Work time estimage - MG-Rover.org Forums
post #1 of 9 (permalink) Old 13-05-2017, 08:45 Thread Starter
Car: MGF VVC MK2
Work time estimage
Here is a bit of game.
This is the list of works I aim to complete this weekend (now raining...), along an estimate in time.
What's yours time estimate?
* Anti-rollbars nuts/washers change (2.5h)
* Exhaust hangers change (2h)
* Engine screws tightening (1.5h)
* Clutch bleed (0.75h)
* Replace lost clutch cover on bleed nipple
* Add missing screws to stop engine rattle (0.3h)
* Handbrake tightening (0.3h)
* Check and add brakes oil (0.1h)
* Rear hood seal refurbish (1h)
* Window alignment (1.5h)
* Window seal fixing (2h)
* Fit door cards holders (O/S door) (0.5h)
* Clean and moisture squeaking leather seats (0.75h)
* Moisture steering wheel (0.2h)
* New battery clamp fitting (0.2h)
* Fit MG badge ring on dashboard (0.2h)
DeathFromAbove is offline
post #2 of 9 (permalink) Old 13-05-2017, 10:06
<<<snip>>>
Time to post thread - priceless..........
post #3 of 9 (permalink) Old 13-05-2017, 10:21 Thread Starter
Car: MGF VVC MK2
I still miss some of the British humor...
post #4 of 9 (permalink) Old 13-05-2017, 13:42
Stuck in the 80's...
Its an MGF - therefore add 50% of time to all 'small' jobs, then 350% to any 'big' job.
That way you wont be disappointed when you don't get to end of your list this weekend
IanMc is offline
post #5 of 9 (permalink) Old 13-05-2017, 23:57
I had a quote to swap the front subframe of four hours, it has taken me four months so far.
post #6 of 9 (permalink) Old 14-05-2017, 01:11
Car: FunBuggy
And that's only the 1st bolt?
Phaeton is offline
post #7 of 9 (permalink) Old 14-05-2017, 07:49
Yeah, double it and add 42 hours for all those jobs you haven't found yet.
post #8 of 9 (permalink) Old 14-05-2017, 09:47 Thread Starter
Car: MGF VVC MK2
Ok, so he took me 3 hours the following (including bringing all the tools up/down):
* Engine screw tightening (cam cover and HT cover)
* Clutch bleed
* New clutch bleed nipple cover (can be fiddly...)
* Added screw to exahust menifold shield and to engine bay cover (rattle still there...)
* Rear hood seal refurbish: happy with the seal and look of it
I miserably failed in:
change battery clamp
adjust handbrake cable
post #9 of 9 (permalink) Old 14-05-2017, 18:52
Thumbs up
Good start. You'll have to reserve another weekend for working on the car..
Finished work, TF time........ Red Devil MGF and MGTF (Sponsored by MGFnTFBITZ) 18 28-12-2008 21:21
time to work geodark MGF and MGTF (Sponsored by MGFnTFBITZ) 3 04-08-2008 07:55
does the turbo work all the time? alek MG ZR / Rover 25, 200 & Streetwise 7 29-11-2006 14:06
