Thermal gaskets - MG-Rover.org Forums
post #1 of 8 (permalink) Old 03-09-2013, 08:41 Thread Starter
Car: Modified death trap
Thermal gaskets
Many thanks to Mike at Ferriday Engineering for these
Ordered the exhaust and inlet thermal gaskets
http://www.ferriday.co.uk/gaskets/gaskets.shtml
From Mike for any that are interested
Cost for a Thermal Inlet Gasket is 43.00 in 5.0mm, or 53.00 in 7.0mm thickness, and the Thermal Exhaust Plate is 46.00. But bought together they are 79.00 and 89.00 respectively plus 5.50 P&P UK Mainland. Availability is usually within a few days.
The other item that is available is a TIG for the plenum, cost 34.00 if taken with the others.
All the best Allan,
Dieseldestroyer is offline
post #2 of 8 (permalink) Old 03-09-2013, 08:49 Thread Starter
Ive gone for the 7mm inlet gasket
post #3 of 8 (permalink) Old 03-09-2013, 09:51
I have something similar for the Hyundai's inlet manifold, except mine was made by OBX and is around 4mm. The actual thickness though will be close to 6/7mm when sandwiched between two OEM gaskets.
They work very well, or so I'm told - increasing the runner length shifts the torque curve to the left a tad and they do help keep plenum temps down. Will have it fitted this weekend once my gaskets arrive
Rik420SDi is offline
post #4 of 8 (permalink) Old 03-09-2013, 10:02 Thread Starter
Im running Titan ITBs and there is plenty of room for 7mm gasket..
Every little helps Im thinking
post #5 of 8 (permalink) Old 03-09-2013, 10:11
Car: Audi TT 225 Quatrro
Id be under the impression you'd want as much heat transfer from the head into the exhaust manifold as possible - but thats me.
Thermal gasket on the intake however makes absolute sense.
Jay13 PNTHR is offline
post #6 of 8 (permalink) Old 03-09-2013, 10:30 Thread Starter
You get heat transfer back into the head from the zorst..
The head will still have coolant flow through it..
Will run it with the zorst thermal gasket and see how it does.. worst case senario I can always swap back to a normal gasket
post #7 of 8 (permalink) Old 03-09-2013, 11:22
Funny thing this. When I discussed them last time there was a heated debate that thermal transfer would never happen back into the head. I disagree with this especially on a modified (tuned) engine).
I do have some thermal gaskets somewhere, but I've never fitted them. I might have even given them to Jon when he bought my engine.
post #8 of 8 (permalink) Old 03-09-2013, 12:16 Thread Starter
Clive perhaps yoour Scholar Evo 2 super charged engine wasnt deemed 'tuned or modified' enough lol
thermal gaskets nutjob MGF and MGTF (Sponsored by MGFnTFBITZ) 10 12-02-2013 13:30
thermal windscreen cover mossie MG ZR / Rover 25, 200 & Streetwise 3 18-11-2011 17:19
Thermal Shock msunduzi MGF and MGTF (Sponsored by MGFnTFBITZ) 6 26-02-2009 14:35
KV6 thermal intake gaskets Roverdose MG/R Modification & Tuning 3 03-01-2009 18:43
random thermal shock crross MGF and MGTF (Sponsored by MGFnTFBITZ) 8 25-01-2008 22:03
