Rough idle...? - MG-Rover.org Forums
 6Likes
post #1 of 32 (permalink) Old 25-12-2016, 19:18 Thread Starter
Rough idle...?
Hello and Merry Christmas everyone! After trawling the internet I'd like to get some further advice from you guys here before I go replacing every part in the car!
So, after having my flexi pipe changed due to it making the car sound like a proper chav car I've had a real rough idle.... Particularly on a cold start. However, it has happened the odd time when the car is warm and stationary at the lights. I'll try my best to explain... Of a morning, when the car first starts it feels fine and the revs are where they should be. However after about 10 seconds the revs start to drop and the car rumbles and vibrates like it's getting ready to stall. It almost feels as if the cold start up cycle gets cut short? However this wouldn't explain why it would happen when warm. When I try and drive the car when it is exhibiting these symptoms it feels like it's running on 2 cylinders and when I take it out of gear and pop it into neutral it will stall. It drives absolutely fine 90% of the time although... I feel it is the idling that screws it up. A few days ago I replaced the plugs, leads, air filter and coil packs and while it seems to run better, the fundamental problem remains. There was no evidence of oil being on the old plugs so I don't think it is the inlet manifold gasket. I'm thinking to replace the IAVC valve or at least give it a clean? Maybe fuel filter? I must say... since this has started after the flexi pipe change, could it be the o2 sensor? The garage very honestly informed me my old o2 sensor was intact and it didn't require a change so they just used the old one. I went back to them explaining my symptoms but they were adamant the sensor wouldn't cause this problem but I disagree as this problem has only arisen since the change. Any thoughts guys?? Is an o2 sensor something I can change comfortable at home you reckon??
Many thanks!!
Mem
MrKitty is offline
post #2 of 32 (permalink) Old 25-12-2016, 19:28
Car: Crystal White (Pearl) LE500 #133. Previously; TF160; F
maybe a TPS reset might help? throttle position sensor I believe. a quick search of the forum should turn up the procedure. certainly worth a shot
roobs is offline
post #3 of 32 (permalink) Old 25-12-2016, 19:35 Thread Starter
Thanks for the reply roobs, I'll take it for a quick spin to make him warm and give it a go.. Certainly can't hurt! Would love an easy fix such as this but when is life this simple aye??
MrKitty is offline
post #4 of 32 (permalink) Old 25-12-2016, 19:36
sundanceuk's Avatar
Car: MG TF 160
TPS is a easy and free first thing to do, but I am thinking that maybe when the downpipe was changed, possibly the lambda sensor, or wiring may have been damaged. This would explain why the engine is misbehaving since you replaced the downpipe. It would be where I would be looking first. second would be the Idle air control valve.
I did have a similar fault on my car, but it disappeared after a day and has not come back, although I have serviced the engine and replaced the plugs since.
I also picked up a spare IACV from our sponsor the other day, just in case as they can act up when dirty.
Get a plug in diagnosis, it may help to narrow it down a bit!
Sundance
sundanceuk is online now
post #5 of 32 (permalink) Old 25-12-2016, 19:40 Thread Starter
Cheers for your speedy replies guys, particularly on xmas day! I will get cracking, try and be a little less cynical and hope the TPS reset works
MrKitty is offline
post #6 of 32 (permalink) Old 25-12-2016, 19:55
you never know. sometimes you can spend hours trying to figure something out and it turns out it was something simple all along, other times not so much lol. fingers crossed it's just a glitch and not a gremlin.
roobs is offline
post #7 of 32 (permalink) Old 25-12-2016, 19:56
also, I love that your car is a boy
roobs is offline
post #8 of 32 (permalink) Old 25-12-2016, 21:11 Thread Starter
So I just took him out and got him nice and hot (lol), did a tps reset and it really does feel better and idle beautifully however I can't be fully sure until I start him in the morning from cold... I shall update then!
roobs likes this.
