Parking Sensors - MG-Rover.org Forums
post #1 of 9 (permalink) Old 22-06-2011, 12:06 Thread Starter
Parking Sensors
Ive jsut fitted parking sensors to the F (strange thing to do on car with only 3 wheels on and that wont start but ive done it ) only thing I have left to do is connect the power feed but I dont know which wire is reverse
So question is - Which colour wire in the rear cluster is Reverse and which one is earth ?
Carl is offline
post #2 of 9 (permalink) Old 22-06-2011, 15:16 Thread Starter
has no one else fitted sensors to an F / TF - is it just me that cant drive
Carl is offline
post #3 of 9 (permalink) Old 22-06-2011, 15:42
Car: TF135, MG3, MG6 GT TSE
They are fitted and working well on my TF - using a meter, I found which reversing light wire came live when the gear lever was put in reverse (with the ignition switched on, of course).
It was a bit more fun routing the wiring to the display from the boot to the base of the windscreen.
MRL
G0MRL is offline
post #4 of 9 (permalink) Old 22-06-2011, 15:44
Not sure of the colours but if you have a test lamp put the car in reverse with ignition on and probe the multi plug on the rear lamp till it lights up, put back to neutral and check it goes out to confirm you have the right wire, as for an earth anywhere on the body is fine I usually use one of the rear lamp fixing bolts.
Paul
Beat me to it!
PaulTF is offline
post #5 of 9 (permalink) Old 22-06-2011, 17:14 Thread Starter
I can earth to the body was gonna use the earth from the light ,
Ill have a stab round with the meter with it in reverse
Carl is offline
post #6 of 9 (permalink) Old 22-06-2011, 17:18
I have fitted them to my van, but for me, the TF has never been a problem reversing/parking even with the hood up.
post #7 of 9 (permalink) Old 22-06-2011, 17:21
Car: -
Green wire with brown stripe.
BLMC is offline
post #8 of 9 (permalink) Old 22-06-2011, 17:29 Thread Starter
promote that man to captain !
Thanks mate
Carl is offline
post #9 of 9 (permalink) Old 22-06-2011, 17:59
Car: MG TF 135, Citroen Picasso
I did a howto on them a few months back on a TF, as roverman says, it the green/brown wire.
Sorry didn't reply earlier but I've just come in from work
bandk is offline
Parking Sensors Rosses85 MGF and MGTF (Sponsored by MGFnTFBITZ) 4 05-10-2009 09:09
Parking sensors plisken MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 17-08-2009 15:33
Parking sensors will-w MG ZR / Rover 25, 200 & Streetwise 4 08-08-2009 00:58
Parking Sensors superdx MG ZT / Rover 75 (Sponsored by Rimmer Bros) 1 20-08-2005 18:01
