Replacing Faded Badges MG TF - How To - MG-Rover.org Forums
post #1 of 94 (permalink) Old 25-03-2007, 16:30 Thread Starter
Car: MG TF 160 Lemans Green
Having just replaced the front and rear badges on my MG TF160 I thought I'd make a guide as a "how to" so others can benefit
Firstly, what you will need:
1. Can of Clear Lacquer
2. Dental Floss
3. Plastic spatular or similar
4. Something to remove grease (I used t-cut)
5. Soft cloth
6. 2x new badges
Note badge part number: DAB000160 - for the TF you need two the same (both 70mm). They are reasonable at 12 each from any x-part dealer. Mine came from Rimmer Brothers.
Firstly I used the clear lacquer to build up another layer on the new badges to help stop them fading like the originals. The Halfords own lacquer cost me around 6.50 and worked a treat.
Build up as many coats as you can be fussed to add, giving a couple of light sprays each coat. Make sure you wait 10 minutes between each coat until the lacquer is touch dry. I added around 5 coats on each badge, returning to add more coats whilst i was removing the existing badges.
Next, you need to remove the old badges. Many people have said that heating the badges helps remove them, but frankly there was NO way I was getting a heat gun or hairdrier anywhere near my baby... and I actually found you just don't need it.
The easiest way was to use dental floss (I used mint out of preference...) and put this behind the badge and use a sawing motion to cut the self adhesive pad out from behind the badge. It requires a little patience, but it only took about 5 minutes to get each badge off. Just keep sawing with the floss until they basically fall off of their own accord.
TIP: If you find that the floss keeps snapping, just double it up under the badge. I found this helped a lot and speeded the process up.
The pins on the back of the badge look scary but are mearly there for positioning and are not / should not be glued.
When the badge is removed there is likely to be part of the adhesive pad left, I removed this with some rubbing of my thumb, and a nice young lady with long nails A bit of perseverance and you can peel the remainder away. There is no need for any heat, paint stripper, sand paper etc etc...
The front badge is recessed into the bumper, but all you need to do is to help the floss under the edge of the badge using the plastic spatular. It's a bit of a fiddle at first, but gets better the more you cut through.
Now just use a soft cloth and something to remove the grease. I used a tiny amount of t-cut.
When you are happy that the lacquer on the new badges has hardened enough (touch dry, or over night if you can manage that... I couldn't ) simply peel the backing from the adhesive pads they come fitted with and gently press into place.
Job's a good 'un!
Now step back and admire your shiney new badges!
zilla is offline
post #2 of 94 (permalink) Old 25-03-2007, 16:33
Car: MGTF160
Nice Job,and handy bit bit of info,the old badges are bad aren't they? Dave
DAVIDT6DCM is offline
post #3 of 94 (permalink) Old 25-03-2007, 16:34
Nice one!
post #4 of 94 (permalink) Old 25-03-2007, 16:37 Thread Starter
yeah, considering the car is only sept '02 the front one was shocking and made the car look a lot older. It's got a new lease of life now
zilla is offline
post #5 of 94 (permalink) Old 25-03-2007, 16:37
Car: MG TF 135 & Mk2 MG ZR Express
Send a message via MSN to tf karl Send a message via Yahoo to tf karl Send a message via Skype™ to tf karl
Nice How to...? Z ,someones had a busy weekend
tf karl is offline
post #6 of 94 (permalink) Old 25-03-2007, 16:39 Thread Starter
yep all good fun tho. Start small and then work up.... so a milltek exhaust, vader induction and lowered springs next weekend
also, get the diy stuff out the way whilst it's cold, 'cos lets face it, when it's warm I'll be driving it
zilla is offline
post #7 of 94 (permalink) Old 25-03-2007, 16:54
Good work Zilla
Herbie is offline
post #8 of 94 (permalink) Old 25-03-2007, 17:20
Car: MGF Trophy 160, MG ZS180
Good Job
Tim. is offline
post #9 of 94 (permalink) Old 25-03-2007, 18:03
excellent stuff do you mind if I link to this zilla ??
post #10 of 94 (permalink) Old 25-03-2007, 18:05
Car: 99 MGF & Alfa Spider LE
Thats brill.
Link pete! Add to your website.
Iain
iaross is offline
post #11 of 94 (permalink) Old 25-03-2007, 19:19
Car: MG TF + MG ZR + MG BGT + MG ZR-R+MG3
If you do fit 'Lowered Springs', a 'How to' would be very useful.
GazSuttonUK is offline
post #12 of 94 (permalink) Old 25-03-2007, 19:23
Pip
Send a message via MSN to Pip
Badges - another job on my to-do list. Last one I bought (for the centre cubby) only cost 6 though
Glad to see it's a doddle to change. Has anyone had new ones fitted long enough to determine whether lacquering actually helps?
Pip is offline
post #13 of 94 (permalink) Old 25-03-2007, 19:32
Originally Posted by Pip View Post
.....Has anyone had new ones fitted long enough to determine whether lacquering actually helps?
I have, can't remember when I did it, must be well over a year, and they still look as good as new *touches wood*
post #14 of 94 (permalink) Old 25-03-2007, 21:01
Very nice Zilla. I love the TF badges.
Yigit is offline
post #15 of 94 (permalink) Old 25-03-2007, 21:30 Thread Starter
not at all! It's there to help people so just go for it
zilla is offline
post #16 of 94 (permalink) Old 25-03-2007, 21:58
Green Goddess
Car: MG TF 80th Anniversary LE #1469 Tweaked by Z&F
Send a message via MSN to Paula
Why do some badges go manky and some dont? Mine are still in perfect condition, i check them every time i wash the car just in case.
Paula is offline
post #17 of 94 (permalink) Old 25-03-2007, 22:01
Your car spends a lot of it's time in the garage.
post #18 of 94 (permalink) Old 25-03-2007, 22:02
Green Goddess
Paula is offline
post #19 of 94 (permalink) Old 25-03-2007, 22:06
Car: Renaultsport Clio 197 & Renaultsport Clio 172
Send a message via Yahoo to Emily
Thats a great 'How To'. I've just bought a new badge for mine, and i wasnt sure how i was going to take the old one off and put the new one on, so i'll be using your guide now. Thanks!
Emily is offline
post #20 of 94 (permalink) Old 26-03-2007, 10:37
Car: MG TF 160g (Special Edition of 1) and Lexus RX300
Send a message via MSN to Catweazle Send a message via Skype™ to Catweazle
New badges just added to my shopping list...with that sort of How To...I am confident even I will be able to do it.
Thanks Zilla, this buffoon is learning...little steps but everything helps...
Catweazle is offline
Tags
f/tf how to, how to
help with faded badges sash MGF and MGTF (Sponsored by MGFnTFBITZ) 19 03-09-2008 22:11
Replacing MG Badges on Mk1 ZR Darren199 MG ZR / Rover 25, 200 & Streetwise 3 04-01-2008 05:44
badges of tattiness (needs to be a tf) Deano MGF and MGTF (Sponsored by MGFnTFBITZ) 24 17-08-2007 09:41
Replacing emblem - MG TF agrasso MGF and MGTF (Sponsored by MGFnTFBITZ) 1 14-05-2007 21:48
Replacing badges Tonyrec MGF and MGTF (Sponsored by MGFnTFBITZ) 36 19-07-2006 21:31
