Temperature sensor removal (for Gauge) - MG-Rover.org Forums
post #1 of 4 (permalink) Old 07-10-2016, 10:00 Thread Starter
Unhappy Temperature sensor removal (for Gauge)
Hi guys,
MGF 1998 is it easy to remove the temperature gauge sensor????
or must other things be removed to allow access.
I have no indication on the temperature gauge.
Many thanks in advance
Clive
Mgwanderer is offline
post #2 of 4 (permalink) Old 07-10-2016, 11:02
Stuck in the 80's...
Reasonably easy (in MGF terms).
As usual prepare for dislocation of the fingers, wrists, elbows etc, but it just unscrews.
ps from memory (5-6 years ago), its the brown one for the gauge - but please double check that, and you need either a 17 or 19 mm spanner (with no space to turn it...).
IanMc is offline
post #3 of 4 (permalink) Old 07-10-2016, 12:27 Thread Starter
Thanks Ian
According to the photo from cjj of the engine sensors it would appear to be the other one that is under the pipe and somebody said that the gearbox would need to be removed which I find strange????
post #4 of 4 (permalink) Old 07-10-2016, 21:02
Blue is for the temperature gauge.
Brown or black are for the ECU.
Do not interchange the three, they are incompatible with each other.
Before changing the sender make sure it is faulty by
a) earth the lead and the gauge so go to the red
and
b) check the OBD reading for coolant, after five minutes of running this should show above 88', if it doesn't suspect a thermostat fault.
MGF Temperature Gauge Sensor chrisamayas MGF and MGTF (Sponsored by MGFnTFBITZ) 7 19-02-2016 07:04
Gauge coolant temperature sensor Roverlike MG ZR / Rover 25, 200 & Streetwise 3 30-04-2012 20:31
Fan, Temperature sensor and temperature gauge issues. GWFBall MG ZS / Rover 45 & 400 12 06-07-2011 11:41
Sensor for instrument temperature gauge. bobobrains MGF and MGTF (Sponsored by MGFnTFBITZ) 4 07-01-2007 19:27
Temperature Gauge Sensor DJPLEASURE Wanted 3 25-08-2005 23:15
