Thermal Shock - MG-Rover.org Forums
post #1 of 7 (permalink) Old 26-02-2009, 12:43 Thread Starter
Car: MGF & Onyx Firecat
Thermal Shock
Is this really a cause of HGF???
I had a Rover 400 a few years ago, and I was told it was then.
I took the thermostat out, and drilled a 3/16 hole through the fixed part.
This allows some water to bypass the thermostat, meaning that it will heat up evenly, and there wont be a sudden rush of cool water when the thermostat opens.
Only drawback is that ir takes slightly longer for the engine to warm up.
msunduzi is offline
post #2 of 7 (permalink) Old 26-02-2009, 12:46
you still get a 'rush' of cool water when the stat opens, even with the little hole drilled.
Do a search for PRT...
MyRomeo is offline
post #3 of 7 (permalink) Old 26-02-2009, 13:00 Thread Starter
Do I take it that this is common practice? I hadn't seen it mentioned before.
There may be a rush of "cooler" water when the thermostat opens, but the difference isn't as great, the radiator feels much warmer before the thermostat opens.
I am more used to drilling several 1/4 or 5/16 holes in the fixed plate to get extra cooling in a hotter climate (can't remove the thermostat as it often causes the water pump to cavitate, ending up with less cooling)
msunduzi is offline
post #4 of 7 (permalink) Old 26-02-2009, 13:07
Car: MG TF 160
I have heard good and bad things about the PRT, i think its down to what you think will be best...
Reaper is offline
post #5 of 7 (permalink) Old 26-02-2009, 13:12
That's interesting, I don't think I've come across anything negative about PRT.
post #6 of 7 (permalink) Old 26-02-2009, 13:17
Car: MG TF 160
I been told that because there 'bigger' than the normal pipe that runs there it can rub and then break, my xpart have said they have had to replace many recently.... I havent got one as they persuaded me but then it might be worth asking about; maybe even Russel and see what he says...
Reaper is offline
post #7 of 7 (permalink) Old 26-02-2009, 14:35
Thermal shock is just one small part of the head gasket failure mechanism. Fitting a PRT to Freelander and the later MGs did not stop the failures, but it does ease one of the causes. Drilling a hole through the stat is not the solution to gasket failure.
1955diesel is offline
Thermal exhaust coatings. CJJ MGF and MGTF (Sponsored by MGFnTFBITZ) 11 19-01-2009 21:15
KV6 thermal intake gaskets Roverdose MG/R Modification & Tuning 3 03-01-2009 18:43
T-series thermal gasket Manalishi Rover 600 0 11-10-2008 14:27
random thermal shock crross MGF and MGTF (Sponsored by MGFnTFBITZ) 8 25-01-2008 22:03
Amp goes into thermal overload DAN220SDi In-Car Audio, Entertainment, Sat Nav etc... 38 19-12-2006 19:37
