Removing front bumper (MG TF) - MG-Rover.org Forums
post #1 of 11 (permalink) Old 30-07-2006, 00:31 Thread Starter
Smile Removing front bumper (MG TF)
Hi
When trying to remove the front bumper i found five screws at the top of the bumper(just under the bonnet),two large hex screws on the front & 2 screws each side attatched to the black wheel arch protector removed all these but still attatched on closer inspec i noticed behind the black plastic wheel arch protector at the top of the bumper inside the wheel arch there seems 2 b another screw (1 each side) these seemed very tight to remove (couldnt get these off) are these the last 2 scews i need to remove.
What a hassle to fit a set of fogs
gtully is offline
post #2 of 11 (permalink) Old 30-07-2006, 09:06
Car: MGF VVC & SEAT Family bus
If it's the same as the F there are 2 screws behind the liner on each side, 1 right near the wheel arch that has to come right out and one nearer the front which you only have to loosen.
HTH
Phil_B is offline
post #3 of 11 (permalink) Old 30-07-2006, 17:50
and just to rub more salt in the wound its not necessary to remove the whole bumper to fit fogs it can be done from underneath withe the bumper stil on the car
SLIPPER32 is offline
post #4 of 11 (permalink) Old 30-07-2006, 21:18
D'oh, , could have been worse though, could have been fitting them to an F. Not only do you have to take the bumper off but you have to cut your own holes :S
Phil_B is offline
post #5 of 11 (permalink) Old 30-07-2006, 23:37
Car: SAAB 9-3 Cab Aero 2.8L V6 Turbo - Damn its fast.......
Just incase you still want the instructions......
jase is offline
post #6 of 11 (permalink) Old 31-07-2006, 11:27
Car: MGTF 160
Oooops
Looks like someones due a moderator warning!
garyb0479 is offline
post #7 of 11 (permalink) Old 02-08-2006, 23:19 Thread Starter
Thanks for the advice
Dont think there is much room to fit the fogs & mounting brackets ,from underneath,i also want to remove the front grill so think its probably easier to remove the bumper.(please correct me if im wrong cause id really rather not have to remove it)
gtully is offline
post #8 of 11 (permalink) Old 27-06-2011, 05:15
Car: Other Rover
Originally Posted by gtully View Post
Hi
When trying to remove the front bumper guard i found five screws at the top of the bumper(just under the bonnet),two large hex screws on the front & 2 screws each side attatched to the black wheel arch protector removed all these but still attatched on closer inspec i noticed behind the black plastic wheel arch protector at the top of the bumper inside the wheel arch there seems 2 b another screw (1 each side) these seemed very tight to remove (couldnt get these off) are these the last 2 scews i need to remove.
If you are still having a hard time to remove the bumper, better watc an online tutorial in youtube or ask a friend who knows how to help you.
psylocke24 is offline
post #9 of 11 (permalink) Old 27-06-2011, 05:55
Car: TF148
or go into the 'how to' guides at the top of the forum and read the excellent CJJ guide
Lee121 is offline
post #10 of 11 (permalink) Old 27-06-2011, 06:35
I think after 5 years he may have sorted it
post #11 of 11 (permalink) Old 27-06-2011, 07:14
You never know. Them last 2 screws are buggers.
MG TF front bumper NandoDave For Sale 7 07-06-2011 12:45
MG TF front bumper Deano Wanted 0 09-04-2008 14:06
mg tf front bumper and headlights! mgzrtd+ Wanted 0 30-05-2007 08:54
MG TF Front Bumper lushboyandy Wanted 1 06-11-2006 17:44
MG TF front bumper Tomcat MGF and MGTF (Sponsored by MGFnTFBITZ) 0 05-02-2006 15:36
