Refurbishing Alloys - Page 2 - MG-Rover.org Forums
 9Likes
post #21 of 46 (permalink) Old 08-01-2017, 19:58 Thread Starter
Car: Trophy
Originally Posted by JT Dent View Post
Depends what paint you have used.If the paint is too soft when you try to flat them off theres a chance of lifting the paint.Once the paint has gone off they will flat without problem.I wouldnt rush to deal with them if they arnt too noticable.They can be dealt with at any time in the future if they bug you.The longer they are left the harder the paint and will take slightly more work to buff back but longer is safer.
Thanks. I've gone for a second coat for now and I'll see what they're like in the daylight.
I suspect I'll let it go as you really have to be looking for it to spot it.
Mikey07 is offline
post #22 of 46 (permalink) Old 09-01-2017, 10:15 Thread Starter
Car: Trophy
All looks good this morning so I'm going to go with it as is.
I'm not happy with the condition of the centre caps so I've just ordered up a new set......
MGF Trophy 160 Alloy Wheel Centre Caps - MG Mania Ltd
Mikey07 is offline
post #23 of 46 (permalink) Old 10-01-2017, 11:03 Thread Starter
Car: Trophy
The first wheel is back on but as I'm still waiting for new centre caps to arrive it's not quite finished yet.
In the meantime I've taken off one of the front wheels and will start on that. I'd like to clean up the red brake calipers, will soap and water be enough to do that or should I use something else? I suspect it's never been cleaned!
Mikey07 is offline
post #24 of 46 (permalink) Old 10-01-2017, 11:50
Think before you type!
Get yourself some spray brake cleaner and give the calipers a good squirt of that. This will remove the most stubborn dust and crud. If you want to follow up with soapy water afterwards this will help wash away the gunk.
Good luck.
DocMark likes this.
IanMc is online now
post #25 of 46 (permalink) Old 10-01-2017, 18:22 Thread Starter
Car: Trophy
Good luck.
Will do, thanks.
Mikey07 is offline
post #26 of 46 (permalink) Old 10-01-2017, 22:39
Speaking about the budges, is there anything out there that won't just melt after the second car wash?
nick1981 is offline
post #27 of 46 (permalink) Old 13-01-2017, 13:19
Car: FunBuggy
Originally Posted by Incony View Post
i am going to point out.. that the external wheel condition, is probably less important than whats going on - on the things you cant see.. and that excludes all the finishing and remaking of the wheel external parts.. and focuses on what keeps the tyre inflated and what might change that, regardless of how many hours and finishes one applies to the bits one can see to make the wheel really not what it might be... it just looks good..
the inside of the ally wheel rim, and how the tyre seals to that.. the valve and its condition , is far more important than the shiny shiny paint that gets stone chips..
not least because structural defects in the wheel, caused by shock loading, like potholes for example. deform and degrade the structure of the alloy.. in the parts one cant see..
a deflation failure might kill you, and others ... and will be caused by a fault in the ally, or the valve or the tyre.. nothing at all to do with how shiny the wheel looks..
**** looking wheels could well be safer to use than shiny shiny ones... its down to the application of knowledge... so learn some. i think.
And I thought I was a half empty glass type of guy, I'm a ray of sunshine compared with you.
roobs likes this.
Phaeton is offline
post #28 of 46 (permalink) Old 14-01-2017, 09:59 Thread Starter
Car: Trophy
Wheel No.2 is nearly done. I gave it its last spray of paint this morning and it'll get lacquer tomorrow before going back on.
In the meantime I've replaced the centre caps with new ones from mgmanialtd. I originally ordered black and silver badges from their ebay shop but when I got them and checked their website I noticed that they also have black and yellow ones. They were good enough to let me exchange them and I think they go well with the car.
You can see from the first pic why I gave up on the previous caps!
roobs, IanMc and Mikeadman like this.
Mikey07 is offline
post #29 of 46 (permalink) Old 14-01-2017, 13:34 Thread Starter
Car: Trophy
I'm having trouble getting the first cap on. I've measured it and it's the right size but it aint going in.
Is there a particular way to do it or is it just a case of lining it up and giving it a good shove?
