Rear subframe front mounts - MG-Rover.org Forums
 3Likes
  • 2 Post By nocturneblue
  • 1 Post By Roverlike
post #1 of 9 (permalink) Old 28-06-2014, 06:49 Thread Starter
Quick question
Can I change the front mount on the rear subframe without dropping the engine / subframe?
Many thanks
will dig is offline
post #2 of 9 (permalink) Old 28-06-2014, 06:52
Car: Modified death trap
No...
Because you can't get to the inside to hold the bolt..
You'll have to lower the subframe 2-3"
Dieseldestroyer is offline
post #3 of 9 (permalink) Old 28-06-2014, 06:57 Thread Starter
cheers Allan, I assume a hoist to hold the engine would be the best way?
will dig is offline
post #4 of 9 (permalink) Old 28-06-2014, 07:35
Car: MGF 1.8mpi, Subaru Legacy 3.0, Audi TT TFSI
Hi Allan / Will,
Did I not read somewhere where someone on the forum used an angle grinder to remove said offending bolt and then replaced it with a new one, without lowering the subframe.
Exactly how he held it to tighten it up I don't know, if I remember he turned the bolt around I think.
Just surmising
Tone
Uncletone1 is offline
post #5 of 9 (permalink) Old 28-06-2014, 08:06
Car: MGTF 115 Sunstorm/Rover 45 Spirit/1977 Scimitar SE6A 3000V6/Saab 93t convertible.
It still won't come out, it will hit the body as the bolt is so long.The whole thing is set up into a shaped recess above the floor pan,which means the body has to be lifted off.Its easier to lift the body with a jack either side,and wooden planks against the floor pan,using holes drilled in it not to crush floor fixings.The callipers have to come off,as do the exhaust,heat shield,A/R bar bolts.Its similar to the front,but you have the engine weight on the frame when lifting,so make sure all is supported,and safe.All the bolts snapped on mine,not to be negative,and I have drilled 3mm holes into the body mountings,so I can now fill the hollow area the bolts/threaded plates sit in,with waxoyl.before waxoyling the whole area after.
rob dunster is offline
post #6 of 9 (permalink) Old 28-06-2014, 10:43
Andy I'd go for holding engine and box in place using crane (if possible) and just drop the subframe 3"
Would save a lot of work if the engine etc stays in roughly same place
post #7 of 9 (permalink) Old 28-06-2014, 11:33
On the TF, it is quite easy to change the front of rear-subframe mounts without dropping the subframe.
Leave one front mount on and work on the other one - this keeps the subframe in position. I took the weight of the car on the side I was working on at the back of the subframe - and also at the sill jacking point wuth an axle stand there. The reason for this, is that you want the subframe to drop a fraction when you take out the two bolts holding the flanges in, to increase access to the bolthead inside the mount. It doesn't drop much, but even a half inch helps. So, my advice is not to support the subframe at the front on that side, so it twists slightly lower when those two flange bolts come out (these are prone to snapping btw - get yourself a set of cobalt HSSG drills).
The problems are that there is little space to get a socket into the front mount to hold the bolthead, and the bolt is too long to come out even if you do get the nut off, as the bolt trikes the chassis in front.
These are not fatal problems. A 1/2" drive socket will get into the mount if you have taken the flange bolts out and supported it like I said. It's a bit of a jostle to get it in, but it will go in.
The next problem is that the bolt is loctited and the torque to get it off is huge. I jest not. Heat it up. Do not try and remove it cold. If you get it hot enough to boil spit it'll undo wth ease.
The final problem is that the long bolt running through the centre won't come out as the head strikes the chassis. Simply angle grind the end off a few threads out from the nut before you start. This is enough to allow it to come out and you can reuse it too in reassembly if you like.
On reassembly, you can either reuse the shortened bolt, or cut the new one down to the same length, or use a full length one but put it in backwards* - so the nut is inside the mount, instead of the head. This allows the bolt to be withdrawn backwards where there is plenty of clearance, as opposed to forwards like before, where there is none.
(*didn't try this, but I don't see why it wouldn't work).
