Rover k-series q375hk - MG-Rover.org Forums
post #1 of 4 (permalink) Old 13-03-2016, 17:54 Thread Starter
Hi !
I need extra power in my MG TF 136CV .
What do you think about this camshaft ROVER K-SERIES Q375HK ?it is the same of piper cams 285h?
Rover K-Series | Q375HK - An hydraulic profile camshaft | QED Motorspo
profile:
Expressed Period: 284
Maximum Cam Lift: 0.373
Inlet Fully Open: 108 ATDC
Inlet Lift @ TDC: 0.112
Exhaust Fully Open: 108 BTDC
Exhaust Lift @ TDC: 0.112
Inlet Valve Clearance: N/A Cam is for use with hydraulic followers
Exhaust Valve Clearance: N/A Cam is for use with hydraulic followers
mainuno is offline
post #2 of 4 (permalink) Old 14-03-2016, 10:19
Originally Posted by mainuno View Post
Hi !
profile:
Are you going throttle body route too as I don't think they're suitable for a single t/b.
They are very good cams for road and track use I use them but mine are the mechanical type as I have a high rpm limit
tonestf is offline
post #3 of 4 (permalink) Old 20-03-2016, 02:10 Thread Starter
Hi !DO you use esmeralda 3d for this cams ?
mainuno is offline
post #4 of 4 (permalink) Old 20-03-2016, 16:04
I have not heard of anyone using these cams without a aftermarket ecu I guess they are usually fitted along with other performance enhancements this is the route I went, I use the emerald ecu k6.
Perhaps a call to kmaps could shed more light on the matter also there are some pretty clued up folks on here that may just have the answer you need
tonestf is offline
alloy oil cap for a rover engine l series t series etc zr-td-nutters Wanted 3 24-05-2013 10:54
L Series Diesel Engine Overhaul Manual & L Series Rover 600 brake pads hfz_3 Diesel Forum! 10 29-12-2011 20:18
Rover didnt make the K series/ L series James MG / Rover Related Chat - up to 2005 32 09-01-2009 14:01
rover 220 gti t series and m series engines whats the difference???? rover2201 'R8' Rovers (aka Wedges!!) 9 28-07-2005 22:21
difference between rover 820 T Series and 420 T Series santa20 Others 8 25-05-2004 21:19
