Repair of clutch master cylinder (with photos) - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
post #1 of 24 (permalink) Old 24-02-2009, 18:20 Thread Starter
Car: MG ZS 120+
I am too tight to pay for a new master cylinder, so today I had a go at fitting new seals instead.
I bought AP Lockheed repair kit LK 11231 off ebay for about 8 including delivery.
First, I removed the clevis pin from the top of the clutch pedal. There are no photos of this stage because it's done mostly by feel.
Next, remove the plastic cover from under the bonnet. I had to give the plastic nuts a little help to come off:
With that out of the way, it is easy to see the clutch master cylinder:
Remove the pipe from the top, taking care to catch any drips:
Remove the 2 bolts and lift the cylinder out of the bulkhead:
Peel back the rubber boot and remove the circlip. The cylinder spills its guts:
The cylinder in bits:
Old seals removed:
New seals fitted using some brake fluid to lubricate:
Putting things back together with some red rubber grease. The cylinder body was cleaned using alcohol wipes and the reservoir had some brake fluid poured in and then I gave it a good shake before emptying it out:
The circlip is back in. Just need to push the rubber boot back on and fit it to the car:
Put it back in, fill the reservoir and then bleed using the bleed point on the slave cylinder. Total time about 4 hours.
Problems:
My circlip pliers were too large to fit the holes in the circlip. I made do with a pair of needle-nose pliers.
The cylinder insides were different to the diagram in my repair kit. Instead of easily coming apart, it was all one unit so I had to stretch the seals over the length of the shaft to get them on. Much swearing was required, but they went on.
I've disturbed the brake light switch while messing around in the footwell. I'll have to reset that tomorrow.
Link to album of all images
ourmark is offline
post #2 of 24 (permalink) Old 24-02-2009, 18:30 Thread Starter
Car: MG ZS 120+
Hmmm... not all of the photos are showing. Gonna try uploading them somewhere else.
ourmark is offline
post #3 of 24 (permalink) Old 24-02-2009, 18:40
Car: MG TF 160
Very usefull!!
Reaper is offline
post #4 of 24 (permalink) Old 24-02-2009, 19:01
Good work there, an excellent how to
MGFmad is offline
post #5 of 24 (permalink) Old 24-02-2009, 19:50
Car: TT MGF #0002
You make it sound so easy to remove it from the car That rear bolt is a right pain in the arse!!!
Good job I've got the one I took of my car a few weeks back to replace the seals in, must get round to it one day
gotenks1321 is offline
post #6 of 24 (permalink) Old 24-02-2009, 19:57
excellent how to. Just one small point, you make reference to the 'slam panel' as being the plastic moulding at the back, its not, the slam panel is what the bonnet catch locks in at the front, the moulding has the grand name of an 'under bonnet cover'.
post #7 of 24 (permalink) Old 24-02-2009, 21:04 Thread Starter
Car: MG ZS 120+
Thanks guys, and thanks for the correction, Pete. I've edited my post.
ourmark is offline
post #8 of 24 (permalink) Old 25-02-2009, 06:49
Car: MGF Trophy 160, MG ZS180
Nice post. Have some rep.
I've got a screwdriver like that. One of my most used tools.
Tim. is offline
post #9 of 24 (permalink) Old 25-02-2009, 07:46 Thread Starter
Car: MG ZS 120+
Thanks for the rep!
If anyone has trouble with images not loading, all these (and a few more) are also here
ourmark is offline
post #10 of 24 (permalink) Old 25-02-2009, 07:48
Car: 1999 MGF 1.8 mpi
Excellent job!
MGFNorway is offline
post #11 of 24 (permalink) Old 25-02-2009, 08:12
Car: VVC
Hi
thanks for the nice tuto, but could you tell me why you have change it, what was the symptom on the clutch ?
thanks
pascandrea is offline
post #12 of 24 (permalink) Old 25-02-2009, 10:07 Thread Starter
Car: MG ZS 120+
Originally Posted by pascandrea View Post
Hi
thanks
I'd had problems with the clutch sticking for the last 9 months. I bled the system and greased the arm and that worked for 6 months before the clutch stuck again. About 2 months ago, I replaced the slave cylinder which got things working again, but I was unsure of the state of the master cylinder for a couple of reasons:
First, the pedal felt slightly uneven, as if it was bouncing back at the top of the pedal travel.
Second, the fluid was discoloured even though it had been replaced twice in recent months.
So although the car was driveable, I thought it best to sort the master cylinder. Then I've done the whole lot and I can hopefully get another 50,000 miles out of it.
One more thing to mention is that I'd replaced the clevis pins on both cylinders with stainless steel ones. Yesterday I was able to check them after 2,000 miles and they have no signs of wear.
M8x16mm fits the slave cylinder and M8x20mm fits the master cylinder. If you want to use a washer, then you'll need to go one size bigger on each of these. I chose not to because where they are located, I'm more likely to drop a washer and lose it than I am to get it on to the pin. There isn't much rotation on these joints and therefore the R-clips don't suffer from not having a washer, IMO.
ourmark is offline
post #13 of 24 (permalink) Old 27-02-2009, 15:02 Thread Starter
Car: MG ZS 120+
Just a little update now I've driven the car some more.
The clutch pedal feels very smooth. For some reason, I thought it might feel lighter but if anything it's got slightly heavier. But the odd "bouncy" feeling has gone so that's good.
I haven't heard any squeaks from the pedal since doing this, either. Maybe it is too early to tell, as the squeak used to come and go, but if it's gone then that's really, really good.
Very happy with the results from doing this work and I can't wait to do the brakes next. I'm planning a master cylinder rebuild along with braided hoses and new pads.
ourmark is offline
post #14 of 24 (permalink) Old 06-03-2009, 15:22
where are the photos
i have same problem with the clutch...srry but i cant see your photos
_MEME_ is offline
post #15 of 24 (permalink) Old 06-03-2009, 16:21 Thread Starter
Car: MG ZS 120+
Images should display correctly now. Good luck with it!
ourmark is offline
post #16 of 24 (permalink) Old 07-03-2009, 00:09
Car: MGF MK2 1.8i,BMW 330i
Great post!! Thanks
Broon is offline
post #17 of 24 (permalink) Old 01-05-2012, 00:31
Originally Posted by Broon View Post
Great post!! Thanks
Glad I thanked you for this post back in 2009 as I now need to use it to repair my master cylinder..I must have secretly known I'd need it some day
Broon is offline
post #18 of 24 (permalink) Old 01-05-2012, 04:55
Car: MG TF 160 in Silver
But their's no mention of welding the car first.
Hope you fix it soon.
Ta-tar for now
eyes wide open is offline
post #19 of 24 (permalink) Old 01-05-2012, 05:05
Ta-tar for now
No welding needed
Broon is offline
post #20 of 24 (permalink) Old 13-05-2012, 19:33
Old seals removed:
Problems:
How on earth did you get the rod out of the unit. Mine wont come out at all?
Snowman001 is offline
Tags
clutch master cylinder, f/tf how to
clutch master cylinder luddite MG ZS / Rover 45 & 400 10 20-01-2009 18:10
Clutch Master Cylinder alex7127 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 17 12-10-2008 22:34
Clutch master cylinder gotenks1321 MGF and MGTF (Sponsored by MGFnTFBITZ) 11 29-05-2008 12:52
Clutch Master Cylinder Rover Gonzo MG ZT / Rover 75 (Sponsored by Rimmer Bros) 8 10-03-2008 21:50
clutch master cylinder cookies MG ZT / Rover 75 (Sponsored by Rimmer Bros) 7 03-05-2006 18:58
