sub frame up grade - Page 2 - MG-Rover.org Forums
 5Likes
post #21 of 24 (permalink) Old 12-04-2017, 17:31
Originally Posted by IanMc View Post
The mounts on my '95 F appear to be the originals.
Would early F mounts fit a TF? - if so, are they still available anywhere?
I notice that they are not available from Rimmer Bros.
F ones will fit a TF and give a slightly softer setup. Not sure if they are still readily available but I know my brother bought a new set off ebay recently at a bargain price, there must be old stock out there somewhere, its just finding it
dert is offline
post #22 of 24 (permalink) Old 12-04-2017, 19:39
Originally Posted by TipperMG View Post
That's because they are rubber filled mounts on a F and simple steel fabrications on a TF. Water collects in those on a TF and that's why they rust away! If only MGR had thought through rust protection coatings properly...
That doesn't explain why the larger ones on the TF are in very good condition.
post #23 of 24 (permalink) Old 12-04-2017, 20:27
The larger ones face the opposite way so don't get water ingress into them....drive around everywhere in reverse and you'd soon see them degrade...at least the front ones would still be good though
dert is offline
post #24 of 24 (permalink) Old 13-04-2017, 07:31 Thread Starter
Car: mgtf160
Well I have now got my new sub frame mounts on and the old ones were not too bad the front were a bit more rusty than the back ones and I put new bolts in as well [ 12.9 grade ] two need heat but the others were out with a bit of huff and puff
IanMc likes this.
helsbyman is offline
Best grade of oil? brivtec Diesel Forum! 7 20-08-2011 12:50
Right grade of oil?? simonruss MGF and MGTF (Sponsored by MGFnTFBITZ) 3 25-05-2010 12:04
Oil Grade slj MG ZS / Rover 45 & 400 7 28-12-2006 08:26
Grade my works... shaddsi Car Care & Detailing Forum 11 11-12-2006 22:11
What grade of fuel webbywagon MG ZT / Rover 75 (Sponsored by Rimmer Bros) 6 01-01-2006 15:33