MrKitty is offline
post #9 of 32 (permalink) Old 27-12-2016, 19:18 Thread Starter
Unfortunately after a tps reset I've not had much luck. Yesterday I changed the fuel filter (such a b*tch to loosen that thing) and removed the IVAC valve and gave it a good spray of carbon cleaner but to no avail... also tps reset after cleaning valve... it has to be this o2 sensor because I'm pretty stumbed!!
MrKitty is offline
post #10 of 32 (permalink) Old 27-12-2016, 20:18
Think before you type!
Perhaps the sensor wires are damaged?
IanMc is offline
post #11 of 32 (permalink) Old 27-12-2016, 20:27 Thread Starter
Sensor wires related to the o2 sensor Ian?
MrKitty is offline
post #12 of 32 (permalink) Old 27-12-2016, 20:47
Yes Sir - take a close look at them for damage to the insulation.
IanMc is offline
post #13 of 32 (permalink) Old 27-12-2016, 21:23 Thread Starter
Alright I'll check em out!
MrKitty is offline
post #14 of 32 (permalink) Old 27-12-2016, 22:19
Silly question time.
1) Is this on a TF as in your avatar info or another car, this isn't mentioned anywhere in the thread?
2) Have you scanned the ECU for fault codes?
3) Have you read OBD data at any point?
For instance what is the CTS doing?
What about fuel temp?
Is it switching to closed loop at all?
post #15 of 32 (permalink) Old 28-12-2016, 00:28 Thread Starter
Hi talking cars, sorry I should have made that clear, it's an mg tf 135 03 plate sprint. Certainly not silly questions because I have no idea what the OBD data is :o and I have not had the ecu read, is that something I could do myself or would I need funky equipment? And the CTS is a good point, would explain why it feels to switch from a cold cycle to a warm too early!!
MrKitty is offline
post #16 of 32 (permalink) Old 28-12-2016, 09:57
OBD is on board diagnostics, the TF complies to OBD2 requirements. These can be read and cleared with a cheap ebay Bluetooth reader.
OBD2 fault codes are held in the ECU.
The K series has 2 CTS, one feeds the dash gauge, the other feeds the ECU and this data is used to control fueling and ignition timing.
post #17 of 32 (permalink) Old 28-12-2016, 10:04
MrKitty, where in Essex are you?
If you were close to Braintree you could come to my place and I would gladly plug my diagnostic kit into your car and scan for error codes.
IanMc is offline
post #18 of 32 (permalink) Old 28-12-2016, 10:32 Thread Starter
Ah ok that makes sense, I remember when I got him remapped he plugging it in from under the steering wheel! And Ian that would be wonderful! I live in Loughton but would be more than happy to pop to Braintree. Pm me a time and place and I'll be there
MrKitty is offline
post #19 of 32 (permalink) Old 28-12-2016, 11:33
pm me a time and place and I'll be there
You have PM Sir
IanMc is offline
post #20 of 32 (permalink) Old 28-12-2016, 17:54
Car: MGF 1.8 VVC
Is there a chance that the insulation sleeve on the o2 sensor wires was omitted when the sensor was swapped over?
(On my car it's a simple asbestos tube covering the bare wires)
On a hot pipe, the wires could melt causing a short.
IanMc likes this.
scot748 is offline
Sudden onset random rough idle/ rough running issues onepostwonder Diesel Forum! 2 01-03-2016 14:28
Rough Idle 1.4 zr BrokenSpring MG ZR / Rover 25, 200 & Streetwise 5 23-07-2015 13:18
Interesting idle issue: Low/rough idle when braking out of gear. Very confusing! DMGRS MG ZT / Rover 75 (Sponsored by Rimmer Bros) 13 24-09-2011 01:54
Rough Idle Dom1269 MG ZR / Rover 25, 200 & Streetwise 4 13-05-2009 22:35
rough idle amsokol MG ZT / Rover 75 (Sponsored by Rimmer Bros) 7 29-09-2008 21:00