I have used this technique on both my rear subframe front mounts and there is no difference between the sides. Do one side at a time so there is always one front mount in position. If your front mounts are very corroded you might want to support the subframe on the side you are not working on as well as the remaining front mount will suffer additional loading when you remove the other.
General arrangement of axle stands on the n/s. It's up to you to make sure your arrangement is safe and suitable.
Left - old front mount and long bolt with the end angle ground off to allow it to be removed. Right, shiny shiny new front mount and yet-to-be shortened new bolt. Could have resued the old bolt frankly, it was in very good condition, having been screwlocked.
The obligatory snapped flange bolt (right). Get yourself a decent HSSG drill to deal with this. It is hard to get this particular bolt drilled out though - the sill interefers. I drilled a pilot hole with a mini-dremel with flexible extension shaft, which has a small enough diameter to not foul the sill. Then I used bigger drill to open out the pilot hole. This fouled the sill and went in at an angle, but the piloy hole seemed to keep it on track. Choose your final drill size carefully to avoid losing threads - it is something like a 7 or 7.5mm, but check.
Note that although there appears to be an axle stand supporting the front of the subframe in the picture below, it was just belt and braces - there is clearance between the top of the axle stand and the subframe. I didn't know at first how far the rear subframe would drop when unsupported on one side so wasn't taking any chances. Not far at all, as it turned out.
Now here is a confusing photo - at the time I took YYG10005A bolts out of the two flange holes. Consulting the exploded diagram in Rimmer Bros I saw that in fact they should be the self-tapping (helical groove up through the threads) KYP100002(L) bolts. I bought these and they were useless. They wouldn't tighten - they stripped their thread near the head of the bolt. So, I went back to using ordinary bolts at this point, but it looks like the YYG's are in fact correct, although not as shown on the general assemly drawings. I have no idea what is going on there.
See, I told you you can get a 1/2" drive ratchet in there - note you can see the socket because the front mount has a huge rust hole in it.
Injecting Dinitrol ML cavity wax - pretty much everywhere, but in this case in the cavity behind the front mount flange mounting threads.
The finished n/s front mount - using new but cut-down bolt.
View of the painted rear subframe - I did this before refitting the front mounts, so I could paint around the front mount area. Note in the top left of the picture, the rotted engine air induction hose just visible. I removed it and repaired it with a double wrap of duct tape, as duct tape seems to survive everything...
HTH.
Bobert and sundanceuk like this.
Last edited by nocturneblue; 28-06-2014 at 20:20. Reason: ADDITION & corrected 'nut' to 'bolthead' & photos
nocturneblue is offline
post #8 of 9 (permalink) Old 29-04-2016, 19:39
sundanceuk's Avatar
Car: MG TF 160
I have just ressurected this thread, its well useful as I am going to replace these mounts, also now its back to the top of the thread list for a while and I can find it easier!
Thanks to Nocturn for this extremely useful info...Admin, could this be dropped into the how to section? I am sure I am not the only one who needs to refer to this in the near future!
Sundance
sundanceuk is offline
post #9 of 9 (permalink) Old 30-04-2016, 06:21
I put it into How to thread of MGF/TF: ***Hints and Tips, F/TF How-to Guides & TYRE GUIDE*** under "How to remove the rear subframe front mounts"
sundanceuk likes this.
Roverlike is online now
rear,front subframe mounts,lots of fun. rob dunster MGF and MGTF (Sponsored by MGFnTFBITZ) 1 05-05-2014 08:08
front subframe and mounts tf bugsb MGF and MGTF (Sponsored by MGFnTFBITZ) 2 14-03-2013 16:45
rear subframe / front subframe Jaffacakekilla MGF and MGTF (Sponsored by MGFnTFBITZ) 7 02-09-2012 20:55
changing rear subframe mounts Jaffacakekilla MGF and MGTF (Sponsored by MGFnTFBITZ) 0 11-06-2011 08:24
NAM9017 bushes and rear subframe mounts Jaffacakekilla MGF and MGTF (Sponsored by MGFnTFBITZ) 3 08-06-2011 21:47
