Pre 2000 Diagnostics - Page 3 - MG-Rover.org Forums
post #41 of 237 (permalink) Old 07-02-2012, 22:31
Originally Posted by technozen View Post
I initially used the OBD cable that came with the unit and had live data with it from my MEMS2J 200VI and a MEMS1.9 Rover 400.
I then made up a lead for 5AS programming and decided to add a switch which allows me to use one lead for MEMS and 5AS, this lead gave me live data on MEMS1.9/2J/3.
Since the weekend I have had live data on a Jag XK8, Vauxhall Astra, Rover 25 and an MGF.
Thanks i'll try the OBD cable for live data,
what are you switching to be able to do that???
Mgwanderer is offline
post #42 of 237 (permalink) Old 07-02-2012, 22:50
Mmmm....Rover..
technozen's Avatar
The 5AS uses two data lines, a separate IN and OUT. On the diagnostic connector these are pins 3 and 1.
MEMS uses a single bi-directional line on Pin 7.
Pin 3 and Pin 7 end up at the same pin on the DB25 connector at the T300 so the switch simply connects the correct one depending on what the lead is being used for.
technozen is offline
post #43 of 237 (permalink) Old 07-02-2012, 23:15
Many thanks, I will try to mod my lead and see what the results are on my unit.
I will let you know the outcome
Once again many thanks
post #44 of 237 (permalink) Old 08-02-2012, 01:43
I have a Faultmate diagnostic system made by Blackbox Solutions. It does most everything Rover's Testbook does. You only buy the software you need for your application and it is suitable for just about every MG-Rover vehicle. It works very well on my early MGF with it's MEMS 1.9.
http://www.blackbox-solutions.com/products.html
(Not the easiest site to navigate FYI)
RichinVancouver is offline
post #45 of 237 (permalink) Old 11-02-2012, 20:26
Car: MGF 1.8 16v 1998
Send a message via MSN to Mattlav Send a message via Skype™ to Mattlav
Just looked i have one connection and a small lead.. so MEMS 1.9? anything i can do/get that isnt too expensive?
Mattlav is offline
post #46 of 237 (permalink) Old 20-02-2012, 11:54
I received my T300 unit last week.
Cabled it up and it all works. Cleared all fault data (all historic and in relation to high voltages at various sensors plus one low battery).
Also reads live data. Good value for what it does and came in case.
I have a MEMS 2J.
Julian Foulger is offline
post #47 of 237 (permalink) Old 29-02-2012, 13:10
Send a message via MSN to nikolas
is it possible to shoot a video on the use of the tool??
or is it so easy to use..??
also, what is the case with this cable..?? http://themgclub.org/showthread.php?p=4115101
nikolas is offline
post #48 of 237 (permalink) Old 29-02-2012, 14:24
It is very easy to use. No problem at all and very interesting (especially the live data function).
post #49 of 237 (permalink) Old 29-02-2012, 16:51
i m looking forward to receiving mine..
all necessary equipment is included, right..??
nikolas is offline
post #50 of 237 (permalink) Old 29-02-2012, 17:26
Car: MGF VVC, ZS 135+, Toyota RAV4
Me too
Jason F VVC is offline
post #51 of 237 (permalink) Old 29-02-2012, 18:25
For accessing main ECU - yes.
For recoding the alarm / Fob you need to buy a 5AS cable off EBAY. Not expensive.
post #52 of 237 (permalink) Old 04-03-2012, 15:22
Car: MG ZR160
does this work with diesels?
Popeye 89 is offline
post #53 of 237 (permalink) Old 04-03-2012, 16:24
Definitely be interested in one of these - seems like a very useful bit of kit considering i need to get a fob programmed anyway!
Do yo think it would work on a 1998 Range Rover too?
adamelphick is offline
post #54 of 237 (permalink) Old 04-03-2012, 16:33
I suspect it does as RR is LR and that is on the list of manufacturers the kit deals with.
post #55 of 237 (permalink) Old 04-03-2012, 16:59
Great news as keeping the Landy going on a severe budget is not so easy! I don't want to get rid of it as it was my dads before he died so it's got sentimental value (and actually a great car too).
post #56 of 237 (permalink) Old 08-03-2012, 21:38
Got mine today, so far used it on the 'F' ( Mems 2J ) used it to clear historic faults, and I can confirm it WILL talk to the ecu.
post #57 of 237 (permalink) Old 08-03-2012, 22:14
Mmmm....Rover..
technozen's Avatar
This might be of some use as regards key fob programming...
http://roy.duitman.nl/Rover_Manual.pdf
post #58 of 237 (permalink) Old 14-03-2012, 15:17
am i doing sth wrong, or mine is faulty../?
do you have a rover specific plug or you use the obd2 one?
mine doesn't have rover specific plug..i connected obd2, never started..
i then tsted it on familys Polo it blinked for a while, then it started..seemed.. ok..
i unplugged it, and replugged it to confirm that it would start again, but it wouldn't start..
shall i think of replacing it??
nikolas is offline
post #59 of 237 (permalink) Old 14-03-2012, 17:26
You use the OBD2 one even for OBD1 cars.
Worked fine on mine first time. Plug in first and then turn on ignition to 2 for historic faults or 3 (ie start) for live data.
Make sure plug fully in both ends. There is a right way up.
post #60 of 237 (permalink) Old 14-03-2012, 20:23
it worked only one time on family's Polo,
and never turned on since then..
also the only time that turned on, the screen blinked for a while, which didnt seem normal..
either there is problem with the wires, or with the tool itself..
nikolas is offline
= pre 2000 mg exhaust adaptor + exhaust gaskets + fuel filter = super_cds For Sale 1 09-06-2011 20:12
= mgf cat - downpipe - pre 2000 exhaust adaptor - exhaust rubbers - gaskets = super_cds For Sale 1 29-08-2010 16:59
2000 Rover 45 1.8 Connoisseur VS 2000 BMW 318i saloon Rover_King Other Motoring Chat 30 04-02-2010 15:39
Diagnostics on a 2000 25 TheBoy MG ZR / Rover 25, 200 & Streetwise 1 10-07-2009 19:11
Pre-pre FandM meet? ANDYJ_ZR Scotland 165 09-05-2006 17:42
