Wind noise, anything I can do? - MG-Rover.org Forums
post #1 of 13 (permalink) Old 27-04-2015, 20:23 Thread Starter
Hey guys, I am having a hard time hearing myself think, talking to my partner or even listening to the radio when driving at over 30MPH.
Is there anything I can do to stop the wind whisteling in through what sounds like the windows and behind me somewhere?
Thanks!
Luke
lukebolger is offline
post #2 of 13 (permalink) Old 27-04-2015, 20:30
One easy to fix problem is when the front of the soft top doesn't mate properly with the rubber seal. I lift the roof off the seal, smear a very small amount of vaseline thinly on the rubber seal, then wipe it with a cloth and then latch the roof back in position again. That seems to get the seal back to normal. There is also adjusting the two latches as well of course.
Not sure about the windows, maybe someone else can help.
nocturneblue is offline
post #3 of 13 (permalink) Old 27-04-2015, 21:00
Woof Woof
Thanks!
Luke
Buy a Lexus.
barkingdog is offline
post #4 of 13 (permalink) Old 27-04-2015, 21:13
Stuck in the 80's...
Originally Posted by barkingdog View Post
Buy a Lexus.
That actually made me laugh out loud, 10/10
IanMc is offline
post #5 of 13 (permalink) Old 28-04-2015, 09:31
Car: 02 TF 135 Trophy Blue
Wind the windows down and drop the hood as a quick fix?
Sharpleyman is offline
post #6 of 13 (permalink) Old 28-04-2015, 11:26 Thread Starter
Apart from me buying a japanese Mercedes....
Ill try the vasaline
post #7 of 13 (permalink) Old 28-04-2015, 11:31
Car: Rover 623 GSI
I believe that getting the hood and windows adjusted correctly .............................. maybe even renewing some seals will make a lot of difference. Many MGF's have poorly fitted hoods and poorly adjusted windows.
plezier is offline
post #8 of 13 (permalink) Old 28-04-2015, 11:59
Thanks!
Luke
Surely fixing the issue is a double-edged sword. On the plus side, you'll be able to hear the radio. On the minus side...
JensenHealey is offline
post #9 of 13 (permalink) Old 28-04-2015, 12:32
Fixing the hood gaps behind the dorr would be impossible I should think, although there is some adjustment in that area and you might improve it - there was a thread on this last year. I don't notice it to be honest.
I do notice moise from the front seal or windows.
There is a tiny gap where the window meets the seal at the point where the top of the window glass breaks direction. If you have more gap than that, maybe the windows have tilted on their stops? You could check by smearing something like zinc oxide (white) cream on the top of a partly lowered window, then raising it, then lowering it again and seeing whether the zinc oxide cream forms an unbroken line of the seal.
The rubber hood/window seal can get a bit tired over time apparently and there was a thread not so long ago (more to do with water ingress) that suggested plumping up the seals by inserting a sort of nitrile(?) rubber tube into the channel that runs through the middle of the seals.
post #10 of 13 (permalink) Old 28-04-2015, 16:52
Car: 04 Rover 75 Connie Tourer in XPower Grey, 04 MGZT+ 1.8 Turbo in Trophy Yellow.
You drive with the hood up?
673NN is offline
post #11 of 13 (permalink) Old 29-04-2015, 08:57
That was my thought
When I first had a new hood, bought and fitted at BAS, it made a noticeably massive difference compared to the old, oem hood which was, I don't know six or seven years old at that point (I had to drive it home with the hood up - it was snowing). It did feel and sound more like driving a normal car in the cabin.
Not to say a new hood is what you need but it goes to show what a well fitted hood and rubbers can do.
You can also get a Hood Liner for the soft top which people who've had it seem to like and think it does reduce noise. TF Spark LE and hood
Bromsgrove man is offline
post #12 of 13 (permalink) Old 29-04-2015, 11:10
Car: Rover 75, Morris Ital, MGF, Rover Metro
Wind noise only bothers me over.... oh, better not post that!
Sumo is offline
post #13 of 13 (permalink) Old 29-04-2015, 11:22
Car: MG TF 115 03 plate (50K miles) 1.6 K Series in Royal Blue (code JFM,I think).Now all TT'd up.
I think there are tablets out there nowadays for that type of complaint.
50p_millionaire is offline
wind noise mg zr rocpara Introduce yourself 1 10-04-2015 19:31
r45 do wind deflectors improve wind noise window up lee-d MG ZS / Rover 45 & 400 5 26-02-2015 17:36
MG ZR Wind Noise ceeghb MG / Rover Related Chat - up to 2005 19 16-09-2010 10:19
Wind Noise. Celestial 20 MGF and MGTF (Sponsored by MGFnTFBITZ) 7 15-12-2008 18:06
Wind Noise barnardo MGF and MGTF (Sponsored by MGFnTFBITZ) 2 29-10-2007 21:37
