Spax Problem part - MG-Rover.org Forums
  • 1 Post By Masterbateson
post #1 of 12 (permalink) Old 30-12-2016, 15:12 Thread Starter
Spax Problem part
HI I live in SE London there are speed bumps every 100 yards.
Fitted spax shocks and springs with new bolts 18 months ago to my 03 TF. Reckon I still need to soften up some more.
Have just broken the bolt that secures the Shock to the upper suspension arm on the back driver side.
Heard it break on a hump and car sat down hard 200 meters from home.
Wheel off. Problem obvious.
I have remarkably managed to get the broken bolt out of the arm.
Ordered new bolts. Now I realise the spax shocks use a collar/washer/bush either side of the shock which sits into a recess in the arm.
One is lost. Does anybody have an idea of what I can use or does anybody have an old spax shock with the collars still in place lying about.
No car till sorted.
Good wishes for New Year
Kevin R (Rev)
FrKevin is offline
post #2 of 12 (permalink) Old 30-12-2016, 17:00
I think the collar/bush is part of the shocker lower mounting. I didn't think they came out separately as the lower bush is some kind of spherical bearing rather than a rubber bush and sleeve affair.
Probably need to contact Spax.
BTW make sure the new 'bush' is properly located in the upper suspension arm recess and the bolt properly torqued up so that you will hopefully avoid a re-occurrence!
TipperMG is offline
post #3 of 12 (permalink) Old 30-12-2016, 19:21 Thread Starter
No there are separate collared bushes that are supplied with spax shocks. They fit the recess in the arm and sleeve the bolt either side. I remember they are cable tied in pairs onto the bottom end of the new shocker when they are first unpacked.
FrKevin is offline
post #4 of 12 (permalink) Old 31-12-2016, 09:48
Car: 143 vvc Mk1
Treat the root cause - move out of SE London!
On a more serious note, you may find that you can lodge a claim, or at least a complaint against Bromley council. For the want of a letter i'd try.
I know the parts you refer to - i'd guess they will be common to a lot of Spax dampers, so have a look on ebay, or phone Spax.
blackoctagon is offline
post #5 of 12 (permalink) Old 31-12-2016, 14:47
Interesting.
On the original damper design (and on the Bilstein replacement dampers) the bush takes the suspension load by being recessed into the arm and the bolt provides a clamping load to keep it there.
On your Spax arrangement it sounds like the bush is just a spacer and the bolt takes the suspension loads and not the bush. Is that what it looks like?
No wonder the bolt shears as they are in shear and not really designed to take that loading!
TipperMG is offline
post #6 of 12 (permalink) Old 31-12-2016, 14:55
Car: MG ZT-T
If you fitted these without fitting the correct top hat washers/spacers, then you are going to shear the bolts.
Have a look in Mike Saturs website under the spaxs shockery section and you'll find em.
IanMc likes this.
Masterbateson is offline
post #7 of 12 (permalink) Old 31-12-2016, 20:04 Thread Starter
Nice one, got it, forgotten I had traded previously with Mike Satur helpful guy I am back in business:
Thankyou so much for responding
Shock Absorber Lower Centering Bushs Spax MGTF
These were correctly fitted with new bolts in August 2015 thats what's worrying me.
FrKevin is offline
post #8 of 12 (permalink) Old 02-01-2017, 09:42
Re Mike Satur has he changed location or Phone number?
campbosshassi is offline
post #9 of 12 (permalink) Old 02-01-2017, 18:24
Car: MG TF 160 SPRINT
I see that you are sorted now but for information, when I needed the top hat spacers form my spax dampers I ordered them direct from spax.
Ian_R is offline
post #10 of 12 (permalink) Old 03-01-2017, 11:41
Car: MG ZT-T
You had better luck than me, I tried going through to spaxs and they made out that they knew nothing about these top hat washers and didnt supply them.
Bet they were a lot cheaper.
post #11 of 12 (permalink) Old 04-01-2017, 16:45 Thread Starter
All sorted
Mike Satur is the guy.
Corresponded with email:
Sale - Mike Satur Ltd [sales@mikesatur.com]
Kevin R
FrKevin is offline
post #12 of 12 (permalink) Old 05-01-2017, 07:34
Car: MG ZT-T
Thats what you wont get from spaxs !
Mr satur is a very helpfull chap, and knows the true meaning of support.
Part Throttle 75 problem nickyburnell Diesel Forum! 2 03-08-2012 22:14
non starting problem part 2 stevie d MG ZT / Rover 75 (Sponsored by Rimmer Bros) 23 29-03-2011 09:00
ABS Problem what part to get Moose2000 MG ZR / Rover 25, 200 & Streetwise 3 21-07-2010 21:27
Part problem John MGF and MGTF (Sponsored by MGFnTFBITZ) 6 25-10-2006 09:45
