Subframe mounts MGF - MG-Rover.org Forums
post #1 of 10 (permalink) Old 01-10-2014, 12:27 Thread Starter
Trader Supporter
Car: MGF, Alfa MITO, Volvo C70 and Maserati 3200GT 365bhp
Subframe mounts MGF
What's the dela with subframe mounts on an MGF?
Do they deteriorate? What happens when they do?
How do you fix them?
TT MK7 exhausts for MGF and TF sold out next batch ordered. .
Neil Surrey Lab is offline
post #2 of 10 (permalink) Old 01-10-2014, 12:42
Car: Modified death trap
They don't rot like MGTF ones do.. as the water doesn't get in due to the rubber
The rubber perishes though and can allow for movement
Most people who are looking to 'upgrade' for fast driving/track days swap the F ones for TF solid ones.. as the subframe mounting to the car via solid mounts improves handling
The TF mounts (especially the forward facing ones) however rot for fun
I created my own 'cyberman' mounts... basically TF mounts (brand new) sleeved with 3.4mm seamless tube, spot welded and seam welded into the TF mount for extra strength and will take a lot longer to rot through
Ive also fitted sealed plastic bungs too (no water in, no water out)
Dieseldestroyer is offline
post #3 of 10 (permalink) Old 01-10-2014, 12:46
http://www.mgfregister.org/forum/vie...mounts#p110914
There are stainless ones for sale.. but some debate about how strong they are compared to steel
post #4 of 10 (permalink) Old 01-10-2014, 13:14 Thread Starter
Trader Supporter
The car is a 96 F
I'll check them for rot either metal or rubber. Would their rotting explain the car trying to steer itself under braking and not being stable at high speed on the motorway?
Car is currently hardly driveable
post #5 of 10 (permalink) Old 01-10-2014, 13:35
Car: 1999 MKII MGF
Exclamation
Originally Posted by Neil Surrey Lab View Post
The car is a 96 F
(Possible a stupid question here, but...) have you checked out the EPAS? Sounds a bit like a knackered assistance motor!
Just a thought.
DavesZed is offline
post #6 of 10 (permalink) Old 01-10-2014, 13:42
Car: FunBuggy
Check your rear wheel bearings & play in the rear suspension, ball joints etc. if it's unpredictable handling it is more often the rear rather than the front.
Alan...
Phaeton is offline
post #7 of 10 (permalink) Old 01-10-2014, 21:33
Car: 2001 mgf, 300tdi land rover discovery
when I took the mounts off my MGF the rubber had split all the way round, couldn't tell when they were on the car, I'm in the process of changing mine for some TF ones and following in DD's footsteps have "cyberman'd" mine too as its an awful lot cheaper than buying heavy duty ones that are no better
Wobble is offline
post #8 of 10 (permalink) Old 01-10-2014, 22:16
Car: MGTF
I know that the TF front mounts rot as already mentioned here,but can the rears also rot/wear to allow movement?
Andy Fife is offline
post #9 of 10 (permalink) Old 01-10-2014, 22:29
The rears (4 holes) are thicker to start with.. And as they face backwards don't get anywhere near the same punishment
I've only ever seen fronts rotted away..
post #10 of 10 (permalink) Old 02-10-2014, 12:27
Car: MGTF & R75 Tourer
My rear rotted away and had to be replaced.
Err...That doesn't sound quite right somehow!
RichandPaula is offline
TF subframe mounts Littlened MGF and MGTF (Sponsored by MGFnTFBITZ) 1 08-01-2012 15:04
Subframe mounts gotenks1321 MGF and MGTF (Sponsored by MGFnTFBITZ) 3 10-11-2010 01:16
subframe mounts flyingbanana Wanted 3 01-12-2007 10:51
MGF vs Trophy subframe mounts fuzzyHGF MGF and MGTF (Sponsored by MGFnTFBITZ) 3 16-04-2003 21:57
MGF vs Trophy subframe mounts fuzzyHGF MGF and MGTF (Sponsored by MGFnTFBITZ) 1 14-04-2003 13:24
