PG 1 Gearbox Oil - MG-Rover.org Forums
post #1 of 8 (permalink) Old 23-03-2006, 17:37 Thread Starter
PG 1 Gearbox Oil
Hi
I need gearbox oil for my 160 gearbox. I know that it is mtf94. But my local factors don't stock it. They have contacted miller oils for me. and millers say that it is the same as 10w40 engine oil? Is this true??????
Gruntilla is offline
post #2 of 8 (permalink) Old 23-03-2006, 17:52
Car: Rover 420 (95-99)
"and millers say that it is the same as 10w40 engine oil?"
If that is so, rover would have put synthetic oil in it would they have not. tell you what .Ive just opened my can of it ...and it smells like nothing Ive ever smelt before..slight strawberry smell to it..so it cant be normal engine mineral oil ....maybe it is something synthetic.
all the best..mark
aboard_epsilon is offline
post #3 of 8 (permalink) Old 23-03-2006, 17:53
Car: 420 SDLi
No it's not. www.75andztclub.com click Dealer Locator.
Fodenman is offline
post #4 of 8 (permalink) Old 23-03-2006, 17:56
The PG1 box fitted to maestros and montegos are 10w40 however they have an oilchange interval of 40k miles. MT95 is very similar and infact for top up purposes many manuals say 10w40 is the stuff to use. I'd try getting the right stuff if you can, but if you are just topping it up then good quality 10w40 should be fine.
post #5 of 8 (permalink) Old 23-03-2006, 18:04 Thread Starter
Thank you all
I'm changing it so i'll try and hunt some mtf94 down. unless many of you think different?
post #6 of 8 (permalink) Old 23-03-2006, 18:09
Richard Moss
Guest
Posts: n/a
I used SAE80 gear oil in my 820- it's been fine.
post #7 of 8 (permalink) Old 24-03-2006, 18:45
Car: MG ZS+ TD135+
I used Redline MTL in my ZR TD. Looked up the specs and it is compatible. Meant to be good stuff.
No problems with stiff shifting on a cold morning.
Seen some ridiculous prices of over 20/litre, but it is 11 for 946ml here: http://www.fluke-motorsport.co.uk/pr...roducts_id=137
If someone is running a 220 Turbo or chipped diesel (I know you're not), might be worth using, due to the high torque
SDI_Tim is offline
post #8 of 8 (permalink) Old 24-03-2006, 19:05
Car: Rover 400 (-95)
my gearbox has semi-sythetic engine oil in it, works fine.
Ben959 is offline
PG! gearbox and castrol smx s touche MG ZR / Rover 25, 200 & Streetwise 12 05-09-2008 01:19
214si 16v Engine Oil, Gearbox Oil SplateKseries MG ZR / Rover 25, 200 & Streetwise 4 05-06-2007 18:39
200 Vi's PG-1 gear box... redVi MG ZR / Rover 25, 200 & Streetwise 7 27-01-2007 08:34
PG 1 gearbox bearings and bits theskrebs Others 0 06-05-2005 20:08
Gearbox 620DI topped up with gearbox oil *Victor* Rover 600 4 13-08-2004 19:58
