Wheel bearings - MG-Rover.org Forums
post #1 of 7 (permalink) Old 16-02-2017, 11:43 Thread Starter
Car: mgtf160
Wheel bearings
Hi all
I don't know if it is just bad luck but my mot in 2015 was a fail thanks to a duff wheel bearing which in turn had damaged the hub so bearing AND hub to replace 60 for the parts. Come 2016 the same again failed wheel bearing + damaged hub and again 60. So being a good christian [tight ] I thought it is obviously cheaper to replace the wheel bearings on the 2 other wheels 30 before this years mot
So replace your bearings now @15 x4 or pay 55 x 4 for hubs also
helsbyman is offline
post #2 of 7 (permalink) Old 16-02-2017, 15:14
Car: MGTF115 & Rover25 1.4
Do you mean drive flanges when you say hubs.
Our sponsors can do new drive flange and bearing kit for jest under 60 each post free.
david.c is offline
post #3 of 7 (permalink) Old 16-02-2017, 17:12 Thread Starter
Car: mgtf160
Hi Yes I mean flanges [ I think ] The part that the bearing gets pressed into and has the wheel studs on
60 is about right I paid 45 + 13:50 inc post
post #4 of 7 (permalink) Old 17-02-2017, 01:56
Did you buy new or second hand?
post #5 of 7 (permalink) Old 18-02-2017, 11:21 Thread Starter
Car: mgtf160
Always new, second hand wheel bearings? [ don't see the point in buying another somebody's problems ]
post #6 of 7 (permalink) Old 18-02-2017, 18:49
Woof Woof
What's the matter with these cars and wheel bearings. I can't remember the last time I had to change one, if ever.
barkingdog is offline
post #7 of 7 (permalink) Old 18-02-2017, 20:44
you havent lived then barkingdog. i think. the main killer of wheel bearings in the F , is failing and consequentially hard hydragas, and potholes.
the wheel then has to absorb the shock of bad road surfaces, because the suspension isnt...
it means that tyre pressure becomes the absorber of shock, and when it doesnt the tyre compresses and hits the wheel rim.. that shock is transmitted to the wheel. which dents, and the wheel bearing which degrades..
one can hear a grumbling wheel bearing, its got a rotational thrum... it gets louder as the bearing structure fails, and the steering as consequence begins to loose its precision..
in its worst phase, the wander of the wheel, starts to affect the brakes , the brake discs and pads...
the car becomes a fragile thing.
if the suspension cant absorb the shock... everything in that line cant give it to the suspension.. and has to take it.
wheel bearing grumble is one of the first signs... but an mot failure on a dented wheel. is another. an unbalanced wheel will kill a wheel bearing like tapping it with a hammer until its bearings fall out.
Incony is offline
Wheel Bearings bigwigsdad MGF and MGTF (Sponsored by MGFnTFBITZ) 5 07-02-2013 21:46
Wheel bearings. CJJ MGF and MGTF (Sponsored by MGFnTFBITZ) 27 16-09-2012 00:01
Wheel bearings. CJJ MGF and MGTF (Sponsored by MGFnTFBITZ) 8 08-11-2010 19:56
wheel bearings smokie999 MGF and MGTF (Sponsored by MGFnTFBITZ) 9 14-04-2009 17:59
