Temp issues. - MG-Rover.org Forums
post #1 of 3 (permalink) Old 07-12-2014, 20:12 Thread Starter
Temp issues.
So, had the Tf now for about 4 months, great car, really chuffed, but I sense I have a problem.
When I bought, it, it was suggested that the HG had been replaced, because the colour of the coolant indicated it had been contaminated, oil was fine, and the car ran absolutely fine. It was suggested that I should get the coolant changed, and that's when the problems started.
The heaters do not pump out as much warm air as was expecting,based on my experiences with my F.
The temp gauge (which sits slightly higher than my F did, just above the mark below half way) gets up to speed, quick enough, but sometime, not a hint of warm air comes out, until well into ,my journey.
I bled the front bleed screw today, and a reasonable amount of air came out, so I am hoping that I will see an improvement tomorrow.
My concern now, is I am told that, if you take off the coolant cap, you should be able to see the coolant flowing across the tank as it circulates the system, but it does not, and it has been suggested that I have hgf, but I would be surprised at this, as my problems only started after replacing my coolant.
Sometimes, in traffic, the temp gauge creeps up, and but as I move off, it stabilises.
Celestial 20 is offline
post #2 of 3 (permalink) Old 07-12-2014, 20:37
Stuck in the 80's...
1) Replace the cap.
2) Set the heater to hot and bleed from all THREE bleed points.
IanMc is offline
post #3 of 3 (permalink) Old 07-12-2014, 20:51
Second bleed point is up behind some plastic by the snorkel in the bonnet area, the third is accessible with the engine access panel off - it is just a bleed screw sticking out of a coolant pipe on the pax side(ish).
nocturneblue is offline
Temp and coolant issues R25NWY MG ZR / Rover 25, 200 & Streetwise 2 28-12-2012 09:36
Temp issues is this the jingle valve? Hot air going cold and temp gauge going up trophyblue02 MG ZR / Rover 25, 200 & Streetwise 8 08-11-2012 20:07
engine temp issues Tamim MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 02-12-2010 21:03
temp issues! bourneyo MG ZR / Rover 25, 200 & Streetwise 11 20-01-2010 11:47
Temp Issues badger666 MG ZR / Rover 25, 200 & Streetwise 11 17-05-2008 19:28
