What have you done to your MGF MGTF today? (Second Part) - Page 13 - MG-Rover.org Forums
 88Likes
post #241 of 327 (permalink) Old 18-04-2017, 10:36
batoutofhull's Avatar
Originally Posted by Celestial 20 View Post
Took her home!
20170415_173123000_iOS by Jim Pritchard, on Flickr
Pilgrimage? me thinks.
batoutofhull is offline
post #242 of 327 (permalink) Old 18-04-2017, 11:05
Car: MG TF 135 Spark
Took her home!
Great colour car looks superb
Katrew is offline
post #243 of 327 (permalink) Old 18-04-2017, 11:23
MGJohn's Avatar
Cool
Agreed! So puzzling that there are far more MGs and Rovers in dull as ditchwater colours like XPGrey.
I suspect dealership stock ordering colour preference blindness.
MG and Rover had some really special colours in their range. Not just the sooper-dooper variable colour change ones but the ordinary solid and metallic vibrant ones.
I've seen Rover 25s and 45s locally in that superb blue and they really look special to my old minces...
B>>M>>W ....
MGJohn is offline
post #244 of 327 (permalink) Old 18-04-2017, 12:37
Thanks!
It's a Celestial Blue, one of the Monograms. Not a "flippy" paint, but "supertallic", which is great, as the paint is not stupidly expensive.
Celestial 20 is offline
post #245 of 327 (permalink) Old 19-04-2017, 21:32
Car: MGF VVC MK2
DeathFromAbove is offline
post #246 of 327 (permalink) Old 20-04-2017, 06:48
Stuck in the 80's...
I see you have a gas strut fitted there DFA - would you recommend it/them?
If so, which one did you buy and did you buy the mounting bracket also or make your own?
IanMc is online now
post #247 of 327 (permalink) Old 20-04-2017, 07:14
Car: MGF VVC MK2
I've bought them from MGManialtd, bracket were included.
They are SS... and a bit of a mixed bag...
++ They are very robust and so much better than the stick. Touch the bonnet and it fly to heaven
- You need to hammer the bonnet to make it sit flat (I did a bit of messy job... and is not completely flat anyway)
- They are rusting :/
post #248 of 327 (permalink) Old 20-04-2017, 19:17
Car: MGF VVC MK2
So... Finger crossed my new Oil Funnel fixed the oil leak. For now....
post #249 of 327 (permalink) Old 24-04-2017, 08:10
I'm needing myself a set of those!!
Cheers.
esotericman1967 is offline
post #250 of 327 (permalink) Old 26-04-2017, 14:34
sundanceuk's Avatar
Car: MG TF 160
Finally got around to prepping up my nice red powder coated cam cover ready for fitting.
The mating edges all needed a proper scrape to get rid of excess paint, old gasket media and to generally square it all up again, its surprising just how uneven the face of the cover was, but a good hour with a machine bed scraper sorted it out.
Also while I was at it, decided to re-tap the threaded holes on the top where the coil packs bolt, and decided to helicoil them, as I have never liked steel pins in alloy threads anyway.
All ready to fit and hopefully will cure a very tiny oil seep between the cover and the head.
Sundance
sundanceuk is offline
post #251 of 327 (permalink) Old 28-04-2017, 18:31
Car: Rover 75 CDT, Metro 116,MGF VVC,Mrs JoCoLo's Panda 1.2 and Mstr JoCoLo's TF 115
Today I found out my MGF isn't really Nightfire Red, underneath it's Solar Red. It's been resprayed, very well but I want it original.
JoCoLo is offline
post #252 of 327 (permalink) Old 28-04-2017, 21:29
In the brief period between getting home and having supper I tried getting all four corners of the front subframe transplant bolted up and have come to the conclusion that the front end is slightly twisted
post #253 of 327 (permalink) Old 28-04-2017, 21:34
Noooooooooooo! - nightmare.
IanMc is online now
post #254 of 327 (permalink) Old 29-04-2017, 08:07
One of the bolt holes is a fraction out and there is evidence of panel replacement when viewed from underneath and of the three windscreen surround panels one is gloss and two are matt.
But I've had her for six years with no feeling of her not driving true so I will get her tracked and we should be fine.
IanMc and Mikeadman like this.
post #255 of 327 (permalink) Old 29-04-2017, 17:25
sundanceuk's Avatar
Car: MG TF 160
All four brake calipers serviced ready for the MOT on Tuesday, glad to see the pads have about another 12 months on them, so next year will swap the calipers for my spare refurbed set and fit my new EBC Ultimax pads.
Also finished treating my rear subframe with rust killer and sparayed up with black underseal paint. Also did a bit on the front subframe where it needed it.
While the wheels were off, took the opportunity to clean the inside rims properly.
Just need to adjust my handbrake cable tomorrow and then its ready for the test!
Sundance
Mikeadman likes this.
post #256 of 327 (permalink) Old 30-04-2017, 08:40
Car: MGF VVC MK2
Driven to Cornwall ...
post #257 of 327 (permalink) Old 30-04-2017, 14:41
Managed to get all for mounts done up only to find that the F rear mounts only have 3 bolt holes while the TF ones have 4 so I'm either going to have to
1)swap to TF solid mounts
2)flip the F mounts over
3)drill the forth hole in the F mount.
All assume the forth hole is there in the chassis and so I can fit the TF subframe cross brace.
Then there was a F1 and ran stopped play.
post #258 of 327 (permalink) Old 30-04-2017, 14:43
Oh, d I discovered I need to drill holes to allow the top shock mounts room and the front air dam is a nightmare to get back on.
post #259 of 327 (permalink) Old 02-05-2017, 14:17
Full cambelt service and the boot wiring harness repaired by Jon and Claire of Rough Luck Racing. They did a superb job - full of praise for their work.
Katrew is offline
post #260 of 327 (permalink) Old 02-05-2017, 14:41
sundanceuk's Avatar
Car: MG TF 160
MOT today, pass and no advisories, thanks mainly to all the how to's on here and elsewhere!
What have you done to your MGF MGTF today? (First Part) MGJohn MGF and MGTF (Sponsored by MGFnTFBITZ) 3239 27-08-2016 09:29
MGTF - Part Number for Pipe loones MGF and MGTF (Sponsored by MGFnTFBITZ) 1 31-05-2016 23:45
MGTF Pleeease Help my find a part !! tina MGF and MGTF (Sponsored by MGFnTFBITZ) 2 02-03-2006 18:54
