Third Light - MG-Rover.org Forums
 4Likes
  • 1 Post By steviejones133
  • 1 Post By donshrimpton
  • 1 Post By I-am-spartacus
post #1 of 9 (permalink) Old 16-05-2017, 19:54 Thread Starter
Third Light
Evening,Does any one have any idea what bulbs are fitted in the third light in an MGF Mk 1
I.A.S
I-am-spartacus is offline
post #2 of 9 (permalink) Old 16-05-2017, 20:18
Assuming you mean the high level brake light - they're R284 2.3w bulbs. Google is your friend
http://www.halfords.com/motoring/bul...w-car-bulb-x-1 individually or http://www.ebay.co.uk/itm/MGF-High-L...cAAOxy0x1TUSNy for a complete set and/or spares......
super_cds likes this.
steviejones133 is offline
post #3 of 9 (permalink) Old 16-05-2017, 20:25 Thread Starter
High Level brake light
thanks for the information
post #4 of 9 (permalink) Old 16-05-2017, 20:31
Car: Rover 200 Cabriolet
I recently tried replacing these bulbs and found the contacts in the light fitting temperamental and instead went for one of these LED alternatives. Look at this on eBay http://www.ebay.co.uk/itm/291954235453
Sent from my SM-G920F using Tapatalk
I-am-spartacus likes this.
donshrimpton is offline
post #5 of 9 (permalink) Old 16-05-2017, 20:56
Car: MGF + ZR
are they easy to swap out?
super_cds is offline
post #6 of 9 (permalink) Old 16-05-2017, 21:59
Pretty much, yep. Undo the two screws holding the light assembly to the boot lid. The whole unit will then become free to ease out. Disconnect the connector cable from the rear of the assembly. The light unit should then separate from the black plastic housing and then on the rear of the light unit there are a few screws to undo so that you can gain access to the unit (which is sealed with a rubber gasket to prevent water ingress) and be able to change the bulbs.
The bulbs themselves might need a little wiggle to get them out. Then just a case of replace and reassemble. Might also be worth cleaning the bulb contact points whilst you are at it.
post #7 of 9 (permalink) Old 16-05-2017, 22:05 Thread Starter
Yes simple......remove the two screws that hold the light in,Then with draw it from the boot lid by pushing the wire thru the boot lid Unplug the light,you then need to remove the small screws from the back of the light be aware that there is a central screw that is hidden so you will need to cut out the plastic "plug"then remove the screw.
You then need to prise the red lens from the black cover you then have all the bulbs exposed which just pull out.
To replace is a reverse of this...
post #8 of 9 (permalink) Old 16-05-2017, 22:24
Car: MGF + ZR
got 3 for 3.50 + free post
on carparts4less
code: weekend12
still working prob ends at midnight
post #9 of 9 (permalink) Old 16-05-2017, 23:12
on carparts4less
code: weekend12
I got 7 free from my local scrappie. the 'donor' car had been rear ended and the light was in bits so I dunno if they work yet, I still have to get around to trying them and replace a few of mine that had gone.
Read and reset Engine warning light and Code light most4tune8 MG ZR / Rover 25, 200 & Streetwise 4 12-01-2011 13:16
ZS Reg Light & Rear Driver Side light not working? neilojacko1981 MG ZS / Rover 45 & 400 1 15-08-2010 02:08
Light Bulb Warning Indicator ON - Air Bag light ON & Brake Pad sensor Light ON! Rover-in-Spain MG ZT / Rover 75 (Sponsored by Rimmer Bros) 33 22-07-2010 20:45
3rd brake light/ Tail Light for mgzr/25 spoiler gordy_b Wanted 0 15-09-2008 21:40
fog light wiring loom and button, and light bezels BERTMAN Wanted 0 10-01-2007 13:57
