Panel Gaps/Shut Lines. (Pic heavy) - MG-Rover.org Forums
post #1 of 9 (permalink) Old 05-05-2007, 11:13 Thread Starter
Car: Honda S2000
As with most F/TF's some of the panel gaps and shut lines on my TF were less than perfect, so tackled a few of them this morning.
Worst was the top of the passenger door..... as you can see from the first picture the door is both 'out' and 'down' of the rear quater panel.
First job was to adjust the stricker plate (Below) via the 2 Torx bolts, this (in my case) allowed the plate to be moved 'Up and in' to bring the door shut something like in line..
Next, to get the door flush both top and bottom with the bodywork I adjusted the 2 rubber door 'stops' on the inner door frame (the 2 black bungs top and bottom in the picture) these stops just wind in and out by hand to fine tune the shut line.
Finished..... still not 100% perfect but is a big improvement over before, and also as the rubber adjusters are now tight against the bodywork, 1 less door rattle to worry about!.
Mark.L is offline
post #2 of 9 (permalink) Old 05-05-2007, 11:27
Car: MG TF 135 in XPG
Excellent! I keep meaning to look at my doors, I think they're almost the right height, they just sit a bit proud when shut.
Loaky is offline
post #3 of 9 (permalink) Old 05-05-2007, 11:58
Pip
Send a message via MSN to Pip
What is it about the passenger door, that so many are out? I keep meaning to do mine, but never quite get around to it.
Pip is offline
post #4 of 9 (permalink) Old 06-05-2007, 10:02 Thread Starter
Car: Honda S2000
Will only take you a few minutes Loaky if you have the Torx bit, just move the striker plate in a touch and adjust the stops to suit!.
Mark.L is offline
post #5 of 9 (permalink) Old 06-05-2007, 10:03
Might have to have a go today or tomorrow, got some Torx bits too from when I had the numper off.
Loaky is offline
post #6 of 9 (permalink) Old 06-05-2007, 10:44
Good luck Jon, don't break your hands
Herbie is offline
post #7 of 9 (permalink) Old 06-05-2007, 10:45
More worried about breaking the car Herbs!
Loaky is offline
post #8 of 9 (permalink) Old 06-05-2007, 10:47
.... my neighbours just wondered about the loud laughter
Herbie is offline
post #9 of 9 (permalink) Old 06-05-2007, 12:29
Just had a bosh at mine, the top now sits alright, adjusting the striker plate, though i'll have to look at those bungs I think as it still hangs out at the bottom of the door.
Loaky is offline
Front Bumper panel gaps on facelift Mel75 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 5 20-07-2006 20:42
Frontal bonnet shut lines aries9456 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 28-05-2006 00:47
R75 bonnet shut lines maxi_crawf MG ZT / Rover 75 (Sponsored by Rimmer Bros) 10 06-04-2006 19:08
Panel Gaps! Karni MG / Rover Related Chat - up to 2005 30 01-03-2005 17:07
Panel gaps king arthur MG / Rover Related Chat - up to 2005 11 03-06-2004 23:53
