Stainless Front Subframe Mounts - MG-Rover.org Forums
post #1 of 9 (permalink) Old 30-07-2014, 10:34 Thread Starter
Car: MG TF 160
Like many of our cars my front subframe mounts had seen better days.
So I ordered some stainless ones from ebay and new nuts and bolts from Rimmers.
Rimmers
Below you can see old vs new, some of you might notice a slight difference however….
The bolt from Rimmers is identified for 1998 onwards (my TF is a 52 plate) however its too long. Below is the correct one:
The end result (all greased up as the bolts aren't stainless…)
Reaper is offline
post #2 of 9 (permalink) Old 30-07-2014, 19:46
Woof Woof
Yea. I got SS front mounts too. Used the original bolts again..Hummmm.
barkingdog is offline
post #3 of 9 (permalink) Old 30-07-2014, 20:33
They came out just after I bought the upgraded ones from MS.
I'm always a bit cautious about using Stainless in high stress areas though as it is more brittle. Time will tell I suppose.
post #4 of 9 (permalink) Old 31-07-2014, 09:37 Thread Starter
Car: MG TF 160
Cant be any weaker than the originals that were on there!
Reaper is offline
post #5 of 9 (permalink) Old 31-07-2014, 12:46
Car: Rover 623 GSI
The long bolt looks like it's for the rear mounting on the front sub frame.
plezier is offline
post #6 of 9 (permalink) Old 31-07-2014, 14:22 Thread Starter
Car: MG TF 160
I thought that but Rimmers have item 13 as a different part no. to item 7.
Reaper is offline
post #7 of 9 (permalink) Old 01-08-2014, 07:44
Car: MGF 1.6i
13Bolt-flanged head - Genuine MG Rover
except Trophy OR rear mount to front subframe1800 cc2FB114317MIn stock
£3.04 ex VAT £3.65 inc VATQty: 64989
Trophy OR rear mount to front subframe1600 cc2KYG000110In stock
£1.40 ex VAT £1.68 inc VATQty: - See more at: http://www.rimmerbros.co.uk/Item--i-....w30by15k.dpuf
to me it looks like you have bolts for a 1600 not a 1800 (the longer bolt) on the car - ther part number for item 7 on the rimmers site is KYG000110 - the same as the 1600 setup.
SNA400 is offline
post #8 of 9 (permalink) Old 01-08-2014, 11:13
Did you grind the long bolt off as it was difficult to undo? I have found that the threadlock on these bolts is extremely stiff when cold on an old bolt, to the point it appears almost impossible to turn. Heat it up to about boiling point though (100C) and my front mount bolts came off easily. I reused them as they were OK. Not so the two smaller flange bolts, I replaced them.
nocturneblue is offline
post #9 of 9 (permalink) Old 01-08-2014, 11:20
Car: Audi TT 225 Quatrro
Stainless will be absolutely fine on that component.
Jay13 PNTHR is offline
Rear subframe front mounts will dig MGF and MGTF (Sponsored by MGFnTFBITZ) 8 30-04-2016 06:21
rear,front subframe mounts,lots of fun. rob dunster MGF and MGTF (Sponsored by MGFnTFBITZ) 1 05-05-2014 08:08
front subframe and mounts tf bugsb MGF and MGTF (Sponsored by MGFnTFBITZ) 2 14-03-2013 16:45
TF subframe mounts Littlened MGF and MGTF (Sponsored by MGFnTFBITZ) 1 08-01-2012 15:04
subframe mounts L@@K D4EWE MGF and MGTF (Sponsored by MGFnTFBITZ) 3 12-10-2011 12:20
