Roof/window leaks... - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
post #1 of 19 (permalink) Old 16-05-2006, 18:37 Thread Starter
Car: Honda S2000
Another job done on the new TF today!.
In heavy rain water would drip down the inside of the passenger window!.
As you can see from the first pic below its easy to see why!!!..
Had a similar leak on the old `F` and same cure applied to the TF if its any help to anyone!.
In the first pic it looks like the window is out of line as its not pushing against the screen seal as it should, but instead going over the side creating the gap!.
The problem is caused by the seal on the corner of the screen/roof bending in and down as the seal locating peg loosens and bends, so not pushing the seal against the window.... hence the gap!.
The cure is to remove the hood clamp bracket (screen), then pull away this seal....... its then a case of lifting the seal and re-locating the peg fully in its hole, this should bring the seal `out and up` to meet the top of the window!........ a small adjustment of the hood clamps was also needed to eliminate a tiny remaining gap!
You can see the difference it makes in the second pic!!
Mark.L is offline
post #2 of 19 (permalink) Old 16-05-2006, 18:53
*pete runs off to the garage with spanners*
post #3 of 19 (permalink) Old 16-05-2006, 19:19
Car: MG ZT 260 SE V8
Wait for me! It's better than my insulation tape fix!!
James C is offline
post #4 of 19 (permalink) Old 16-05-2006, 20:22
ah cool i just leave the window down a bit and push it into the rubber, but im gonna have a go at it
mgfjackson is offline
post #5 of 19 (permalink) Old 16-05-2006, 21:52
I think I'm going to spend some time and put all these great little 'fixes' into a 'how to' web site, wadda think ???
post #6 of 19 (permalink) Old 16-05-2006, 21:55
Car: Audi TTR 225 :)
Send a message via MSN to M77XNE
I'm going to get my dad on the case at the weekend to sort my leaks out for me. My dad is great - after all, what are dads for!?!?!
and Pete, I think you have a fab idea there!! Do you fancy your own personal PA???
M77XNE is offline
post #7 of 19 (permalink) Old 16-05-2006, 22:05 Thread Starter
Car: Honda S2000
Sounds good Pete!.
Am fitting a new interior either over this weekend or next week depending on work!..
Changing most of the interior stuff so will take some piccies if you wish for a `how to` type thing if that helps!.
Mark.L is offline
post #8 of 19 (permalink) Old 17-05-2006, 05:44
yeah, anything Mark. There was 'talk' of such a section on here, but no sign of it ever happening . I'm don't intend to cover existing stuff, I'll just get permission from the orginator to supply a link.
post #9 of 19 (permalink) Old 17-05-2006, 06:31
Car: MGF VVC & MR2 GT-i16
Send a message via MSN to Sambo. Send a message via Skype™ to Sambo.
http://mr2oc.co.uk/index.php?name=Knowledge_Base
That's my bible when I'm trying to fox my MR2. If a new fix is posted on the forums, anyone can submit that post to the "Know your 2" section for a modrator to edit and pubish.
I'm shocked that this website doesn't have one.
Sambo. is offline
post #10 of 19 (permalink) Old 17-05-2006, 06:57
Andie B
Guest
Posts: n/a
Clicking the link came up as 'access denied' I'm afraid....guess they can sense us F/TFrs who don't also have an MR2 at 100 cyber-paces!
post #11 of 19 (permalink) Old 17-05-2006, 07:20
Car: MGTF160
That's good bit of info Mark, mine not leaking but the fit is awfiul,will have a wiggle about with it this weekend.
Sambo i couldn't open either,link just froze my page , Dave
DAVIDT6DCM is offline
post #12 of 19 (permalink) Old 19-05-2006, 20:08
Oops, sorry, you need to be a member to see it, but I've taken a few sneaky screen-grabs...
http://simon-cooper.net/temp/3.jpg
http://simon-cooper.net/temp/2.jpg
http://simon-cooper.net/temp/1.jpg
Sambo. is offline
post #13 of 19 (permalink) Old 28-11-2006, 13:54
Sorry for pulling up, but:
Thanks Mark !!!
What a useful tip, almost repositioned the hole seal and worked a treat, makes my F so less noisier and I have a good feeling in general now. Did the cheater and windows adjustment a few months back, so this was the "i-dapple" (i-tüpfelchen, maybe not translatable) ......
Worth every minute to do that, also Curgy's tip ref. the cantrail seals (loosen little nut, pulling seal toward a-frame, closing nut) was great !!!
Danke Mark and James
Herbie is offline
post #14 of 19 (permalink) Old 07-03-2007, 15:03
Send a message via MSN to AlexF
oh no!
the 1st picture has gone.... any chance of uplaoding it again?!
I think I have the exact same problem - so before I go chasing my tail this weekend taking the door apart I'd love to see if my MGF is doing the same as yours!
ALex
AlexF is offline
post #15 of 19 (permalink) Old 07-03-2007, 18:31
Car: Classic Rover
yes mine is also doing this. just the passanger side window. it just doesnt fit snuggly into the seel.
can anybody put up an easy step guide to fixining this?
cheers
jonrice81 is offline
post #16 of 19 (permalink) Old 29-06-2007, 00:30
Jut
Car: MG TF 160 :D
sorry for the thread necrophillia, but anyone got a step by step guide preferably with pics to do this?
Jut is offline
post #17 of 19 (permalink) Old 29-06-2007, 07:03
G'morning Jut, this may help you (Cantrail seal):
http://www.mgfcar.de/adjust/Adjust01.PDF
Herbie is offline
post #18 of 19 (permalink) Old 02-02-2009, 16:32
Thank god
How glad am I that this thread is on here, just bought an older TF and cannot get good seal on passenger side with hood up. Its as if Cantrail seal forces window out at top.
I have done all the window adjustment and cheater adjustment
any chance of a link to curby's thread ref cantrail adjustment with little nut.........
Obviously I am well behind the drag curve, glad I am not alone though, this forum is a godsend.
gavnorton is offline
post #19 of 19 (permalink) Old 25-02-2011, 06:46
I found this thread and I think this could solve my problem, but I was hoping that someone could help and explain a little (maybe with a photo) as I am not sure which clamp I have to remove or tighten (the one on the front window screen or the one on the hood).
The problem is that the LH window has a leak when the hood is really wet and soaked so the drops from the corner of the ood find their way into a tiny corner opening of the window-to-door seal. The RH side has not any problems. I have taken photos of the corner of the hood from both sides, if somebody can advise on this. The first one is the LH with the problem and the second one is the RH where there is no problem.
http://img88.imageshack.us/i/img0831cu.jpg
http://img340.imageshack.us/i/img0832j.jpg
Taki is offline
roof down window up on mgf nk8 MGF and MGTF (Sponsored by MGFnTFBITZ) 41 01-10-2007 05:33
roof leaks thru interior light on zs 120 jules 123 MG ZS / Rover 45 & 400 1 25-08-2007 22:02
glass window and electric roof kizzy MGF and MGTF (Sponsored by MGFnTFBITZ) 41 09-03-2007 18:34
Split in window/roof seal ZoSo MGF and MGTF (Sponsored by MGFnTFBITZ) 3 26-09-2006 17:45
rear window and roof Deano MGF and MGTF (Sponsored by MGFnTFBITZ) 19 19-08-2003 12:58
