBITZ) 9 19-08-2009 20:44
Odd engine behaviour after starting rich_b Diesel Forum! 10 19-02-2008 06:29
Odd behaviour! SteveChilds MGF and MGTF (Sponsored by MGFnTFBITZ) 17 25-07-2006 07:38
