How to use K-Seal - MG-Rover.org Forums
post #1 of 52 (permalink) Old 16-01-2011, 12:42 Thread Starter
Banned
Car: 1998 Rover 216 SLi, and my 1997 Ford Fiesta Ghia 1.25!
Send a message via MSN to jmurray01 Send a message via Yahoo to jmurray01
Question How to use K-Seal
Am I right in thinking this is how to use K-Seal ?
Pour 50:50 Anti-Freeze/Deionised water into a bucket, shake K-Seal, pour entire bottle into the bucket and mix.
Pour into cooling system, bleed (after trying to get rusty clips off hoses ), job done!
jmurray01 is offline
post #2 of 52 (permalink) Old 16-01-2011, 12:45
Send a message via AIM to Ex-MG Send a message via MSN to Ex-MG
No you don't do that, you get instructions, I think you have to run it to engine is hot, turn it off and then put it in, it doesn't work anyway, my dad used it on his Renault Scenic and it didn't work.
Ex-MG is offline
post #3 of 52 (permalink) Old 16-01-2011, 12:48 Thread Starter
Banned
I don't really care if people think it works or not, I just want to know how to use it.
And thank you, I'll wait until I buy it then read the instructions then.
However if you have to warm the engine up first surely you would have to remove some coolant to make room for the K-Seal ?
post #4 of 52 (permalink) Old 16-01-2011, 12:57
Formerly MGTurbo#261
Car: ZTT190, ZS180, P38 V8 Range Rover, V8 Discovery 1, MG Maestro Turbo
Originally Posted by jmurray01 View Post
Oh **** off if you're not going to help.
Yes hold on you have just dropped something out of your pram
But if you google K-Seal (Remember google it can turn up all sorts of things)
You find the K-seal site and low and behold they have instructions .. Well roger me with a broom handle, fancy that.
Just in case you still have a fear of google, I have done it for you ....
K-SealŪ is simple to use:
  • Shake bottle vigorously (at least 30 seconds) to ensure that the contents are evenly mixed.
  • Add the entire contents to the radiator or overflow tank. (When adding K-SealŪ to the overflow tank, pre-mix the contents with 1 to 2 litres of water to ensure effective dispersal into the cooling system. Allow time for the product to enter the cooling system if you are treating a slow leak. Do not pour K-SealŪ directly onto metal).
  • The leak will stop within 1 to 3 minutes once the engine has reached operating temperature.
  • Top up the coolant as necessary leaving the K-SealŪ in the system for future sealing. K-SealŪ is compatible with all types of antifreeze.
Edit .. Thanks for the rep JMurray01 .. You really need to get out more
.. Touche
SN1958 is offline
post #5 of 52 (permalink) Old 16-01-2011, 13:00 Thread Starter
Banned
Yes, but if you have to warm the engine up, you will need the coolant to be over the MIN mark, and if it is, adding 1-2 litres of water & K-Seal will overflow it!
post #6 of 52 (permalink) Old 16-01-2011, 13:01
That's it.
Ex-MG is offline
post #7 of 52 (permalink) Old 16-01-2011, 13:03
RTFI .. You need to remove 1-2 litres with it cold, mix in the K-Seal and add it back then bring up to operating temperature. It needs to be well mixed into the colling system to have any chance of working. Look at the K-Seal website it explains all and the theory behind how it should work.
SN1958 is offline
post #8 of 52 (permalink) Old 16-01-2011, 13:05 Thread Starter
Banned
But Steven said to add it with the coolant at operating temperature.
post #9 of 52 (permalink) Old 16-01-2011, 13:06
Yer our instructions said differently, they changed the instructions .
Ex-MG is offline
post #10 of 52 (permalink) Old 16-01-2011, 13:07 Thread Starter
Banned
So what is right!?
Add when cold, or add when hot ?
post #11 of 52 (permalink) Old 16-01-2011, 13:09
So what is right!?
Whatever it says on their instructions.
Ex-MG is offline
post #12 of 52 (permalink) Old 16-01-2011, 13:10
Car: VVC Coupe
Send a message via MSN to Randyjim
Buy some and then read the bottle.
Randyjim is offline
post #13 of 52 (permalink) Old 16-01-2011, 13:11 Thread Starter
Banned
But if it says on the bottle what it says on their website that is as much use as a chocolate tea-pot!
post #14 of 52 (permalink) Old 16-01-2011, 13:13
A chocolate teapot can be quite useful if you like chcolate and dont like tea ...
I dont see what is confusing the website clearly gives all the details you need, unless you want them to develop a version that you undo the bottle and it just applies itself to the car for you while you stand back and watch ? Maybe drop them a line to suggest that ?
SN1958 is offline
post #15 of 52 (permalink) Old 16-01-2011, 13:16 Thread Starter
Banned
What I mean is, do I have to add it to cold or hot coolant!?
And if I have to add it to cold coolant, why not just add it to the mixture in the bucket then pour the whole lot in in one go ?
post #16 of 52 (permalink) Old 16-01-2011, 13:17
It will be the same as the website, we used the stuff about a year and a half ago.
Ex-MG is offline
post #17 of 52 (permalink) Old 16-01-2011, 13:18
Car: VVC Coupe
If you have to add the k-seal and then warm the engine up surely you would have to remove some coolant to make room for the K-Seal?
Randyjim is offline
post #18 of 52 (permalink) Old 16-01-2011, 13:24
The instructions indicate from cold and then bring the engine up to normal temperature, it only works when the engine gets to normal temperature. You need to removed 1-2 litres and mix this with the K-Seal so it enters the coolant system and doesnt just sit in the expansion tank. Its not rocket science, you just need to get the contents of the bottle to be circulating round the coolant system and the theory is this will go into the leaking area and the particles in the K-Seal will plug it up.
SN1958 is offline
post #19 of 52 (permalink) Old 16-01-2011, 13:25
Car: VVC Coupe
What is the point of asking for advice then?
You think the bottle and the website are wrong, yet when people suggest something else you moan that 'thats not what it says on the bottle'!
According to the website 'The leak will stop within 1 to 3 minutes once the engine has reached operating temperature'.
That suggest to me that you need to warm the engine up after the K-Seal is added. In order to be able to waarm something up, it must be cold to start with.
Add K-Seal to a cold system.
You need to mix it with 1-2 litres of water (Hint: mix it in a clean 2 litre pop bottle). Then add it to the COLD engine.
If you can't fit the 1-2 litres of K-Seal in the tank, you will need to drain off some of the coolant. To do this use a Bellend, there is one next to your keyboard!
Randyjim is offline
post #20 of 52 (permalink) Old 16-01-2011, 13:28
A what?
Ex-MG is offline
Looking for exterior door trim/seal/strip for MGF ("Outer waist seal"?) ohansen MGF and MGTF (Sponsored by MGFnTFBITZ) 2 02-12-2008 19:58
Rover 600 rubber door seal, can I use a Rover 400 rubber seal istead? megmeg Rover 600 10 28-06-2008 15:55
Rover 600 rubber door seal, can I use a Rover 400 rubber seal istead? megmeg Rover 800 0 19-05-2008 10:24
mg zr door seal and sunroof seal irish pa MG ZR / Rover 25, 200 & Streetwise 1 12-01-2008 15:49
