Squeaky Front Suspension - MG-Rover.org Forums
post #1 of 8 (permalink) Old 07-04-2009, 09:57 Thread Starter
Car: Pearlescent Green MGF VVC
Send a message via Skype™ to Pud27
Hi Everyone,
My MGF sounds like an old spring mattress and the squeaky noise seems to be coming from the front offside so I assume its something to do with the suspension.
Does anyone have any idea what could be causing this?
Pud27 is offline
post #2 of 8 (permalink) Old 07-04-2009, 09:59
When were the suspension arms last pumped with grease?
post #3 of 8 (permalink) Old 07-04-2009, 10:01 Thread Starter
Not for a while!! I hope its that simple?
Pud27 is offline
post #4 of 8 (permalink) Old 07-04-2009, 10:06
You need a good quality grease gun full of LM grease, locate and clean the nipple the top suspension arm, connect the gun to the niple and pump away until the grease starts to come out of the sides of the arm. This may or may not help but it's a good starting point and will only beneficial.
post #5 of 8 (permalink) Old 07-04-2009, 14:53 Thread Starter
I will try that tonight and hope that's all it needs if not will let you know but many thanks for your kind help so far
Pud27 is offline
post #6 of 8 (permalink) Old 07-04-2009, 20:02
Car: MGF Trophy 160, MG ZS180
Most likely one of the rubber bushes running dry. Lubricate them with some very thin oil, (or dare I suggest WD) then when its sorted, seal it in with something thicker and more durable.
Tim. is offline
post #7 of 8 (permalink) Old 08-04-2009, 09:33 Thread Starter
Sounds ok now with greasing up the suspension arm will repeat it in a couple of weeks to take care of any air pockets.
Many thanks for the good advice to all.
Pud27 is offline
post #8 of 8 (permalink) Old 27-04-2009, 21:23
Car: MG TF 160
Hi, I had the same kinda problem - v bad squeaking from the front off-side! Tried the grease-gun trick, even sprayed everything in the wheelarch (minus the disc and caliper!) daily for three weeks....nothing. In the end had to relent and ask a local garage to sort it. They stripped the suspension completly, regreased everything and volla - a lovely squeak-free car! Honestly, worth every penny!
Tim_mabon is offline
Squeaky suspension glennroy Other Manufacturer models 1 01-05-2007 16:10
squeaky rear suspension. jonrice81 'R8' Rovers (aka Wedges!!) 1 12-09-2006 17:14
squeaky rear suspension jonrice81 MG ZR / Rover 25, 200 & Streetwise 5 09-09-2006 11:33
Squeaky Suspension funkyplates MGF and MGTF (Sponsored by MGFnTFBITZ) 7 08-02-2006 10:35
Squeaky suspension MGTF-Ian MGF and MGTF (Sponsored by MGFnTFBITZ) 4 15-11-2005 07:44
