Water sloshing/Drain holes.. - MG-Rover.org Forums
post #1 of 13 (permalink) Old 12-06-2006, 15:05 Thread Starter
Car: Honda S2000
For the Archives as it pops up now and again....
If you hear `sloshing`(water) type noises coming from the front of your car, or after a few dry days you are still seeing water dripping out of the area around either of the front mudflaps. (NO other areas as this may be coolant!!) then it is likely the sill drain holes are blocked.....
Well worth checking anyway even if you have noticed no problems as its only a 2 minute job!.
Screwdriver shows location of the front holes....... rears are the same only opposite end!...... as the F and TF share the same platform both cars `should` be the same.. (my F and TF are).
Mark.L is offline
post #2 of 13 (permalink) Old 12-06-2006, 15:28
Car: Mazda MX-5 2.0 Sport Tech Roadster Coupe
That's a very swift transit from one place to another!
Nigel (aka Nigel H)
LeginTF is offline
post #3 of 13 (permalink) Old 12-06-2006, 15:32
All we need now is a section to put it in...........
.......btw Mark, I see some missing underseal
post #4 of 13 (permalink) Old 12-06-2006, 15:41 Thread Starter
Car: Honda S2000
I know Pete!.
Been trying to get the TF down to the Bro-out-Laws garage for a underbody steam clean and Waxoyl.......... just not found the time!.
Getting a new Exhaust in the next week or so, and looking at the cat nuts I think this will be a job for His garage as well........ hopefully get the underbody done at the same time!!
Mark.L is offline
post #5 of 13 (permalink) Old 12-06-2006, 19:40
Car: MG TF 160
Hmm. That's a thought. My year old TF is as it left the factory. What sort of undersealing do you think would be a good idea, Pete (or anyone else)???
Chris P is offline
post #6 of 13 (permalink) Old 12-06-2006, 21:46 Thread Starter
Car: Honda S2000
Depends!.
You will allways get some chipping of the underbody protection its just a case of checking and touching up `as and when`..
If you plan to keep the car it may well be worth getting it waxoyled..... in particular the front end, suspension, chassis legs and behind the wheel arch liners!.
See.. Project TF update........ with pic`s
Mark.L is offline
post #7 of 13 (permalink) Old 12-06-2006, 23:11
Car: MG TF 160
Thanks, Marl.
Chris P is offline
post #8 of 13 (permalink) Old 19-04-2012, 13:22
Sill drain holes
I had this problem on my car, but I just could not get any water to come out of the drain holes, even though I could hear it sloshing about. The problem was the screwdriver I was using to poke the holes was too big. I solved the problem and got the water out by poking the hole with a bent paper clip. The diameter of the sill drain holes is very small.
Job done, the paper clip poking caused the water to pour out in a very satisfying way.
goldfinger is offline
post #9 of 13 (permalink) Old 19-04-2012, 22:25
Good tip
post #10 of 13 (permalink) Old 20-04-2012, 19:05
I do not know what to say.....
Julian Foulger is offline
post #11 of 13 (permalink) Old 24-04-2012, 04:50
.....he's the man, the man with the golden touch ?
ROVER-25X is offline
post #12 of 13 (permalink) Old 14-05-2012, 00:05
Thinking how mashed are cills are they'll probably be closed up
Carl is offline
post #13 of 13 (permalink) Old 16-05-2012, 04:50
Drain holes Fast Jan MGF and MGTF (Sponsored by MGFnTFBITZ) 8 03-12-2007 20:41
Those drain holes once again thetruckshop MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 18-01-2007 20:04
Where are all the drain holes? waynefeltham MG ZS / Rover 45 & 400 3 12-12-2006 12:41
drain holes wattalan MG ZT / Rover 75 (Sponsored by Rimmer Bros) 17 11-08-2006 22:12
Drain Holes !!! stevereid MG ZT / Rover 75 (Sponsored by Rimmer Bros) 6 03-08-2006 22:12