The wheel is on the car but I'll take it off again if need be.
Mikey07 is offline
post #30 of 46 (permalink) Old 14-01-2017, 13:41
Car: 1971Triumph TR6, 2006Jaguar X Type 2.5 AWD, 2008 Volvo C70
Are the caps identical to the old ones?
When I replaced mine I had to dremel some plastic off to get them to fit.
Mike.
Mikeadman is offline
post #31 of 46 (permalink) Old 14-01-2017, 14:11 Thread Starter
Car: Trophy
There is a difference in the size of the clip right enough. I'll get filing!
Cheers.
Mikey07 is offline
post #32 of 46 (permalink) Old 14-01-2017, 16:12 Thread Starter
Car: Trophy
Got it in but it took a fair bit of filing. It needed taken down all the way round.
3 more to file now...........
Mikey07 is offline
post #33 of 46 (permalink) Old 15-01-2017, 13:50 Thread Starter
Car: Trophy
Second wheel done. The picture doesn't do the badge justice, it's more yellow than that.
Mikey07 is offline
post #34 of 46 (permalink) Old 15-01-2017, 17:00
Looking good.
Mike
post #35 of 46 (permalink) Old 15-01-2017, 17:10
Car: FunBuggy
Looking good, I'll have those & I'll send you mine up
Phaeton is offline
post #36 of 46 (permalink) Old 15-01-2017, 17:46
sundanceuk's Avatar
Car: MG TF 160
When I did my calipers, I removed them and split them (AP 4 pot's) then used a rotary wire brush to get them back to shiny bare alloy. I replaced the two bolts that bolt the caliper halves together and also polished up the bleed nipples and connecting pipe between the two halves. Finally I scraped the paint away from the MG logo. They came up a treat. I did the rear calipers the same way.
My only concern when painting the wheels with rattle cans is that the paint is a lot easier to chip than the powder coat that the professionals use and it wouldn't surprise me if when changing the tyre you may get the rims chipping.
Anyway, looking good!
Sundance
Mikey07 likes this.
sundanceuk is offline
post #37 of 46 (permalink) Old 15-01-2017, 18:18
Sundance
Wow they look cracking what paint did you use?
Mike
post #38 of 46 (permalink) Old 15-01-2017, 21:30
the wheel badge is wrong as its not round
looks like they are hex shape for the 16" tf wheels
looks like you have a f trophy wheel
badge should be like this
http://www.ebay.co.uk/itm/4x-55-mm-f...oAAMXQVD1SKzFf
obviously in yellow and black not silver and black
there is a chap on here who does the badges
you can get front / back + steering wheel + wheels too in any colour of your choice
his user name is: dazzer75
these seem cheap
20 a re-furb or 30 with tyre if your in bham
https://www.citypowdercoaters.co.uk/price-list
super_cds is offline
post #39 of 46 (permalink) Old 15-01-2017, 21:53
sundanceuk's Avatar
Car: MG TF 160
Mike
I used Beckers in a rattle can. Its very hardwearing and stands up to heat well. Just have to make sure you clean any brake fluid off after bleeding the brakes. I fitted new wear plates and replaced the big bolts with stainless steel ones. Also put new guide pins in...they were really nasty to get out.
Sundance
post #40 of 46 (permalink) Old 17-01-2017, 17:49 Thread Starter
Car: Trophy
The brake caliper on the drivers side was passable after being cleaned up but the one on the passenger side is a mess so I've decided that I'll just paint them both, although I won't be taking them off so will need to stock up on copies of the Metro to cover everything else up
Out of interest, can I also paint the rear calipers if it takes my fancy?
Mikey07 is offline
Refurbishing alloys (straights) Starkie37 MG ZR / Rover 25, 200 & Streetwise 14 02-07-2011 23:36
Refurbishing my alloys... Kris214 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 21 17-01-2011 15:17
Refurbishing alloys roley MG ZR / Rover 25, 200 & Streetwise 16 25-07-2010 13:22
Refurbishing Megs Alloys adamelphick MGF and MGTF (Sponsored by MGFnTFBITZ) 80 21-10-2009 12:07
Refurbishing alloys dawes Metro / Rover 100 10 29-03-2008 12:15
