quiz - MG-Rover.org Forums
post #1 of 18 (permalink) Old 26-11-2005, 08:54 Thread Starter
Car: Ford mondeo
Send a message via Skype™ to griffmonster
quiz
this had a garage beat and two days for me
mates 820 starts but cuts out shrotly after
winning answer wins a virtual
Bollinger
griffmonster is offline
post #2 of 18 (permalink) Old 26-11-2005, 08:55
Crank Sensor?
post #3 of 18 (permalink) Old 26-11-2005, 08:56 Thread Starter
Car: Ford mondeo
not that but sort of
post #4 of 18 (permalink) Old 26-11-2005, 08:57
How long would it run for before cutting out?
post #5 of 18 (permalink) Old 26-11-2005, 08:58 Thread Starter
Car: Ford mondeo
seconds approx 10 ish
post #6 of 18 (permalink) Old 26-11-2005, 09:03
Car: 2004 MG ZR 120+
..blocked fuel filter, or installed upside down if thats possible?
misterreliable is offline
post #7 of 18 (permalink) Old 26-11-2005, 09:05 Thread Starter
Car: Ford mondeo
more simple than that but surprised me only sorted it with substition method
post #8 of 18 (permalink) Old 26-11-2005, 09:08
Car: 420 SDLi
Throtle poss sensor?
Fodenman is offline
post #9 of 18 (permalink) Old 26-11-2005, 09:14 Thread Starter
Car: Ford mondeo
na but getting there with sensing stuff
post #10 of 18 (permalink) Old 26-11-2005, 09:16
Car: 420 SDLi
ECU temp sensor?
Fodenman is offline
post #11 of 18 (permalink) Old 26-11-2005, 09:18 Thread Starter
Car: Ford mondeo
very close but not that
post #12 of 18 (permalink) Old 26-11-2005, 09:39
Car: 420 SDLi
This may not be close but only thing left I can think of re idle/stalling is air flow sensor.
Fodenman is offline
post #13 of 18 (permalink) Old 26-11-2005, 09:39
Car: Vauxhall 'Serious Business' Omega
Inlet manifold sensor........ crapping out then causing idle valve to shut (or open) too much killing the AFR hance stopping engine...??
Vincero is offline
post #14 of 18 (permalink) Old 26-11-2005, 09:46 Thread Starter
Car: Ford mondeo
I know this did surprise me but it's not those,only few left to guess now
post #15 of 18 (permalink) Old 26-11-2005, 10:26
Car: 420 SDLi
Air intake temp sensor?Is this a PGM set up?
Fodenman is offline
post #16 of 18 (permalink) Old 26-11-2005, 10:33 Thread Starter
Car: Ford mondeo
ok ok ok I'll tell ya OIL pressure switch!! only changed it in desperation and it worked!! Im guessing that it's feed in the ecu rather than staight to the dash lamp maybe as a safety measure, only it did'nt run for long enough to think about looking at the dash any new rovers like that? or just this one?
post #17 of 18 (permalink) Old 26-11-2005, 10:39
Was this an early 820?
Same used to happen on Montego/Maestro
post #18 of 18 (permalink) Old 26-11-2005, 11:10
Car: Mini (The real one)
stepper motor needs re-setting first. on ignition II with the engine NOT started, pump the throttle flat to the floor and back 5 times then try and start it. If this doesn't work, check for all electrical connectors that could be damp with water or oil.
HTH
Steve
Steve220 is offline
Quiz For You Haxx MG ZT / Rover 75 (Sponsored by Rimmer Bros) 30 04-06-2006 08:55
A little quiz! Interloper MG / Rover Related Chat - up to 2005 2 27-10-2005 21:50
