rover 200 fuel economy - MG-Rover.org Forums
post #1 of 23 (permalink) Old 07-07-2004, 17:56 Thread Starter
Smile rover 200 fuel economy
hello i was just wondering how many miles should i normally expect out of a standard rover 200 ?
i'm getting around 70 to 80 miles out of a tenna
at 79.9 pence per litre
thats 12.52 litres
70 to 80 miles per 12 to 13 litres of unleaded
my brother reckons it should be around 90 to 100 easily
thanx
MACKA
macka_smacka is offline
post #2 of 23 (permalink) Old 07-07-2004, 17:56 Thread Starter
economy
oh by the way its a 1.4 16v 1998
silly me
post #3 of 23 (permalink) Old 07-07-2004, 17:57 Thread Starter
economy
here i go again its done 47k and hasnt had the head gasket gone
(at this rate ill be talkin to myself the amount of posts im putting on this thread)
post #4 of 23 (permalink) Old 07-07-2004, 18:00
Car: Mini (The real one)
my 214 used to do 100 miles to 10 easily. i REALLY wish my 220 did that
Steve220 is offline
post #5 of 23 (permalink) Old 07-07-2004, 18:04 Thread Starter
economy
am i giving it to many revs cause the car is a real sweet runner.
i sometimes hover around 3 - 4000 rpm from 2nd to 5th maybe its just that
ill have to be sensible
by the way were you drivin basically to the speed limit with it ?
ive tried real hard but soon as there are no cars i cant help but go faster.
post #6 of 23 (permalink) Old 07-07-2004, 18:14
I am getting around 180 miles to twenty quid. It has been a lot lot less then that recently but since ive been sticking to the speed limit everywhere recently and only toeing it once in a while its picked up no end.
empsburna is offline
post #7 of 23 (permalink) Old 07-07-2004, 18:15
just noticed you are from walsall, what do you drive? might have seen you about?
post #8 of 23 (permalink) Old 08-07-2004, 01:14
I get roughly the same kinda mileage - 80 ish per 10 - when doing mostly shorter runs.
This tankfull is the first I've had since moving my k&n away from the throttle body & added a second cold air feed (or to be more exact, moved the k&n over the bottom half of the standard airbox). Have now done 315 miles and aint in the red yet.......something over 100 miles to the tenner.
hmmm, makes me think I should have moved the k&n a wee bit sooner.
Gibbster is offline
post #9 of 23 (permalink) Old 08-07-2004, 06:55
I was alos thinking about this... Ive got a 216 si 98' and the tank is quite big.. around 35 i think, im just about half a cm under the half way mark and done 200 odd miles ish. but the tank was completely empty when i picked it up from the garage. So on my first tank id say im doing a little under 100 miles per tenner
neilwalls is offline
post #10 of 23 (permalink) Old 08-07-2004, 08:33
Car: Rover 200 (-95)
Lightbulb
Gibbster....you said moving the k&n helped fuel ecomony? My air filter in right where the entrance to the airbox used to be, so basicly, if I extended the pipe, and put the cold air feed into the filter (its a universal bolt on cone filter) i should get a better mpg?
Chris
chrisschild is offline
post #11 of 23 (permalink) Old 08-07-2004, 10:06
Car: Jaguar
It's better to brim the tank each time and zero the trip to work out fuel economy.
I usually get between 37 and 44mpg in a Mk3 '96 214Si depending the mix of journey lengths.
On a decent run with a bit more care, I can get over 45mpg.
Daytona is offline
post #12 of 23 (permalink) Old 08-07-2004, 10:11
Sounds like you already have a similar set up for your air filter (ie placed over the old airbox). Adding another cold air source can only help I guess.
Think the difference in mpg I gained was just from getting the filter away from the worst of the engine bay heat > leads to cooler & denser air going in > better mpg
Gibbster is offline
post #13 of 23 (permalink) Old 08-07-2004, 13:09
That seems amazing to me. As I say, I get about 27-30 mpg. Have just got off the phone to a chap at a Rover garage who has been looking at my car who says you would expect about 35 for town driving.
His diagnosis (so far) was to tighten the screws in the engine management system, after the system recorded a coolant fault, and to reset the codes. Hopefully this means the choke will stop pouring so much fuel through.
rob_emmins is offline
post #14 of 23 (permalink) Old 08-07-2004, 13:33
This post may not be beneficial to the original poster, but I'm a little confused while reading this...
Am I right in thinking (I assume this from what I've read) that fitting a K&N filter increases the mpg?
I used to get ~200 miles to 10 but that was mostly driving on motorways and 60mph roads (I drove at around 55mph - the manual that came with my car says 56mph is best for mpg?) but I've been pushing it a bit of late - something I really should stop doing as it's supping more petrol lol.
jonifen is offline
post #15 of 23 (permalink) Old 08-07-2004, 17:40
Send a message via MSN to rov214er
all depends on how hard u drive and where u drive it
rov214er is offline
post #16 of 23 (permalink) Old 08-07-2004, 20:11
Car: Jaguar
My 416 seems even better. Driving to the south coast of France a couple of years ago, fully laden with the family, aircon on and cruising at a steady 85-90mph I was getting about 44-45mpg. Was looking at filling uparound the 400mile mark on the trip.
But where I am, our rush hour is when you get stuck behind the cows going for milking. I get high 30s from the 200 on the regular 6.5 miles to work going between towns with a bit of running about. I always brim the tank and do a quick mental calc to check the consumption. It's not a bad guide for the general health of an engine.
Daytona is offline
post #17 of 23 (permalink) Old 08-07-2004, 21:34
I do mainly motorway driving in my car... ~100 round trips to Liverpool and back. Would a K&N make it more fuel efficient? (sorry to hijack your thread macka_smacka btw)
jonifen is offline
post #18 of 23 (permalink) Old 08-07-2004, 21:54
Car: Please Select
Ive been getting around 55-60 miles per 5 recently, this is a mix of short runs and dual carriageway and country roads.
I once got 47mpg on a run to Cardiff , I rekon after my servicing and so on that ive done it would be more like 50mpg on a similar run. I have to say the 1.1 K Series is bloody good , loves being taken to 5000-6000revs and even sounds quite sporty.
Oyster45 is offline
post #19 of 23 (permalink) Old 08-07-2004, 21:57
very true... the squeal noise it makes when its being pushed a bit is reminiscent of watching the TOCA touring cars on telly
jonifen is offline
post #20 of 23 (permalink) Old 08-07-2004, 22:13
Car: Please Select
Its a lovely engine compared to the bag of nails Ford CVH in the Fiesta and the ridicoulous sounding 1.2 8v Corsa unit, it really does sound like an hairdrier but just less powerfull 0-60 in 18 seconds brum brum .
0-60 in 13 seconds , 100 mph (do able but not nice) and 45mpg can't argue with that for a 1.1. Not looking forward to taking three family members and an oversized suitcase on Monday to the airport. I think I will need to take the rear mudflaps off as they will catch under that load.
Oyster45 is offline
Rover 400 - Fuel economy!? Time to move on? DMGRS MG ZS / Rover 45 & 400 5 11-05-2008 22:44
Rover 214i Fuel economy strictly MG ZR / Rover 25, 200 & Streetwise 3 09-03-2007 15:26
Rover 75 2.0 V6 - Fuel Economy ! Mainjolt MG ZT / Rover 75 (Sponsored by Rimmer Bros) 10 02-12-2006 22:21
rover 216 fuel economy rada080388 'R8' Rovers (aka Wedges!!) 6 17-06-2006 17:42
rover 214i best fuel Economy gear/speed norseman Others 38 24-11-2005 10:26
