Is it time to replace Frnt Ball joints - MG-Rover.org Forums
post #1 of 7 (permalink) Old 15-02-2017, 08:27 Thread Starter
pandrew3's Avatar
When I drive into my garage the front suspension on the MGF gives a clunk. I have already replaced the front hubs and bearings with new uprated Lotus Elise units about 1000Km ago. My mate said that sounds like ball joints Peter. If that is the case then the MGTF also makes the same clunk driving over the same lip. The garage lip is less than 50mm high. If I am buying balljoints are they upper or lower and is there any difference between the MGF and MGTF ball joints?
pandrew3 is offline
post #2 of 7 (permalink) Old 15-02-2017, 10:42
jack the car up and grap the wheel at 12 and 6 oclock and try to move it / rock it if it moves you have your answer , if still unsure remove the wheel and stick a bar in where it will move the hub and you should be able to see if it moves or not.
some times a clunk is just a clunk and nothing is wrong but without looking you will never know , or it could just be the lip your going over is loose if it has anything covering it or an insert on it / in it .
Andy400 is offline
post #3 of 7 (permalink) Old 15-02-2017, 12:08
Maybe worth checking the drop links as they can cause a clunk as well
dert is online now
post #4 of 7 (permalink) Old 15-02-2017, 14:52
Car: MGTF115 & Rover25 1.4
Have you greased the inboard pivots on the upper arm?
The front balljoints are common to both.
david.c is offline
post #5 of 7 (permalink) Old 16-02-2017, 00:34
Shock absorber lower bush?
post #6 of 7 (permalink) Old 16-02-2017, 23:38
sundanceuk's Avatar
Car: MG TF 160
Wink
One that throws people.....make sure the spare wheel is secured, if it bumps about under the bonnet, just sound like the suspension is knocking!
Sundance
sundanceuk is offline
post #7 of 7 (permalink) Old 17-02-2017, 01:31
Good point. Have seen this before, well worth a check.
Ball joints!!!! Masterbateson MGF and MGTF (Sponsored by MGFnTFBITZ) 13 31-07-2014 08:25
Ball Joints drewesq MG ZS / Rover 45 & 400 1 15-06-2013 20:20
75 ball joints chris75 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 7 01-11-2011 00:09
Cost to replace and fit front ball joints Irish TF MGF and MGTF (Sponsored by MGFnTFBITZ) 9 28-06-2011 14:00
Tf ball joints madkitty MGF and MGTF (Sponsored by MGFnTFBITZ) 19 31-03-2011 17:27
