Rear Hydrogas spheres - MG-Rover.org Forums
post #1 of 7 (permalink) Old 20-10-2016, 16:03 Thread Starter
Lightbulb Rear Hydrogas spheres
Hi there,
I have read that you can substitute Metro front spheres on the mgf rear as long as you change both rears???
Has anybody tried this and is it true ???
Many thanks in advance
Clive
Mgwanderer is offline
post #2 of 7 (permalink) Old 20-10-2016, 16:13
Originally Posted by Mgwanderer View Post
Hi there,
Clive
There are reasons why I would not do this:
1. Age of the Metro spheres
2. Different ride characteristics
ie:
MGF (368mm as per factory specs - unlowered)
Metro 1980 - 1990 (12 7/8")
Metro 1990 onwards (341mm)
3. Under 2. above, I would change all 4 to Metro
4. Why would you want to do this on basis MGF (non Trophy) spheres are still readily available (albeit second hand)?
Julian Foulger is offline
post #3 of 7 (permalink) Old 20-10-2016, 17:38 Thread Starter
Julian,
thanks for that info, but the reason is that there are still some new metro spheres available while the MGF units are all second hand. The fact that there is a difference in ride heights of 17mm makes me think a little but, I am informed that they can only replace the rears which is already lower than the fronts in the F's ride stats (not by 17mm though). As the "F" uses the metro's front subframe on the rear I thought it would be a possibility. I think I need to look into this possibility a little more deeply..
Clive
ie:
post #4 of 7 (permalink) Old 20-10-2016, 17:45
Car: MGF VVC MK2
Clive
Is CJJ testing our knowledge...
DeathFromAbove is offline
post #5 of 7 (permalink) Old 20-10-2016, 20:19 Thread Starter
That's the other Clive
The Clever one
post #6 of 7 (permalink) Old 21-10-2016, 17:32
Car: MGF + ZR
they will still have lost some gas due to the age.
just get 2nd hand f ones
you can then send them away to be pressure tested and re-gassed before fitting
link:
http://www.ebay.co.uk/itm/Hydragas-U...8AAOSwuMFUaQqc
super_cds is offline
post #7 of 7 (permalink) Old 26-10-2016, 11:33
Clive,
I have some rear spheres off a 1998 MG F if you're interested. They were perfectly OK when I took them out. Would you be interested? Postage to Belgium might be prohibitive though.
Nick
Nick Malpass is offline
MGF Hydrogas Spheres Hobby MGF and MGTF (Sponsored by MGFnTFBITZ) 2 05-02-2014 23:37
Are MGF hydrogas Spheres compaitable with 111 sl sambomonkee MGF and MGTF (Sponsored by MGFnTFBITZ) 1 07-11-2011 09:28
dropping hydrogas spheres whilst still connected markw19 MGF and MGTF (Sponsored by MGFnTFBITZ) 3 29-10-2009 18:43
rear hydrogas spheres steve1951 MGF and MGTF (Sponsored by MGFnTFBITZ) 3 21-10-2009 22:17
